06-12-2012, 06:08 PM | #1 |
Rep 1,274
OEM batter w/installation=$405?
My battery won't last much longer. The dealer quoted be an installer batter for 405... Is there a way of getting it cheaper? Does the car need any programing after exchanging it? 40% is labor
06-12-2012, 06:15 PM | #3 |
Rep 486
a new battery does need to be "registered" so the charging rate will be appropriate for it.here is a good explanation:
http://www.m3post.com/forums/showpos...7&postcount=12 |
06-12-2012, 06:47 PM | #4 |
Rep 915
Your car not in warranty? Every BMW I have owned has had a new battery installed prior to warranty going away. But, yep, they are expensive.
Just wondering. vz
Previous Track Toy |
06-12-2012, 06:51 PM | #5 |
Rep 6,773
This is why I say that every BMW owner should have a BT Tool...with that you can register the battery yourself..on my 335 replaced and registered my battery....just paid for the battery cost ...$220
06-12-2012, 07:37 PM | #6 |
Rep 1,292
How do you know the battery needs replacing (other than the obvious)? My warranty is up in November and if it's that expensive I want to make sure I get it replaced before then under warranty!
06-12-2012, 07:44 PM | #7 |
Rep 2,928
Drives: 328i, 335i, M3, 535i, X5, 36M
Garage List 2014 Ford Raptor [0.00]
2012 328i E92 [10.00] 2013 X5 [0.00] 2013 335i F30 [8.00] 1990 Toyota Previa [0.00] 1997 E36 M3 [10.00] 2011 E92 M3 [0.00] 2011 535i [0.00] |
06-12-2012, 07:47 PM | #8 |
Rep 6,773
Thats the professional version (unlimited VINs and coding)..The enthusiast version does everything except coding (3 VINS) ..costs $290...Bought mine used off e90post for $150
It has paid for itself a dozen times with my 335i and now my m3. |
06-12-2012, 07:57 PM | #9 | |
Rep 2,928
I definitely need this but 700 is not worth it because it would be sitting there I'm storage most of the time |
06-12-2012, 08:13 PM | #10 |
Rep 6,773
06-13-2012, 01:08 AM | #12 |
Rep 264
What the??! I've only had my car about 9 months so I'm still learning a couple of things and this is the first I've heard of this. Someone please explain to me what BMW has done that requires you to 'register' the battery when all you're doing is a simple swap?!?
No dipstick, can't change your own battery, oil you can only find at the dealer...what's the opposite of DIY? Seems this car is engineered to maximize the chance that any simple item needs to be addressed by the dealer. I understand it's a complex product but the basics should be something the mechanically inclined can address if desired. |
06-13-2012, 04:43 AM | #13 |
Rep 2,426
between your 335i and m3, you changed your batteries 12 times?
“For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.”
- John 3:16 |
06-13-2012, 08:23 AM | #14 | |
Rep 326
06-13-2012, 08:49 AM | #15 | |
Rep 153
Drives: 08 E90 M3 DCT
At the end of the day, I didn't save that much (maybe $100). If you're interested in some coding, find a reputable shop in your area that offer coding and have them do the "registration" with the coding. Some also offer remote coding. You could install the battery yourself and use the remote coding to "register" it. Most likely, you still won't save that much over what you're currently being quoted. You simply get more for your money. |
06-13-2012, 09:10 AM | #16 | |
Rep 6,773
You can reset CBS, troubleshoot and clear codes, register batteries, ecu management and data log..lamda sensor adaptaions, tmps sensor fault..etc etc |
06-13-2012, 09:48 AM | #17 | |
Rep 486
so,it's a lot more expensive than the old integra it replaced for a dd,but every time i drive this thing i have a smile on my face,even if it's just to the store.when i take it on some back roads,a much bigger smile. that's worth a lot. |
06-13-2012, 10:27 AM | #18 | |
Rep 1,292
06-13-2012, 12:54 PM | #19 | |
Rep 264
Excellent, thanks for the explanation. So if I were to source my own battery of the same type already in the car (e.g., the black AGM or white standard) would coding be needed or would I simply be able to swap it out?
Not an issue yet but I like to know these things in advance. I'm going to have to check on the sensor package on the battery terminal later today. Quote:
06-13-2012, 01:42 PM | #20 | |
Rep 2,928
What if I go in and they tell me the battery is still good? is the replacement pending inspection or just changed regardless of remaining battery life? |
06-13-2012, 05:18 PM | #22 |
Rep 1,274
Thanks to all for the answers.
My battery is giving low voltages and the low battery alert went off a couple of times during the winter. The dealer says I dont drive the car enough and that I "use the car with the engine off too much", meaning opening and closing doors and trunk with the engine off, or even having the car off but with the key around.... like when I wash the car (every week). I tried to get a new one under warranty, but they refused. |
