07-02-2012, 07:46 AM | #1 |
Putcha ang ganda...
281
Rep 5,441
Brake bleeding.
so i did a flush on my brakes this past weekend. I noticed that my driver side rear does not have the pad sensor but all other 3 wheels do... is this how it suppose to be i looked around if it got loose or somehow the dealer disconnected it but i just can find anything else. Can someone chime it if one suppose to be in there?
07-02-2012, 08:16 AM | #2 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
It is supposed to be there afaik.
07-02-2012, 09:08 AM | #3 |
Rep 6,149
Correct me if I am wrong but I believe you will only have two brake sensors, on in the rear and the other in the front on the opposite side. I may have this wrong but I think it is front left and rear right.
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
07-02-2012, 09:53 AM | #4 |
307
Rep 13,093
Unless it's different on the older cars, the sensors are on both fronts and one rear.
07-02-2012, 11:03 AM | #5 |
Rep 4,318
Sensors are on both sides in the front but only one in the rear.
GT3 RS | Desperately seeking the next great M car...
07-02-2012, 12:47 PM | #6 | |
Rep 4,002
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
07-02-2012, 02:56 PM | #7 |
Rep 381
Strange.
My car which has the same brake system has sensors on right rear and left front only. I think my '07 335i was set up the same but I'm old and can't remember that far back. |
07-02-2012, 08:05 PM | #8 |
Rep 869
OP, So what was your question about brake bleeding? I was getting all excited...
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20 |
07-02-2012, 09:43 PM | #9 |
307
Rep 13,093
Sounds like a possible BBK install.
07-02-2012, 11:27 PM | #10 |
Putcha ang ganda...
281
Rep 5,441
07-02-2012, 11:34 PM | #11 |
Rep 6,149
I know if anyone knew the correct answer to this it would be you. I was going off memory on my 2006 E90 330i which I could have sworn only had two. On the M3 I was not 100% certain as I did not install my BBK.
Well I think the OP has the correct answer that there are three sensors.
07-03-2012, 12:13 PM | #12 |
Rep 1,164
Same, sensors on both fronts and only right rear.
Akra GT4 / MS Stage 2 / MS UDP / BPM Tune / KW CS / H&R Sways / TMS Delrin / ST 380/355 BBK / Cantrell 2.5" Ducts / SR34 Pads / Apex Arc-8 / Hoosier R7's / Mode GT4 Splitter / GT4 Canards / APR GT-250 Wing / Cantrell Half Cage / Recaro Pro Racer / Schroth Profi II-6 / BMW Alcantera Wheel / Cool Shirt / ESS Fire Supp / Solo DL |
