BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      10-10-2012, 08:22 PM   #1
Car54
Drives: 2014 M-Sport Wagon - EBII
Adjustable perches - how many threads
How many threads of the sleeve should the collar come into contact with. I just installed the GC sleeve kit and to get the car lower than stock i needed to be just below the bottom of the threaded sleeve with the collar.
I'm not sure why I needed to get that low, I guess maybe it will settle in and I'll have to raise it back up. I only have about 3/4" of travel before the bump stop.
      10-13-2012, 01:44 AM   #2
CarbonFoot
CarbonFoot's Avatar
37
Drives: 2024 M3 CS
You might not have the sleeve's fully seated on your damper. It's a tapered fit and it needs a decent amount of force to get it properly seated. You should also make sure both sides are equally fitted by measuring.
      10-13-2012, 07:14 PM   #3
HP Man
Drives: Batmobile
+1 You definitely have an error in your install as you would be significantly lower than stock with the adjusters that low if it was done correctly.
      10-13-2012, 08:36 PM   #4
Car54
The hub's sleeve where the shock goes into or the threaded collar/sleeve/spring perch?
      10-15-2012, 07:01 PM   #5
CarbonFoot
CarbonFoot's Avatar
37
Drives: 2024 M3 CS
^ It could be either or both, but the damper into the hub assembly is probably fine. I suspect the sleeve-over spring perch is clamped too high.
      10-15-2012, 07:45 PM   #6
Car54
After 4-5 hours of a road trip and a couple hundred miles round Daytona, the sleeves should be compressed by now. I'll post up some pics of my settings and stance for comparison.
m3post
