11-03-2012, 04:30 PM | #1 |
Rep 316
Seatbelt Handover/Extender Spring Failure, Fix??
The spring on the end of the seatbelt extender mechanism has failed. It doesn't have the same tension as the passenger side and doesn't grab the seatbelt anymore. I'm on the CPO warranty so I'm sure its not covered, I can delete it but I would like to fix it if I could. Has anyone taken apart the arm? Fixed the spring?
11-04-2012, 01:53 AM | #2 | |
Rep 12,315
If the mechanism is shot, I think you can get to it from the back of the panel and get a replacement part.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
11-04-2012, 03:42 AM | #3 |
Rep 290
Common problem on the e92..I believe you have to replace either the entire motor or the extender, no individual parts are available
http://realoem.com/bmw/showparts.do?...72&hg=72&fg=05 |
11-04-2012, 11:25 AM | #4 | |
Rep 316
11-04-2012, 03:28 PM | #5 |
Rep 290
And replace it with what? As I said there are no individual pieces available..I suppose you could try and "fix" the spring..but I wouldnt count on that working..especially if the spring has lost its tensile strenght.
02-10-2013, 11:12 AM | #6 | |
Rep 50
2008 M3 coupe - DCT & EDC, AA
02-10-2013, 11:19 AM | #7 |
Rep 2,352
Drives: 16' BMW i8
Garage List 2001 BMW M3 E46 CON ... [9.50]
2016 BMW i8 [10.00] 2003 JEEP GRAND CHE ... [0.00] 2000 540i SPORT E39 [10.00] 2007 TOYOTA TACOMA ... [0.00] |
I am pretty sure this is still covered under CPO Warranty
02-10-2013, 03:56 PM | #8 |
Rep 26
Whoever was on the design team for this ridiculous thing should have their engineering degrees stripped. I wonder if they even bothered making a test stand for this before they slapped it into production.
(Also, I checked on mine, not covered under CPO). |
02-10-2013, 04:01 PM | #9 | |
Rep 26
http://www.leespring.com/ Having said all that, unless the spring is somehow damaged, it's unlikely to be worn out. |
02-10-2013, 04:50 PM | #11 |
Rep 392
Just to chirp in...
Happened on my e93, only the belt would not extend out. Without being buckled a passanger sets off the seat belt alarm. Drive ya nuts! So, no passangers till BMW ordered the part (under warranty) and replaced it. Took about a week. |
02-11-2013, 03:55 PM | #12 | |
Rep 16
02-11-2013, 04:16 PM | #13 |
Rep 12,315
This is why I pulled the fuse for this stupid thing. I'll deal with having to reach really far back to grab the seatbelt. I'm used to it now.
Current:
08-06-2013, 02:45 PM | #14 | |
Rep 2,677
Drives: e92 + f15
Do you happen to have the part numbers for the extender arm? Maybe it might be something the dealerships locally can order if we spoon feed them. |
08-06-2013, 04:06 PM | #15 |
Rep 2,677
Drives: e92 + f15
I should've googled earlier... ECS sells them: http://www.ecstuning.com/BMW-E92-335...Belt/ES186833/
08-06-2013, 07:17 PM | #16 |
936
Rep 4,327
Drives: M340
Disconnected mine 10 mins after delivery and never looked back.
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
08-06-2013, 08:08 PM | #17 |
Rep 4,252
Drives: 2017 M3 MG/SO ZCP DCT
How do u disconnect is it just a simple fuse pull? Is there one fuse for both sides?
08-06-2013, 11:54 PM | #18 |
Rep 659
It's actually an $80 part and a 5 minute DYI. All the info and the part you need are here: http://www.m3post.com/forums/showthr...ght=ricfutures
Kit comes with a thin metal "flap" (lack of a better term) that helps you remove the old one. You just need to find the clip that holds it in place. Also, you don't need to remove the mechanism from the car to perform surgery. Simply turn off the car, open your door, hold the arm preventing it from retracting until it stays put. Replace then turn the car on. Arm should retract once you close the door. As over engineered as this thing is I love having it.
F97 X3M
F80 M3 (Sold) E90 M3 (Sold) EB M235i (Sold) E92 M3 (Sold) |
10-17-2013, 08:34 PM | #19 |
Rep 365
Has anyone actually had this replaced under CPO warranty? Was at the dealer today for an oil change and asked about it and they said it wasn't covered and wanted $135 just for a diagnostic. Others have said it should be covered though. I don't really see why it would be excluded, unless they consider it a wear and tear piece.
10-18-2013, 05:19 AM | #20 |
Rep 6,673
Has anyone tried this on an LCI e92 M3?
BMW part 52302208036 http://www.amazon.com/BMW-Genuine-Ho.../dp/B004XEII26 . |
10-31-2013, 12:18 PM | #21 | |
M-GAM3
240
Rep 1,264
Car Enthusiast.
10-31-2013, 12:35 PM | #22 | |
Rep 365
