06-09-2012, 05:47 AM | #1 |
Rep 86
DCT Park
This is probably a stupid question but I'm going to ask anyways. I ordered my M3 a few weeks ago with DCT and was wondering, since there is no PARK and you just pull the hand brake in neutral. What if you were parked on a hill? In MT card you would put it in first or reverse depending on the way you parked. But what about the DCT?
Just randomly thought of it so don't hate. |
06-09-2012, 06:40 AM | #3 | |
Rep 86
06-09-2012, 06:41 AM | #4 | |
Rep 86
06-09-2012, 08:52 AM | #5 |
Rep 53
06-09-2012, 09:41 AM | #6 |
Rep 86
06-09-2012, 10:11 AM | #7 |
Low Pro...
35
Rep 1,067
06-09-2012, 10:57 AM | #8 |
Rep 324
If you'll have the comfort access option, then you should also note that if the car is in neutral but you insert the key fob into its slot that the car won't go into park on shutdown. This is for rolling into car-washes and other instances where you might want to be in neutral with the engine off.
06-09-2012, 06:42 PM | #9 | |
Rep 86
06-09-2012, 08:14 PM | #10 |
OIF Veteran
246
Rep 2,106
if you haven't done so already, some advice is to start reading the owners manual.
You can download it from the BMW website: http://www.bmwusa.com/Standard/Conte...modelcode=1137 It covers parking with DCT (just go to the back, where the index is, and things are hyper linked by term/topic)
Retired: '06 BMW E46 ///M3
Current: '08 BMW E60 DINAN ///M5, Interlagos Blue, SMG DINAN Stage 2 Suspension, Exhaust, Stage III Software, Front strut braces, Intakes, 13% Underdrive pulley, 3.91 Differential, RPI Scoops. |
06-09-2012, 09:08 PM | #11 |
Rep 1,159
brake, handbrake, turn off car, look at the screen panel in-between the speedo and RPM and see that it went to P and then let go of the brake pedal and pray that the car doesn't peace down the hill lol.
M3.E90 JZB Coded.GTSDCT.BomizValved.TurnerTestPipes.ResDelete .EurochargedTune.AAFilter.HRER40s
06-10-2012, 12:05 AM | #12 | |
Rep 86
06-10-2012, 12:06 AM | #13 |
Rep 86
06-10-2012, 12:08 AM | #14 | |
Rep 1,432
Don't leave your car in neutral: the handbrake alone is not Sufficient in the e9x m3. Here is my past story: http://www.m3post.com/forums/showthread.php?t=560095 |
06-10-2012, 01:37 AM | #15 | |
Rep 86
06-10-2012, 01:58 AM | #16 |
Rep 265
06-10-2012, 02:47 AM | #17 | |
Rep 3
http://en.wikipedia.org/wiki/Parking_pawl And it sounds like using P solely could damage the transmission (pasted from the above article)... Most vehicle manufacturers and auto mechanics do not recommend using the transmission's parking pawl as the sole means of securing a parked vehicle, instead recommending it should only be engaged after first applying the vehicle's parking brake. Constant use of only the parking pawl, especially when parking on a steep incline, means that driveline components, and transmission internals, are kept constantly under stress, and can cause wear and eventual failure of the parking pawl or transmission linkage. The pawl might also fail or break if the vehicle is pushed with sufficient force, if the parking brake is not firmly engaged. Replacement can be an expensive operation since it generally requires removing the transmission from the car. |
06-10-2012, 07:23 AM | #18 |
Rep 1,705
I thought this thread was going to be about a park for only DCT cars, like dog park is for dogs.
JK... Funny how even car enthusiasts are a little confused/intimidated by the modern tech in BMWs
06-10-2012, 08:35 AM | #19 | |
Rep 86
06-10-2012, 09:10 AM | #20 |
OIF Veteran
246
Rep 2,106
once you're done reading the manual the first time, read it again. Then again.
06-10-2012, 11:45 AM | #21 | ||
Rep 324
If there's one piece of advice I'd give a new DCT driver/former MT driver it would be this: Don't park in tight spaces on a steep down slope faced downhill. Having to quickly get the car to reverse uphill without slippage is definitely one situation that's easier to negotiate out of with an MT. |
06-10-2012, 07:19 PM | #22 |
Rep 2,271
I loaded the manual on my iPad. So, every time I'm on a flight that's more than an hour, I'm reading my manual. And every time, I learn something new about my car (I've read it about 10+ times now).
2011.75 E90 AW | DCT | ZCP | ZCV | ZCW | ZP2 | Prem Sound | Moonroof | BMW Apps |
Mods List: Evolve Exhaust | M Perf Steering Wheel | Tint | Lux | Hardwired V1 | KW V3 | Volshlag CP | Brembo BBK | BBS FI | Yokohama AD08 R| Schroth 4 Point Harness | Challenge GT Diffuser | OEM GTS Wing| GTS Lip| I lied earlier, I wasn't done with mod, but I swear, I'm done now, no more mods... |
