06-11-2012, 08:48 AM | #1 |
Rep 1,303
Lowering the car on b&g springs, can camber be aligned within oem spec?
Just wondering if I lower the car on b&g springs (1" front .5" back) would the camber still be able to be put within oem specs with an alignment? I don't want crazy uneven wear on the tires obviously...thanks
06-11-2012, 10:46 AM | #2 |
Rep 1,250
Can it be put to OEM specs: almost certainly, dropping an inch only adds about .3-.4 degrees of negative camber inherently, and the OEM adjusters have plenty of range to lower negative camber.
Necessary to put to OEM specs for wear: Maybe not. You are not going to get abnormal wear at only -1 or -1.5 degrees, especially if you ever drive in curvy places. I run -2.0+ and haven't experienced uneven wear. I think to get "crazy unever wear" you would have to run a ton of camber, more than is even possible with the stock adjusters. |
06-11-2012, 01:18 PM | #3 | |
BimmerPost Supporting Vendor
732
Rep 3,735
The car has plenty of adjustment capability. Malek
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
