01-06-2013, 03:02 PM | #2 |
Rep 2,388
Drives: M2 Competition
not sure if this is the issue but try changing the switch position. I had this happen in another Euro car because of the position wasn't quite on the right spot on the switch. The other thing it could be is that one headlight is higher up(as it should be). the passenger side headlight is higher so as not to blind oncoming traffic.
01-06-2013, 03:12 PM | #4 |
Chemofski
54
Rep 1,295
Yes, show us your headlights.
'13 Individual Frozen Brilliant White ///M3 Coupe
Ordered 2/15/12 | Euro Delivery on 9/21/12 | U.S. Redelivery on 12/6/12 | Motor Dead on 7/15/13 '13 Space Gray/Mugello Red X5///M Pavement Punisher | Snow Muncher | Family and Board Hauler | Roadtripper |
01-06-2013, 03:46 PM | #7 |
Rep 904
Drives: E90
2011 E90 M3 6mt AW/Speed Cloth - ZCP, Moonroof, non-iDrive - PCD 12/9/10 Painted reflectors, matte black grills/gills, Deansbimmer Belly Pan, DEI Alarm, Homelink/compass retrofit, Passport MAX2 Hardwire, GP Thunder 8500K, modmy3 LED interior, Dinan Mufflers, HRE P40 19" Satin Charcoal, Michelin PS4S |
01-06-2013, 04:18 PM | #8 |
Member BMW CCA Los Angeles
32
Rep 470
Drives: 2022 M8 GC Comp
Look at the difference with the light pattern up against the wall in high beam and low beam. If one doesn't change then the high beam module might be stuck/malfunctioning and you'll need to take her in. Hopefully you're under warranty.
Current Rides:
2022 ///M8 GC Comp Much enjoyed: 2018 ///M4 ZCP || 2014 ///M5 ZCP || 2011.5 ///M3 Sedan || 2007 ///M Coupe || 2008 550i Sport || 2006 ///M3 ZCP || 2008 X3 3.0si || 2006 325i || 2003 Z4 3.0 Roadster || 2003 330ci || 2002 325i |
