BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      08-08-2012, 11:42 AM   #1
EAS
BimmerPost Supporting Vendor
EAS's Avatar
549
Drives: VF620 M3
▀▄ eas | DIY: Angel iBright V4.5 for e92 3-Series & M3 [INSTALL OVERVIEW]
Below is a video overview of the new AngeliBright (AiB) v4.5 LED Angel Eye kits showing an install into a 2011 BMW M3.
Angel iBright V4.0 fits any e92 pre-LCI 3-Series Coupe/Convertible (including all e9x M3 models) with Angel Eyes from the factory ever built.
Features:
- Brightest Angel Eye kit on the market with uniform light distribution between low and high beam Angel Eye rings
- 3 year warranty, over 3x longer than other kits on the market
- Precision 6061 CNC aluminum construction
- Much brighter compared to OEM yellow bulbs, or other competing LED angel eye kits
- 6000k to match the low beam xenon headlights
- No dimming of lights when ignition is turned on, rings remain at full power at all times
- Complete microprocessor controlled ballast system specifically designed for the 3-series Coupe/Convertible and all M3 models
- Ballast controls and maintains proper electrical conditions for the AiB at all times
- Includes all US and Worldwide e92 cars including M3 Coupe/Sedan & Convertible
- Complete OEM fitment and better than OEM finish
- Easy installation in 10 minutes, you DO NOT have to remove the headlights!
- Light bending” optical system to deliver maximum light into the Angel Eye rings
- Integrated Plug & Play Connectors, no external harnesses required
- Manufactured and assembled in the USA
- No AM/FM radio reception interference
- No Flickering, Blinking or Flashing on startup
- No On-Board Computer(OBC)/dash errors
Comparison of OEM vs AIB v4.5
Direct Sunlight
AIB v4.5 components tucked away inside headlight housing - no drilling or cutting required
Models Supported:
2007-2012 e92 3-series Coupe/Convertible
2008-2013 e9x M3, including Sedan, Coupe and Convertible models
Tools Needed:
- Flat Tip ScrewDriver
- Pliers (SoftJaw preferred)
- 5/64" Allen Wrench
Enjoy, feel free to ask questions in the thread if help is needed.
      08-13-2012, 08:07 AM   #2
kornykidd0
Drives: 2008 E90 M3
What is the difference between the AiB 4.0 and these new 4.5?
      08-13-2012, 11:06 AM   #3
mdosu
Drives: Double Vanos'd Civic-M3
my guess based on the picture is there is a new light source, perhaps brighter than 4.0?
we'll let EAS weigh in on this...
      08-13-2012, 11:11 AM   #4
THE TECH
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
Still waiting for some side-by-side pics of the setups to see the difference.
      08-13-2012, 11:13 AM   #5
EAS
EAS's Avatar
549
Drives: VF620 M3
Aside from the obvious color change, the design has been changed slightly on the heatsinks to improve efficiency.
The AIBs are already super bright. However, there's always room for improvement. Taking advantage of the newest technology, LEDs are approximately 10% brighter than AIB v4.0 with a slightly higher color temperature increase from 5500K to 6000K.
      08-13-2012, 02:09 PM   #6
rjd598
Drives: F30 340i
2016 BMW 340i  [0.00]
hahhaha ok so what about 4.5?
      08-13-2012, 09:41 PM   #7
///M3THOD
///M3THOD's Avatar
Drives: 991.2 GTS
Unless I'm missing something here, thats exactly what he's comparing them to.
      08-13-2012, 11:03 PM   #8
rjd598
Drives: F30 340i
So led refers to 4.5?
      01-31-2014, 03:24 PM   #9
blast1st
Test
blast1st's Avatar
Philippines
115
Drives: MDX as my daily @blast_1st
wow. this helps a lot. thanks guys!
      02-18-2014, 02:38 PM   #10
Maestro-p
Drives: 2011 E92 M3 Aline
Features:
Direct Sunlight
Models Supported:
Tools Needed:
How much ?$$$$$$$$
m3post
