09-13-2012, 02:01 PM | #1 |
atlien
15
Rep 371
Drives: '11 e90 335i
Common issues with e92 6MT 2008+ ??
Hi guys, my friend is looking to buy a E92 6MT M3 from 2008 or later. Can anyone please tell me if there are any issues that are common or have persisted with these cars that I should tell him to inquire about? I did search this forum but didn't come across anything that seemed to be a common issue. could be that I'm not searching the right terms, so apologies if that is the case
what I'm thinking of in terms of common problems are things like rear subframe cracking in the E46 M3, HPFP failures with 335i, exploding sunroofs in E9x, etc. Have there been any issues like the ones I listed, or have there been any recalls that he should inquire about to make sure that the recall work was performed? I did read a lot of threads talking about DCT failures, but my friend only wants a MT car so not worried about the DCT stuff thanks in advance
2011 e90 335i: AW/Oyster | M Sport | BMW Performance (Power Kit v1, Exhaust, Suspension, rear and side aero kit, 19" 313s)
09-13-2012, 03:00 PM | #2 |
Rep 344
Idle control valve and throttle actuators seem to be the most common problems. There have been a few incidents of bad bearings as well. Seems to be fairly reliable other than that.
09-13-2012, 03:08 PM | #3 |
Rep 8,496
i've seen a few posts on stuck valves and various vanos related issues in addition to the idle air control valve issue.
There's a SIB on rear diff noise, which is easily solved with a different fluid. There's also posts regarding broken diff bolt. This car is mainly reliable. I can't find that report, but someone posted on the here once on a initial quality survey drilled down by model specific, and the M3 is the highest quality product manufactured by BMW. Last edited by mdosu; 09-13-2012 at 03:14 PM.. |
09-13-2012, 03:30 PM | #4 |
Putcha ang ganda...
281
Rep 5,441
no issue im at 72k miles
only replacement was when i had 4k miles on it and entire tranny was replaced due to bad gears and just recently 1 week ago i replaced the low pressure sensor which cost me 50 bucks. other than that.. its all good.
09-13-2012, 03:51 PM | #6 |
atlien
15
Rep 371
thanks for the replies. I did search, and all i uncovered was the DCT stuff
09-13-2012, 04:07 PM | #9 |
Rep 2,688
09-13-2012, 04:27 PM | #10 |
atlien
15
Rep 371
i came across exploding sunroof threads after I bought my E90 and have never opened my sunroof since then. one day my wife says "it's a nice day, let's open the sunroof" and I was like "NOOOOO"
it's a crazy issue though. BMW said it was due to a rock hitting the sunroof but then a local TV station in socal did an investigation with some university professor who said it would go against the laws of physics for a rock thrown by a car in front of you to hit the sunroof with force at a downward angle. and the pics from people with the exploding sunroofs clearly show that the sunroof is exploding upward. so yea, I never use the sunroof and pray that it doesnt happen
09-20-2012, 10:57 PM | #11 |
Rep 74
My wife's E92 made in October 2011 with less than 3000 miles on it is getting its throttle actuator valves replaced right now. Unbelievable that BMW does not recall the cars based on the number of reports on this specific problem.
09-20-2012, 11:29 PM | #12 | |
Rep 2,513
AW|FR 6MT E92 ///M3 |
09-20-2012, 11:52 PM | #13 |
11818
Rep 23,187
ive never heard about the exploding sunroof issue. i have one and have never given that a thought. should i worry about spontaneous combustion of my passengers as well. i might win the lottery first.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
09-22-2012, 02:02 PM | #14 | |
Rep 12,315
Overall, this car has been by far one of the best/most reliable M car in a while! That's what convinced me to pull the trigger, without any warranty at that.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
