06-26-2012, 01:38 AM | #1 |
Rep 310
Can lowering reduce rubbing of front tires?
I'm on 275/35R18 ET25 and my front tires rub against the rear wall of the wheel well at a bit over half of the steering range. For lowering to help, it would have to move the front wheels forward. Is that the direction of suspension travel?
I've read that some people are running the same wheels & tires without rubbing, but at least one of them is lowered. Is lowering the key, or might there be some other variation at work, such as different camber plates?
06-26-2012, 08:06 AM | #2 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
Lowering adds negative camber which many times can allow a tire to clear where it wouldn't before.
06-26-2012, 12:12 PM | #3 | |
Rep 961
If this is happening only on the passenger's side, there's a possibility that your windshield washer fluid reservoir has come adrift. It's mounted behind the wheel well liner at the back, and if it's come off its moorings then it pushes the liner forward and it will rub against the back of the tire when you turn the wheel. If that is the problem, remounting the reservoir and reinstalling the liner will fix it, but when I had the issue, the reason it was loose in the first place was that the suspension would flex back under hard braking (track use) and the tire would hammer the liner and knock the tank loose. So the fix didn't last past the next track day. Lowering won't change anything. |
06-26-2012, 12:19 PM | #5 |
Rep 961
Adding negative camber, with or without lowering, helps if the tire is hitting the top of the fender arch. That's not the problem here and lowering or increasing the camber won't have much of an effect.
06-26-2012, 12:20 PM | #6 | |
Rep 2,792
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
06-27-2012, 01:34 AM | #7 |
Rep 310
Thanks for the feedback. I had the wheels off (re-installing stock fronts, while I get this sorted out, since they still have some tread left) and it seems like lowering will move the wheels back, if anything. That's counter-productive, for my issue.
Anyway, the rubbing is on both sides. I'm using 275/35R18 on a ET25 wheel (no spacers). I guess I'll have to downgrade to 265/35R18. Since these are ultimately destined to be my track wheels, half the steering range should be plenty. I'm thinking I'll try to wear down these tires, though I'd better do a lot of track days since I'm no longer using them on the street!
06-27-2012, 10:56 AM | #8 | |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
06-27-2012, 11:33 AM | #9 |
Rep 961
In this case, the rim width doesn't matter. The tire tread is what's hitting, and the width of the tread face doesn't change as you change rim width. The only thing that moves it is offset.
06-27-2012, 11:39 AM | #10 | |
Rep 961
That's a great idea! |
06-27-2012, 11:02 PM | #11 | ||
Rep 310
I've had camber plates installed at another shop that does track prep (including a lot of alignment work), and they didn't note anything suspicious. The miles on the car are consistent with the tire wear (original tires still on the wheels). The previous owner had another set of wheels on there for about a year, but I know he sold those. I guess he could have had a set in between... No accident on the record, BTW. Quote:
I'm pretty sure I've seen one or two others mention 275/35R18's rubbing in front. They seem like they just might work on a higher offset wheel.
07-01-2012, 02:52 PM | #12 |
Rep 8,077
Drives: 11 E90 M3 Individual
I have 275/35R18s and have no rubbing issues Its not even close. Maybe your alignment is way out of spec or something?
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
07-03-2012, 11:26 PM | #13 |
Rep 310
You have a 2011 E90. I have a 2008 E92. Could either the difference in years or the difference in chassis have anything to do with it?
07-04-2012, 12:00 AM | #14 |
Rep 961
My E92 was one of the first 2008 M3's in North America, delivered 18 days after release for sale. So, no, it's not a year-to-year difference. Something else is causing this.
07-04-2012, 10:40 PM | #16 |
Rep 310
Wheels are Apex ARC-8 10" ET25. Tires are Dunlop Direzza Star Spec 275/35R18. Car is 2008 E92 with EDC. It came with 220M 19" wheels.
07-04-2012, 10:53 PM | #17 |
Rep 8,077
I have the same tire and wheel setup and I don't rub at all. Odd.
07-04-2012, 11:14 PM | #18 |
Rep 961
07-05-2012, 11:25 PM | #19 | |
Rep 310
Maybe I'll take it into Turner and have them look at it.
Thanks, all, for your info & opinions. I received this advice in another thread: Quote:
Tags |
lowering, rubbing |
