BMW M3 Forum (E90 E92)
BPM
      12-08-2012, 02:09 PM   #1
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
wanted DIY OEM rotor removal
looks like a pretty easy job as i change pads all the time. just wondering if there is a DIY for rotor replacement or any tricks i needed to know. Have Turner stud kit so will have to pull those and replace into new hat. thanks
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      12-09-2012, 08:24 PM   #2
ThunderMoose
Drives: PY E46 M3 and SG E46 M3
There aren't any real tricks, but I'd recommend a couple of things:
- remove the set screws before you remove the calipers otherwise you won't have anything to stop the rotors from turning when you try to remove these screws.
- make sure to disengage parking brake when actually removing the rear rotors
      12-09-2012, 08:36 PM   #3
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
okay thanks. those are both good tips.
      12-17-2012, 10:04 PM   #4
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
anyone find one i still havent.
      12-18-2012, 12:18 AM   #5
thorny
thorny's Avatar
I am looking for the same thing
      12-18-2012, 08:27 AM   #6
2000gsr
2000gsr's Avatar
Drives: 2018 M4
Bump! I need this DIY as well.
      12-18-2012, 09:55 AM   #7
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
I'm also wondering about wheel bearings. My guess is that removal of the rotor gives easy access for their replacement. Not sure if I need it yet at 27K but there have track miles
      01-17-2013, 10:11 PM   #8
tooshay
tooshay's Avatar
Drives: G20+M3 badge
The removal of the rotor is pretty easy once you have the caliber off. Just put some wd40 into the center if the rotor is stuck, then just use a mallet to hit the rotor from behind as you rotate the rotor, and it should come off. It's pretty straight forward. Hope this helps.
G20 with some ///M3 stuff = G80
      01-17-2013, 10:19 PM   #9
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
can the studs be left in as they are loctited in?
      01-17-2013, 11:06 PM   #10
Chriskm3
Chriskm3's Avatar
good question. what is the difference in re /re with a bbk kit?
      01-18-2013, 08:45 AM   #11
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
Removal of front and rear are straightforward. You may need to use a hammer with the screwdriver to remove the set screw depending on how old your brakes are. Also, the rotors may be hard to remove due to rust. A good plastic mallet will help here. Otherwise, removal is the same as any other car.
      01-18-2013, 09:34 AM   #12
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Went to change them out last night but still have 28.5 to 28.7 left so gonna wait a few more track days and change em out in the spring.
      02-13-2013, 07:01 AM   #13
Sleeper519
Sleeper519's Avatar
Drives: 08 E92 M3 DCT
What is the minimal rotor thickness before needing to replace? (StopTechs)
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20
      02-17-2013, 09:08 AM   #14
ThunderMoose
On the outside edge of the rotor, there is a min thickness stamp. I'd guesstimate for your rotors that it will be 31 mm.
      02-18-2013, 09:22 AM   #15
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
how do you use a hammer and screw driver on a hex head fitting?
      02-18-2013, 01:21 PM   #16
dmw16
Drives: 2005 ///M3
I think this was more-so directed at removing the rotor. Sometimes they get stuck on and you need to pry them off with a screw driver or 'motivate' them with some shots from a deadblow hammer. When trying to get the rotor loose stand clear as best you can because you don't want the rotor landing in your foot.
      02-18-2013, 01:54 PM   #17
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Okay that makes more sense. Pulling the fronts tonight. Hopefully the set screws aren't a bitch. Are those 2 little screws really all that keeps my entire rotor and wheel assembly from shooting off into the woods?
      02-18-2013, 02:25 PM   #18
vastano
Drives: F15 X5
no, the screws are there only to hold the rotor onto the hub. Thats it. On cars with studs or BMWs with the stud conversion, they arent *really* needed since the wheel keeps it pressed against the hub like any other car on the road.
      02-18-2013, 03:48 PM   #19
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Okay got it. So the set screws are just that. Locate the hat on the mounting plate. Then the wheel torque holds the assembly on to that backing plate.
      02-18-2013, 04:42 PM   #20
Chriskm3
Chriskm3's Avatar
Please don't be like me and forget to release the hand brake when trying to remove the rear rotors.
Vf supercharger + tune/H&R coils/ Akra evolution exhaust/Volk te37/ Rs-3 tires/ Brembos /TIal BOV/ OSS blacked out headlights/LUX v3/Led taillights/ Challenge Front lip/ P3 vent gauge/ F10 m5 shift mob/Matte black front grills/ And a funky air fresher
      02-18-2013, 05:26 PM   #21
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Thanks already got that tip and only doing the fronts this time.
      02-19-2013, 12:20 AM   #22
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
just did this tonight. barely takes any more time than pads do. super easy. my set screws were easily removed and the rotor just fell off no need to beat it first with a hammer. it took longer to double nut my studs as i was replacing my turners for new set of apex at the same time.
m3post
