01-17-2013, 10:41 AM | #2 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
You will notice that they will only fit right one way. Just play with them until you have them lined up right, then get yourself some double sided tape and put on the inside where the splitters will contact the bumper. Expose the adhesive and then line them back up as carefully as possible and attach to bumper.
01-17-2013, 11:34 AM | #4 |
307
Rep 13,093
01-17-2013, 11:48 AM | #5 |
Rep 1,159
Does the 3M tape really hold the splitters when you are driving 100mph??
M3.E90 JZB Coded.GTSDCT.BomizValved.TurnerTestPipes.ResDelete .EurochargedTune.AAFilter.HRER40s
01-17-2013, 11:49 AM | #6 |
307
Rep 13,093
01-17-2013, 12:11 PM | #7 |
Rep 282
step 1: use painter tape and tape your car 1st before dry fit to avoid scratching the paint.
step 2: dry fit and move around until you find the desired position. 1 hole should line up to the existing screw. step 3: put 3M tape on, preferably 1 long one instead of a lot of short ones. step 4: remove the painter tape on the car, clean the surface well, use alcohol and let dry if you have it. step 5: put on a glove to avoid letting your sweat touch the surface. unscrew the screw, fit the splitter, screw it in, just a little bit, not too tight so you can move the splitter around. position to the desired position you had before. remove 3M tape, and use pressure to push down. when secured, screw the screw in tightly. step 6: enjoy and drink a beer
10' E92 M3 6MT
15? F15 X5 35i |
01-18-2013, 12:03 PM | #8 |
Rep 882
Drives: 2013 ///M3 E92 DCT ZCP
Thanks guys. Got today and ill try without drilling another whole in. BMW wanted to sell me their adhesive stuff but they told me if I use it I cannot remove it so I went with the M3.
01-18-2013, 12:04 PM | #9 |
Rep 882
Now does anyone know where to get the instructions from. Not that I can't so it looking at the you tube video, but I thought it came with instructions. Does any one have it?
01-18-2013, 08:49 PM | #10 |
Rep 1,590
you shouldn't need instructions, you can only put em on one way. Use 3m tape on edges, (i would use a simple self tapping screw underneath) and you're done. Really like 30 min worth of work
01-18-2013, 11:21 PM | #11 |
Rep 116
2010 E92 M3 /// Le Mans Blue Metallic /// Silver Novillo Leather /// BMW OEM 19" ZCP Gunmetal Rims /// BMW OEM Carbon Fiber Front Splitters /// BMW OEM Edition Black Chrome Grills /// BMW OEM Edition Black Chrome Gills /// 3D Design Carbon Fiber Rear Diffuser
01-19-2013, 12:29 PM | #12 | |
Rep 882
01-21-2013, 08:48 AM | #13 |
307
Rep 13,093
01-24-2013, 04:20 PM | #14 |
Rep 1,711
Its really hard to beleive that doubble sided tape and one screw will hold the splitter at over 100 miles per hour.
This is the only thing thats holding me back from putting it on my car. But i have to say that our cars look great with front CF splitters. |
03-18-2013, 11:19 PM | #15 |
Rep 145
Tested mine going 150 plus mph and they are all intact...no issues.
06-17-2013, 12:29 PM | #17 | |
Rep 1,711
Anyone knows what is the real purpose for those rods? |
06-18-2013, 07:55 AM | #18 |
Rep 473
135mph on the back straight at Mosport. No issues.
DR CHUCK
2009 E92 M3 Le Mans Blau on Schwartz. DCT. RAC RG63, KW V3, Eisenmann Race, AP Racing, Vorsteiner GTS5 Front Bumper, Vorsteiner GTS-V Rear Diffuser. |
08-09-2013, 05:11 PM | #19 | ||
Rep 882
08-09-2013, 05:20 PM | #20 |
Rep 5,507
The OEM side splitters really do not provide much downforce as an actual splitter (flat bottom panel lip). It is mostly cosmetic. Tape and 1 screw is fine.
Auto Detailing Enthusiast!
08-13-2013, 10:21 AM | #21 |
Rep 2,342
As speed increases, pressure on the splitter increases. The rods keep the Splitter from distorting from aero, and additionally distorting from impacts with the road when the suspension and aero compress the front. Some regulations require the splitters to be in a fixed postion as well.
