09-24-2012, 03:41 PM | #1 |
Rep 129
pedal panel removal?
Has anyone removed the panel surrounding the pedals? It has several electrical components attached to the inside and one of them is marked ABS. I wondered if anyone has done this and if the battery needs to be disconnected etc.. Any actual experience with this would be appreciated.
11-25-2012, 04:04 PM | #2 |
The Crowing
111
Rep 2,005
I took mine off in search of the footwell module. I didn't unhook the battery. Plugged everything back in and it works fine.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback |
11-27-2012, 07:52 AM | #3 | |
Rep 129
I remember that two of the clips seemed self explanatory to remove but the other(s) did not. Do you remember how all of the clips release? It has been a while since I looked at it. |
11-27-2012, 12:17 PM | #4 |
The Crowing
111
Rep 2,005
i think there was just 2 maybe 3 screws holding it on. in the back above the the foot rest, next to the clutch, there was a tab that had a home to slide into. besides that i think its just unscrew and pull down. while i had all those wires disconnect i kept hearing a noise through the speakers while the car was trying to wake up. once i put everything back together i couldn't hear it anymore.
