BMW M3 Forum (E90 E92)
BPM
      09-18-2012, 12:46 AM   #1
rzm3
Moderator
rzm3's Avatar
675
Drives: E92 M3
Arrow DIY: Changing M-DCT Fluid
I realize that this is long overdue, but here it is!
Important
Let your car cool for an extended period of time (at least 4 hours depending on the ambient temperature) before starting the process. If the transmission's temperature is too high, an incorrect amount of fluid could be added.
Fluid needed
83 22 0 440 214 BMW DCTF-1 (1L)
83 22 2 147 477 BMW DCTF-1 (20L)
Special tools needed
Fluid pump
Thermometer/contact pyrometer
Procedure
1. Remove the protective cover under the transmission.
2. Drain fluid by removing the plastic plug near the front passenger side of the transmission. Fluid can be extremely HOT! If your car was just driven, I would suggest waiting a few hours before draining the oil.
3. Once the fluid drain stops, reinstall the plug. Torque to the suggested value listed on the plug.
4. Open the filling hole (red box). Using a fluid pump, add M-DCT oil into the transmission. I added about 3 quarts before fluid started to emerge from the filling hole.
5. Ensure that M-DCT fluid inside the transmission is below 90 deg. F. Then, close the filling hole.
6. Turn on your engine. In position P, maintain 2000 rpm for about 1 minute.
7. Reopen the filling hole and add additional fluid (about 2 quarts) until fluid starts to leak out from the hole again. This process must be completed while the transmission fluid temperature is below 104 deg. F.
8. Close the filling hole and reinstall any removed panels.
JsL447.50
AndyW673.50
      09-18-2012, 04:41 AM   #2
OM VT3
OM VT3's Avatar
140
Drives: 2011 e92 zcp m3
did your car drive any better once you did this?
      09-18-2012, 07:04 AM   #3
Porschefile
Porschefile's Avatar
59
Drives: E92 M3
Thanks for the info OP. So you added a total of roughly 5 quarts? Is the fill bolt the one with white paint marking alignment with the trans?
      09-18-2012, 08:40 AM   #4
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
I assume you would only recommend doing this for those who are outside the warranty period?
      09-18-2012, 08:58 AM   #5
warp10
warp10's Avatar
776
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
2011 M3  [10.00]
2011 28i X3  [0.00]
that 20L bottle is expensive!
      09-18-2012, 10:47 AM   #6
Grail05
Putcha ang ganda...
Grail05's Avatar
Drives: 17 F82 M4
NICE write up...
      09-18-2012, 11:29 AM   #7
rzm3
Moderator
rzm3's Avatar
675
Drives: E92 M3
No perceivable difference.
BMW lists the 'initial fill' at 7.8 liters. But when you do an oil change, not all the fluid drains out, so only about 5 liters/quarts can be added. I've performed this on two cars and had one checked by BMW to verify that the fluid level is correct.
Yes to your second question.
The oil change process is not detectable/traceable.
      09-18-2012, 11:32 AM   #8
THE TECH
THE TECH's Avatar
307
So are those your marks on the trans and plug?
Also, doesn't it supposedly void the warranty by doing so whether it's deemed detectable or not?
      09-18-2012, 11:53 AM   #9
rantarM3
Drives: E90 M3
I recall you had the fluid tested from your car (http://www.m3post.com/forums/showpos...49&postcount=1) and the fluid was found to be in very good condition with 30k miles. With that in mind, why did you change it on the second vehicle? Have you continued to get the fluid tested and if so, have you found a point (i.e., mileage) where the degradation is noticeable?
      09-18-2012, 02:13 PM   #10
Porschefile
59
Drives: E92 M3
Anybody know somewhere to buy the stuff cheaply? I seem to remember somewhere selling it for $25-30/liter but can't find it now.
      09-18-2012, 10:52 PM   #11
=[monkey]=
=[monkey]='s Avatar
19
Drives: f82 m4
awesome write up! looks easy
      09-18-2012, 11:55 PM   #12
rzm3
Moderator
rzm3's Avatar
675
Drives: E92 M3
It was a vehicle with higher mileage. Customer was moving abroad where he would have limited access to BMW service/parts.
Talk to your dealer. Some offer discounts for car clubs such as BMWCCA and Houston M Club.
      09-19-2012, 11:57 AM   #13
rantarM3
Drives: E90 M3
This is pretty much the same procedure for changing the transmission fluid (partial change) in an X5, which is rated to 100,000 miles. Why the M3 DCT is "lifetime" while the X5 is 100k is beyond me.
Any suggestions as to when you think the fluid ought to be changed?
Also, could you elaborate a little on how you measured the fluid temprature? Is it as simple as inserting the sensor into the fill-opening?
Thanks for making this thread!
      09-21-2012, 08:16 PM   #14
rzm3
Moderator
rzm3's Avatar
675
Drives: E92 M3
^Yes simply insert the sensor into the fill opening.
      09-22-2012, 03:58 PM   #15
bigjae1976
bigjae1976's Avatar
1579
Drives: 11 E90 M3 Individual
2004 BMW M3  [4.50]
2011 BMW E90 M3  [5.25]
2013 BMW 328i  [5.00]
Cheap DCT Fluid
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue
2004 E46 M3 Imola Red
2000 E36/7 Z3 Steel Blue
      09-22-2012, 04:09 PM   #16
Porschefile
59
Drives: E92 M3
Originally Posted by bigjae1976 View Post
Thanks!
      09-23-2012, 05:23 PM   #17
VictorH
Drives: '09 M3
I thought I had read elsewhere that you had to run the DCT pump to drain more fluid and that was only something the dealer could do (but wouldn't since it's "lifetime"). Is this true or not necessary. I guess if the net yield was only 0.5L or less that I would skip, but do you know if that's needed or not?
      09-24-2012, 01:58 AM   #18
rzm3
Moderator
rzm3's Avatar
675
Drives: E92 M3
No I have not heard about this. Perhaps you are referring to the fact that when the engine starts, some of the fluid gets pumped into the cooler and that's why more can be added when that process starts?
      09-24-2012, 08:12 AM   #19
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Nice DIY. where is the fill hole located exactly?
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      09-24-2012, 09:49 AM   #20
bigjae1976
bigjae1976's Avatar
1579
2004 BMW M3  [4.50]
I do that in my automatic M3 (Mazda3!). I brim the tranny with fluid. Remove the tranny cooler return line and then turn on the car. Shift from P to D a couple of times and then the tranny pumps out the fluid trapped in the cooler line. That will drain 3 extra quarts of ATF. Note that I overfill the tranny because you do NOT want to run the transmission dry.
I would imagine that it would be a massive PIA to do it like that in the DCT. Pumping extra liters into the DCT would be tricky, time, consuming, and (if on jack stands) very tiring. If you get 5L of 7.8L by a simple drain and fill, that's good enough for me.
My Mazda takes 6 qts of ATF, 3 of which is in the cooler and lines. So its worth it and its easy to add extra ATF in the dipstick tube.
      09-24-2012, 09:51 AM   #21
Porschefile
59
Drives: E92 M3
As OP said above, the fill hole is the bolt with the white paint marking alignment with the trans, shown in the last pic in the original post.
      09-24-2012, 03:00 PM   #22
klammer
Drives: 11 spc gry m3 e90, 19 X5
Thank you so much for this. Am planning on doing this during the winter as my car is beat pretty hard
mods: track ready stuff
m3post
