07-01-2012, 12:58 PM | #1 |
Rep 145
What could this leak be?
I'm thinking transmission fluid.. I got a HUGE nail in my tire, and when i was refilling it, I drove the car back in my garage and found a huge puddle. Put it on race ramps and its just pouring out fluid. Picture:
And since this forum hates me, here's a direct link to the picture: http://postimage.org/image/4kz3bf1xt/ |
07-01-2012, 01:10 PM | #3 |
Rep 145
God.. What could've caused it? This makes me wonder.. Sometimes when I'm in M mode with Power on, EDC on, and MDM on, when I pull off from a light at normal speeds the RPMS surge and the car bucks forward a bit. Like theyll go to 3k RPM, 2k, 3k, 2k, then I have to let up on the gas to get it normal again.
Should I get it towed, or fill it and drive it? I bought this damn thing 2 and a half weeks ago |
07-01-2012, 01:28 PM | #9 |
Rep 145
07-01-2012, 01:31 PM | #10 |
Rep 6,773
07-01-2012, 01:36 PM | #12 |
Rep 6,773
07-01-2012, 01:47 PM | #13 |
Rep 1,590
BMW Coolant is Blue; OP are you sure it wasn't water from the AC mixing w/ something else. You would know if it was trans fluid right away
07-01-2012, 01:52 PM | #14 |
Rep 145
Well Trans fluid is USUALLY red, and this wasnt red. If the coolant is blue, it wasnt blue. I'm judging this based on looking at it on my gray garage floor, so unless its a strong color I might not even notice it has color.
I've never had the car leak anything untill a nail is conveniently in the tire, and it was a consistent drip from the transmission.. Maybe I kicked up some nasty stuff from a construction zone and it damaged something? It smells like very pure water. Like that kind of stuff you use to fill a humidifer or something. The strange thing is. It didnt start leaking till I backed the car up today to look for what was in the tire Just got Tire Kingdom to order a $400 dollar rear tire.. EDIT: leaking has stopped. would my car tell me anything if it was a certain fluid? Right now all it says is RIGHT TIRE LOW. Last edited by Invadermoose; 07-01-2012 at 02:04 PM.. |
07-01-2012, 02:52 PM | #19 |
Member
75
Rep 379
With most of these threads it ends up being water from the AC. Were you using the AC when/before it was leaking? If you can't tell what color it is maybe you should pick some up with a white piece of paper.
It might be best to just tow it to the dealer of your not sure.
07-01-2012, 03:02 PM | #21 |
First Pride
110
Rep 1,557
Yes. Run the car with the ac on for some time and see if the water came from the same place and if it looked the same. Just my 2 cents
Modded M4
