10-04-2012, 02:05 PM | #1 |
Rep 326
Warranty Expires Soon. Inspection Recommendations.
I recently purchased my 08 E92 M3 and the warranty expires at the end of this month. A local, fellow BMW owner recommended having his CA do an inspection on my car prior to the warranty expiring. His CA happens to look the other way when it comes to mods so I set up the inspection for next Tuesday morning. I've been searching for a thread with recommended checks but for the life of me cannot find it. Please recommend specific things I should have him target or point me to a place where I can do my own research. Thank you in advance.
2008 AW E92 M3: Stage II and DCT tune by BPM Sport, convenience coding + coding for mDrive w/Euro MDM (no iDrive) & alarm retrofit by BPM Sport, Fox Red interior, ESS midpipe, Corsa slip on exhaust, carbon fiber M Performance spoiler, black grills, black OEM M3 ZCP 19" wheels, 15/12mm spacers and AW painted reflectors
10-04-2012, 02:43 PM | #3 |
11818
Rep 23,187
try to get them to check your rear differential bolts. if needed you can say you have been hearing a rattle from the back end and are concerned. I took mine in and got the SA to change rear differential fluid, brake fluid, pads, oil change, cabin filters, wiper blades, and do a diagnostic.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
10-04-2012, 04:28 PM | #4 |
Rep 326
I should have mentioned this is just the factory limited warranty. The routine maintenance portion conveniently expired a month before I got the car. The limited warranty was extended due to the original owner being a BMW executive.
