08-04-2007, 02:41 PM | #1 |
Rep 253
Drives: 335 cab,C-6 08, 73 911E 59 D,
A concern about carbon fiber roof (green House)
Maybe ?
A Black carbon fiber roof may likely be a bit of a confinement issue for me and I have not checked how carbon fiber, especially Black will disapate heat being that my composite hard tops on other cars were blistering hot and were worse inside than metal, Now I am sure that in Germany it wont be bad but in Phoenix, It wasnt super hot in Spain What do you think ? I didnt search on this so I hope is not a repost
TELL me what real drivers training do you have besides your State Drivers License ?
08-04-2007, 02:47 PM | #2 |
Rep 5,124
there are good cf roof arguments going on in regards to how it is going to look over time. as far as heat dissipation goes, the cf should be better at distributing the heat over the surface. only problem is that i am not sure if it has as much insulation below it as the normal roof does. if you live in phoenix it is going to be hot as hell anyway, and it is not going to make a difference. no matter where you live, the difference between cf and regular as far as temp goes is going to be negligible (you aren't going to notice). you can always use the auto fan function to help circulate air.
08-04-2007, 02:49 PM | #3 |
Rep 10,407
Tested and properly developed
The US is BMW largest market. They test in Death Valley, CA. They have environmental test chambers that are even more severe than Death Valley. With the proper selection of resin and clearcoat the CF roof can be more durable than a painted metal roof. I am not the least bit concerned about the longevity of the roof. Ask some M6 guys as well!
08-04-2007, 02:54 PM | #4 | |
Commander-In-Chief
2203
Rep 8,949
08-04-2007, 03:44 PM | #5 | |
Rep 1,356
It's an absolute moot point the very second you turn your AC on, the 2 degree more your car might heat up due to some ill concieved thoery, is rendered pointless. I'm just curious as to how this would be a concern to anyone ans what thought process leads up to such an inquiry from an owners viewpoint. -Garrett |
08-04-2007, 04:10 PM | #6 | |
Rep 6,968
08-04-2007, 06:06 PM | #7 | |
Reincarnated
245
Rep 4,227
08-04-2007, 06:31 PM | #8 |
Rep 1,603
Drives: F80 M3
08-04-2007, 07:16 PM | #10 |
Commander-In-Chief
2203
Rep 8,949
Probably isn't. As I noted, if anything, CF plastic is a better insulator than steel sheet; but, it is so thin that doen't make much difference.
08-04-2007, 07:17 PM | #11 |
Commander-In-Chief
2203
Rep 8,949
Useless
Shows the desperation on this forum--nothing new to talk about since the last reviews.
08-04-2007, 08:37 PM | #12 | |
Rep 72
phoenix is hot!
2006 BMW M3 | SMG | Jet Black | Black Nappa Leather | Titan Shadow Trim | HK Prem Audio |
08-04-2007, 09:34 PM | #13 |
Rep 1,075
nothing tops the desperation of having that thread talking about the type of material the Trim is made of lol
ZzZzZ'er |
08-04-2007, 10:05 PM | #14 |
Rep 5,498
Isnt the roof actually CF enforced fiberglass. I was under the impression that the roof is actually mostly fiberglass.....
Jason
Instagram: jellismotorwerks |
08-04-2007, 10:20 PM | #15 | |
Commander-In-Chief
2203
Rep 8,949
Hot!
08-05-2007, 01:42 AM | #16 |
Rep 10,407
Don't think so
Pretty sure I read somewhere the number of layers and the orientation of the CF fabric used to make the roof. Can't find the reference quickly right now. Makes sense to me. The part need strength and stiffness and fiberglass is nowhere close to CF. If the design was not as stressed and someone wanted to design more of a poser part you could certainly use multiple layers of fiberglass and a thin outer layer of CF just for looks.
08-05-2007, 10:27 AM | #18 |
Rep 4,178
Drives: E90 325i, E82 135i
green House.....
08-05-2007, 10:37 AM | #19 | |
Rep 1,356
His concern was over a CF roof, not a black one. Meaning, I don't understand his heat-saok question directly related to the carbon fiber..? Basically, a moot point! I go shopping too, doesnt matter where you live, when it's 90 ~ 105 and your car heat up inside it takes common sense to leave your windows cracked about an inch and when approuching the car hit your remote to releive the car of it added temp. I have Remote start intigrated into my cars (not sure if that possible with the e90) so the car has been running for a few minutes... Ahhh cool leather on a hot day! Start the car and THEN put your belongings away. You can't even touch my roof when it hot, black roofs could easily cook an egg. I highly doubt a CF roof will be as hot as a black roof. But worring about having that extra heat SOAK INTO THE CAR is anal, considering that the car with a white roof is going to get heat soak too. The difference between a CF roof and a black one won't matter to the inside temp. -Garrett |
08-05-2007, 11:40 AM | #20 |
Rep 798
It's difficult to get good data, insulation of the roof will probably matter regarding CF. Anyway, regarding the impact on color with a standard roof:
Study I read measured cars on a hot day ~ 90F?, the experimenter measured/estimated ~ 5 degree (F) increase in the cabin of black surface car over white or silver, all things being equal, in steady state. The surface temperature difference was ~ 50C higher IIRC, illustrating the efficacy of the insulation. I would expect that if one lives in very hot region, that one would benefit from a white top as compared to black top, maybe not huge, but noticable. |
08-05-2007, 12:12 PM | #21 | |
Rep 1,356
Yes, but only noticible when entering the vehicle. After you open the car up that 5 degree(F) difference is lost pretty quickly. If you leave a Black car sit in the open for 5 hours with the windowed shut, and then leave an identicle White car parked right next to it but with the windows down and the test the ambient interior temperatures of both cars 30 seconds after the doors are opened, I bet it won't be 5 degree's difference. But, that isn't the question at hand, it was strickly related to a CF roof. 30 seconds with A/C on and in both instances it's a moot point...! |
08-05-2007, 01:22 PM | #22 |
Rep 4,128
Drives: M235i & G30 540i
Oh I wish there was something new and exciting in this forum to read about.
