05-27-2012, 07:03 PM | #1 |
Rep 521
WTF alignment, and what can I do now?
Took my car in for alignment since I'm doing some hpde events and I'm looking for something a little more aggressive.
Asked for max even front camber (pins pulled) with zero toe, and -1.7 rear camber with 1/16 toe in per side. Here is what I got: Rear left toe is WAY out. Took a look under the car and found this: Left side: So it looks like my toe adjustment is in fact maxed out. What would cause this? Car has never hit a curb or been hit. What are my options now assuming nothing can be done to the car as is? Here is the right side for reference: Thanks, Adam |
05-27-2012, 07:11 PM | #2 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
Not sure why you would go to the dealer for a race alignment.
05-27-2012, 07:21 PM | #3 |
Rep 6,773
If you need more rear toe adjustment there is a solution..I had these on my 335
http://hpashop.com/Rogue-Engineering...rms-e9x-m3.htm |
05-27-2012, 07:40 PM | #4 |
Rep 521
05-27-2012, 10:35 PM | #5 |
Commander In Chief
Rep 103
Left rear is definitely tweaked. Something's bent. I would start and replace #10 in the pic.
http://www.realoem.com/bmw/showparts...16&hg=33&fg=30
M Powered
05-27-2012, 10:47 PM | #6 |
Rep 521
I'm wondering if I should go with a new toe arm (wishbone) or adjustable set of arms. I'd prefer against the adjustable arms since this car sees winter driving.
In theory, that toe arm will probably be the first to bend, and a longer (unbent) one will immediately solve the toe problem. Last edited by apecush; 05-27-2012 at 11:11 PM.. |
05-28-2012, 03:12 AM | #7 | |
Rep 6,773
Bottom line is if you need more rear toe adjustment b/c your maxed with the eccentric bolt stock setup there really is only one solution..aftermarket and Rogue is a proven race setup..so you cant go wrong |
05-28-2012, 11:19 AM | #8 | |
Rep 521
05-29-2012, 05:44 PM | #10 | |
732
Rep 3,735
The factory car actually has plenty of toe adjustment capability, even on cars that are extremely low. The toe adjuster always has more than enough toe to set the alignment. If in fact the alignment cannot be set with the factory hardware, you might want to start looking into bent components, or the sub-frame may have shifted, something I have seen many times on E46 and E9x M3's. To the OP, I don't see how that tech managed a 0.00 driving axis on the rear axle with the BMW system with static toe on each side being so far off from one another. The only thing I can think of is that the frame is not aligned and these settings were required to compensate for that. Good luck!
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
05-29-2012, 07:59 PM | #11 | |
Rep 521
Measured the toe links, they are identical. Left side (notice the bulge in the steel) right side (bent at end) |
05-29-2012, 08:01 PM | #12 |
Rep 6,773
That trailing arm is actually meant to be flimsy..I remember my body shop guy saying that its designed to crush on impact..curious..since you say you havent hit anything
05-29-2012, 09:13 PM | #13 | |
732
Rep 3,735
And my apologies, I didn't read the print out correctly.
05-29-2012, 10:13 PM | #14 |
Rep 521
no worries. guess $80 for both arms is easier to swallow than a new subframe, though, if this is simply from the shitty roads around town/winter driving, I'll probably be replacing these once a year. Guess I should stock up...lol.
02-20-2014, 10:35 PM | #15 |
Rep 3
@tibra1- hi, I was wondering if the wear on your rear tires was inside; if so, did the Rogue Engineering Rear Toe Arms help with that problem? I feel as though I'm running out of options- you're response and feedback will be greatly appreciated!
02-20-2014, 10:39 PM | #16 |
Rep 3
gummywerms - hello, was the excessive wear on your tires inside? If so, did the Trailing arm replacement fix your problem? I appreciate your feedback- thanks
02-23-2014, 04:34 AM | #17 | |
Rep 3
02-23-2014, 09:28 AM | #18 |
Rep 3,633
Inside wear is very common for all BMW cars. This is use to the factory negative rear camber specs. If yours is more than Normal there may be an issue as mine has never been too bad but I've seen some stock 5 series cars that wore tires bad
02-23-2014, 10:52 AM | #19 |
Rep 4,381
Inside of the rear tyre wear will "appear" to be worse if you run with 0 or positive toe at the rear (toe out)....as the standard oem setting of slight rear tow in, tends to balance out the rear tyre wear,
