11-11-2012, 09:32 PM | #1 |
Putcha ang ganda...
281
Rep 5,441
REAR rotor and pads replacements. ????
So I have never replaced a rotor on our cars and curious how easy it is to replace the rotor and pads.. ive done a lot on Honda, Toyota, and other cars but not on BMW.. is there something that i need to look out for? or tools i need?
Thanks.
11-12-2012, 03:18 AM | #2 |
78
Rep 684
Should be very straightforward. There's a DIY on the forum written by Lucid.
The only trouble I've run into is that sometimes the rear rotor could be seized onto the hub... so some type of bar would really help. In the worst case, use a hammer and hit the areas between the wheel studs. Works very well to remove seized rotors.
11-12-2012, 04:34 AM | #3 |
Rep 5,813
^This...the worst part will be getting the rotor off if it's seized to the hub, and if this is your 1st rear rotor change then it's most likely seized. However, Richard is correct, pull out the "big" hammer
Only other thing to remember is the rear parking brake drum is integral to the rear rotor (release the parking brake). |
11-12-2012, 09:16 AM | #5 |
45
Rep 345
Drives: Many BMW's & Porsche's
Not too much to be afraid of with this job. Make sure you crack open the master cylinder cap for when you push the pistons back into the calipers for the new pads.
Tools: Impact or long ratchet to get lugs off screwdriver for anti rattle clip and caps to hex bolts 7mm hex socket and 3/8 ratchet don't forget the set screw for the rotor (be careful, they strip easily - I may recommend an impact driver to get it off) brake spreader, c-clamp, large mouth adjustable pliers (to push piston back in) That's about it. Again, pretty straightforward, and yes, it will be similar to other cars you have done.....maybe easier. Last edited by TC Kline Racing; 11-12-2012 at 10:26 AM.. |
11-12-2012, 09:55 AM | #6 | |
Putcha ang ganda...
281
Rep 5,441
Thanks. sounds like the same process to any old car or even recent cars.. Thanks... guys..
11-12-2012, 03:44 PM | #7 |
Rep 118
Call me ignorant, but I've been changing the pads without opening the cap and have not run into any issues. Why is this necessary or a good idea?
11-12-2012, 04:23 PM | #9 | |
45
Rep 345
I guess its not imperative, just a good idea to open it and check the fluid while you're doing it. Some people think it makes it easier to push pistons back in because it relieves the pressure. |
11-12-2012, 06:45 PM | #10 |
Putcha ang ganda...
281
Rep 5,441
its OEM got deal off this forum... new for $240 oh yes thats a set...
11-12-2012, 07:28 PM | #11 | |
Rep 2,792
Sean, I use a 2x4 and whack the rotor to pop it loose. If it's REALLY stuck, sometimes it's possible to wedge the end of a breaker bar between the caliper ear and the rotor and pry. Just make sure the end of the breaker bar clears the fender lip or it will dent the fender from the inside when the rotor lets loose.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
11-12-2012, 09:03 PM | #12 |
Rep 1,789
11-13-2012, 12:52 PM | #13 |
Rep 2,339
A good couple of whacks with a rubber mallet in strategic locations seems to do the trick for me when the rotors are seized to the hubs.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
