07-17-2012, 08:51 PM | #1 |
Ultimate Driver for the Ultimate Driving Machine
146
Rep 1,146
Can someone explain what happened to my brake pads?
I was in NJMP Lightning on saturday. bone stock car. 20 min sessions and brand new OEM front rotors and brake pads with 500 light miles on them.
I went on the track and the first session was raining so didnt even push it then in the other 3 session, as it dried up, i went faster but i was still gentle on the brakes. I felt like the pads were not biting the entire day and i dont think i was driving hard enough to boil the brake fluid. Anyway, at the end of the day, there was a huge layer of brake dust on my front wheels. (much more than the 2 hrs i spent on VIR). On my service info screen, the lifetime of my pads went from 28k to 17k miles. Is there like a brake in period that i wasnt aware? what happened to them, just fell apart? Were they faulty parts?
BMW M3 E92 - Silverstone II BPM Sport Stage II Tune + Test Pipes, GTS DCT Tune |
07-17-2012, 08:55 PM | #2 |
Rep 310
There is a bedding procedure when you get new brakes installed, if this wasn't done it could contribute to poor brake performance. Could have let air into the brake system when installing the new pads??? Not sure...lots of scenarios. Take it back to the people who installed them for you to have it inspected.
07-17-2012, 08:57 PM | #3 | |
146
Rep 1,146
Dealer installed them and unfortunately i cant tell them that i track the car
07-17-2012, 08:59 PM | #4 |
Rep 310
Who says you have to? Just go in and tell them that your brakes aren't biting as hard as they used to prior to them installing the new set.
07-17-2012, 09:01 PM | #5 |
146
Rep 1,146
wouldnt they understand it from the wear on the rotors and the pads?
07-17-2012, 09:01 PM | #6 |
Rep 1,848
The "lifetime" of the pads is just a calculation that the car does based on speed and braking. Until the pads actually get to the wear sensor, the car really doesn't know how much pad you have left. The best way to know how much pad you used is to remove the wheels and measure the pad thickness. You probably have a bit of life left.
The OEM pads are ok for occasional and moderate tracking, but if you're really pushing it, you won't feel like you're getting enough bite. |
07-17-2012, 09:02 PM | #7 | |
Automobilist
395
Rep 2,632
07-17-2012, 09:04 PM | #8 |
Rep 1,519
Hey there--it may be due to lack of bedding as suggested above. If you only had 500 light miles on them, they might not have ever achieved proper mating between pad and rotor for the demands of track driving. StopTech has great info about why bedding (or "burnishing") is important and how to do it:
http://www.stoptech.com/technical-su...ake-pad-bed-in http://www.stoptech.com/technical-su...-system-bed-in |
07-17-2012, 09:05 PM | #9 |
Rep 310
In my experience at the track, the stock pads do just fine, but they fade after a short while. The OP was saying that the pads were soft from the get go...this is a red flag to me that something is wrong.
07-17-2012, 09:16 PM | #10 |
146
Rep 1,146
I went to VIR before with 28k old pads and they worked fine. maybe these were not broken in yet...
07-17-2012, 09:50 PM | #11 |
BimmerPost Supporting Vendor
732
Rep 3,735
Check your brake fluid as well and make sure it that it hasn't aged.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com Last edited by Malek@MRF; 07-17-2012 at 10:31 PM.. |
07-17-2012, 10:29 PM | #12 | |
Rep 961
07-18-2012, 11:03 AM | #14 |
45
Rep 345
Drives: Many BMW's & Porsche's
There are quite a few possibilities here, although I agree that it was probably a recipe of many things.
How many miles are on the car now, compared to when you went to VIR? If you have some older brake fluid, that will contribute to soggy pedal feel. Two things I would suggest: Bleed and put in a higher temp brake fluid (Super Blue, Motul, etc) as this will refresh the fluid and take out any air bubble you may have. I would also consider a set of track pads for your next outing. This will really improve your experience and safety on the track. While on track at Mid Ohio, I watched a car lose its brakes right in front of me going down the back stretch to China Beach and took out a 2 week old Boss 302 Mustang. He was using OEM brake bluid and brakes. Don't want to scare you, just something to think about. Last edited by TC Kline Racing; 07-18-2012 at 12:23 PM.. |
07-18-2012, 11:24 AM | #15 | |
146
Rep 1,146
Thanks, At VIR the car and brakes were 28k old, at NJMP it the car is on 30k miles, brakes were 600 miles old and OEM brake fluid was 400 miles old.
I am going to get the super blue and thinking of getting carbotech XP12's for the front pads. and XP8 or XP10 on the rear pads Quote:
07-18-2012, 12:27 PM | #16 | |
45
Rep 345
If you are considering Hawk or Performance Friction brake pads, we are a dealer for both |
07-18-2012, 09:11 PM | #17 | |
Rep 869
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20 |
07-20-2012, 07:20 AM | #18 |
Rep 8,077
Drives: 11 E90 M3 Individual
You didn't bed your pads. Light driving won't do it. You have to get the pads HOT so that you get a layer of the friction material on the rotor surface.
Otherwise, you won't get very good performance from your brakes. Then if you lost a lot of pad, it was probably because you didn't bed in your pads before you drove on the track.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
07-29-2012, 01:44 AM | #19 |
Rep 5,874
07-29-2012, 10:00 AM | #20 |
146
Rep 1,146
Yes, Its called abusing the car.
07-29-2012, 10:57 AM | #21 | |
Rep 9,034
The Stoptech Street Sport pads work pretty well for a combo street/track pad. .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
