02-04-2013, 03:06 PM | #1 |
Rep 912
Why you should never buy a CIC retrofit kit from amateurs...
You should never buy CIC Navigation Systems from non-professional s (Ebay, Amazon, amateurs, etc.). Scroll below to read why! This important information will save you time and money, and most importantly, will you give you peace of mind! 1. Software: When you buy from unknown and untrusted sources, you can never know what’s inside of the system. The software is often outdated and unsupported. A system with outdated software will give you limited functionalities, and it may cause compatibility issues with your vehicle. It will cost you additional money, to do the software upgrade, and most dealers will never do this type of work for you! 2. Hardware: When you buy from unknown and untrusted sources, you never know whether the equipment has been tested. You may be getting equipment that is not functioning properly or is not functioning at all! The seller does not provide warranty, and you may be stuck with equipment that is not good for anyone, except your nearest electronics recycling shop! Moreover, the equipment may be damaged (with water for example) and if you install the equipment that has been flooded, into your vehicle, your vehicle may become damaged as well. We have been made aware of situations, when the vehicle’s electrical system was short circuited after one of such installations. As a result, vehicle owner lost his BMW warranty. 3. Remote coding Never trust amateurs with coding your vehicle! In almost every case, when a vehicle is coded by non-professionals, BMW Dealer will refuse to retain the guarantee of your vehicle, because non-professionals have tempered with the vehicle’s electrical and/or software system. If this happens to you, you will be stuck with a $50,000+ vehicle with NO MANUFACTURER’s WARRANTY. And knowing how expensive repairs and maintenance can be, this is not the situation, in which you would want to find yourself. In other instances, when a vehicle is coded by amateurs, your vehicle may become stationary, meaning it will be impossible to start the vehicle and drive it away, because the coding has been performed incorrectly. In these situations, the vehicle will need to be towed to dealership, which will be able to identify and eliminate the errors, and …. possibly remove your warranty. Not all dealers will perform this type of job to fix your vehicle after amateur’s coding! Those who will, will charge you a high price for the coding. 4. Shipping and cosmetic condition of the products More often than not, non-professionals do not properly prepare the products for shipping, and they arrive damaged. In addition, you do not have visibility of the products that you buy - the products can be scratched, rusted, cracked. If you are lucky, the seller will provide a replacement, but because usually the seller provides no guarantee, you will have wasted the money on the product that you cannot use or that is not aesthetically pleasing. At Bimmer Retrofit, we have an established and trusted supply chain, that selects and supplies only the best after-market systems for our customers and we always take special care when preparing products for shipping to ensure that they arrive safely and are not damaged during shipping. It is up to decide who you will buy your CIC Navigation System from, but we hope that this information will help you understand the total cost of ownership of your Navigation System and vehicle and will help you make an informed decision, so that you can be in control of your financial situation! Last edited by bmwretrofit; 02-04-2013 at 07:05 PM.. |
02-11-2013, 03:43 AM | #2 |
Rep 100
I have one question for the CIC retrofit.
If I get US language CIC retrofit, is it possible to switch to other language for extra cost?
09 e92 M3 Coupe
TE37RT with Hankook R-S3 265/285 Techtec ECU Stock Exhaust |
02-12-2013, 01:36 PM | #3 | |
Rep 912
It is possible to change to another language later on, but it cannot be done remotely. You will need to ship us back the CIC and we will do language conversion here. One important thing to keep in mind: if you are considering to change the language to one of the Asian languages, you will LOSE US maps. For all other languages, language conversion will be ok. |
02-12-2013, 02:30 PM | #5 |
White Shark
88
Rep 919
where is canada are you guys located ? and can you pm the price for CIC for an 08
ESS | Challenge x-pipe | Akrapovic | Stoptech BBK (380/355) |Ohlins R&T | Dinan | Vorsteiner | Downforce USA | Varis Diffuser | Gintani | UUC | BMW Performance | Macht Schnell | Forgestar F14's SDC 19x9.5F 19x11R | 255.35 295.30
02-14-2013, 10:40 AM | #6 | |
Rep 912
We can also pre-code your CIC with up to THREE (3) European languages, and you can easily switch between them. This is a much better solution, if you know in advance which languages you want. P.S. this does not cost extra |
02-22-2013, 12:31 PM | #9 | |
Rep 912
The Car Information Computer (CIC) continues the path laid out by the earlier CCC system and takes it to the next level of development. The main noticeable feature of this iDrive system is the newly designed controller that is now equipped with seven direct access buttons. These buttons provide shortcuts to the menus in the redesigned layout of the user interface. Compared to the CCC system, the number of CD/DVD drives in the CIC has been reduced to one optical drive. The CIC overall screen dimensions have remained the same. However, the number of pixels have doubled from 640x240 (CCC) to 1280x480. This provides improved visual quality by generating a sharper graphic display. The navigation system display has been enhanced with the following functions: • Full screen mode • Night view • 3D models in the perspective map view The use of an integrated HDD (hard disk drive) now allows navigation map data to be saved on the CIC hard disk. Previously, this map data had to be loaded from a navigation DVD for each destination entry. Maps can also be displayed much faster due to the increased processing power of the CIC. The hard disk drive in the CIC also makes it possible to compile and store a personalized music collection. An 8GB section of the total 80GB hard disk is dedicated to store music files. These files can be transferred from audio CDs, MP3 players or USB sticks. Along with the music data files, the music track database (Gracenote®) is also stored to be used for the music search function. An address database has been included in the "Contacts" menu, which can also be accessed from the Telephone and Navigation menus. This feature offers a single “location” for accessing contact information. The information contained is more comprehensive than before. Many external receiver hardware devices such as IBOC and GPS are integrated in the CIC. This adds flexibility and expands the system’s functions. |
03-17-2013, 03:49 PM | #11 |
Rep 912
Yes. Please see the following page for a location near you: http://bimmerretrofit.com/store/inde.../store_locator
03-17-2013, 05:48 PM | #12 | |
Rep 1,374
2018 F80 M3 ZCP Mineral White- Extended Shakir Orange - Full Suntek Ultra Wrapped - ///M Performance Spoiler - RKP Front Lip - RKP Side Skirts - Vorsteiner GTS Diffuser -AA Mid-Pipe-///M performance HAS kit - HRE P101
11 E90 M3 JEREZ BLK METALLIC ZCP SOLD |
03-19-2013, 12:39 PM | #13 |
Rep 912
Please see our website for the current price: http://bimmerretrofit.com/store/inde...&product_id=53
If you have any questions, please email us: info@bimmerretrofit.com Thanks, Kate. |
