02-05-2013, 12:23 PM | #1 |
Rep 944
Car Vibrating...Help!
I've been getting a wierd vibration between 2-3k RPM in second gear. Whether its giving the car 40-50% throttle or just driving normal the vibration is there. You can feel the vibration in the seat and the entire center console along with armrest. Feels similar like the vibration I got before when my old E34 540 had a broken guibo only that with the e34 it was in every gear, alot more violent and not specific to any rpm range and with lower gears being more noticeable.
I took the car to the dealer and according to them the tech and the shop foreman took the car for spin and blamed it on my KW sleeves, exhaust resonance, or the spacers. At the time all I had was ACM testpipes/oem xpipe/acm exhaust. If it were exhaust resonance it would have been there since i was rocking AA Race X-pipe which was louder plus I know what resonance feels like. The KW sleeves were properly installed 1st week i got the car in august by ACM. I doubt it's the spacers since the steering wheel does not shake at all and they were on 2nd week I got the car untill I got my BBS. ALLEGEDLY they checked all drivetrain parts and front suspension and according to them everything is "tight like a new M3". Needless to say, I left the dealer pissed. I switched out exhaust to a more quieter Borla axleback. Nothing Bent every heatshield that can come in contact with the exhaust. Nothing Replaced the left rubber bracket that holds the exhaust because it was broken and......Nothing! It's wierd because sometimes it is more noticeable than others. But it feels like its directly under the car. I'm getting to the point where I don't want the car anymore. One thing I notice is that it is more noticeable the colder it is. Anyone have any ideas? I only found 2 threads with similar problems but the members don't seem to be active on here anymore. Sorry for the long post guys. Thanks, hope someone can help.
E90 M3 AW/Extended FR•Ohlins•Borla•ACM•K&N•IND•BBS•Vredestein•Velos Designworks•Vorsteiner•BMW Performance•Lux AE•Arkym |
02-05-2013, 12:40 PM | #2 |
Rep 3,422
If I'm reading you correctly, the test pipes have been in since you've had the issue.
Lower gears, 2-3k rpm, directly under the car. Sounds exhaust related to me (primary cat delete). Have you checked the test pipe connections? Even if they're sound seems some vibration could emanate from them. I just installed Akra Evo this past weekend after running only an axle back -- noticing all kinds of interesting sounds, resonance, and perhaps some vibration after cat delete. Nothing quite as consistent as you report though.
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
02-05-2013, 12:45 PM | #3 |
Rep 980
2-3k RPM sounds like normal resonance from the engine. Mine does the same thing, primary cat delete...then again, exhaust is the least of my vibration worries...solid bushings contribute the most hehe
Mods: too many the list wont fit in the sig page. PM me
Tesla Referral code: http://ts.la/juliana77782 |
02-05-2013, 01:13 PM | #4 | |
Rep 944
02-05-2013, 01:29 PM | #5 | |
Rep 3,422
Drastic measure maybe, and you'll have to take an afternoon and pay for some lift time, but since you're about ready to get rid of the car because of the issue..
02-05-2013, 01:40 PM | #6 |
Rep 944
I've though about it. But i think the only 2 other threads exactly like mine were stock cars.
02-05-2013, 07:48 PM | #7 |
Rep 17
Keep in mind that loudness of your exhaust does not mean more vibration. Vibration can be a function of frequency. If your current exhaust is quieter but has a more bass-y sound, then the may be the culprit. It may even be a super low frequency that you can't even hear. My bet is this is the issue.
If the exhaust is ruled out, then I would inspect the engine mounts, gearbox mounts, and differential bushings for bolt torque or failure. The E90 M3 is new to me, but I believe the gearbox is bolted to a subframe. If there is a subframe, then check each of those bolts as well, including whether a bolt is missing. Good luck! |
02-05-2013, 09:42 PM | #8 |
Rep 57
I had a similar issue on my 04 m3 and took it to the dealer. They could not find anything and said not to worry about it. Took it to an Independant shop in the city. 5 minutes they found a lose bolt from exhaust touching frame or something...can't remember details but they tightened it up and vibration gone and they did not even charge me. So maybe something from exhaust loose? Hope this helps
02-06-2013, 07:01 PM | #9 | |
Rep 944
02-06-2013, 07:03 PM | #10 |
Rep 944
I also notice that it is not speed related. Like i though maybe it happend at the same speed 20-30 mph but if i go from first to 3rd it doesn't do the vibration. So it's isolated to 2nd gear, and slight vibration in 5-6th gears at 50-60mph.
02-07-2013, 10:46 AM | #12 |
Rep 944
If I'm crusing at 50-60mph and i put it in neutral you can still feel the vibration.
02-08-2013, 12:37 PM | #15 |
Rep 944
02-08-2013, 12:44 PM | #16 | |
Rep 944
I took off the metal plate right in the middle of the Xpipe to see if it's related to it and I strongly believe it has to do with the exhaust. Once i took of the metal plate vibration for much worse and was in every gear. I didn't get a chance to put it back but i certainly will soon as i'm able to use the car again. The rubber mount looks fine but i'm considering buying new ones from BMW just to see if these have soften over time. My rear left rubber mount was ripped and it smothed out some of the vibration when i replaced it but not 100%. At least now it's not any drivetrain part or anything.
02-08-2013, 12:46 PM | #17 | |
Rep 17
And by vibration, do you mean a metal against metal clank or is the whole car shuddering or shaking? If shuddering it can be a number of things (some of them being what the dealer tech mentioned): When you speed up to 80 does it go away (can be as simple as a wheel weight)? How about when you go around a curve at speed, does it get worse (wheel bearing or suspension)? You said you are using spacers. Is the wheel lining up properly with the spacer and the hub? Do you have the correct longer wheel bolts? Are they torqued properly? I would jack the car up and inspect each corner, suspension tightness, wheel bolts, the tires themselves for bulges, etc. |
02-14-2013, 01:07 PM | #18 |
Brian
Rep 103
Exact same as mine. I started noticing the vibration after I removed catless x-pipe and put the stock x-pipe back on. I suspect there is a loose bolt that vibrates a perfect frequency created between 2000-2500 RPM. I am probably going to take it into the shop soon and have them twist all my exhaust bolts.
02-22-2013, 09:18 AM | #19 | |
Rep 944
02-22-2013, 09:20 AM | #20 |
Rep 944
I'm missing the bracket that bolts up to the stock cat clamps, but seems like all testpipes on the market do not use this bracket either.
07-20-2021, 11:52 AM | #21 |
Other car was a submarine
94
Rep 704
Sorry for the long ago thread bump, but I'm also getting vibration between 50 and 80mph. I originally thought it might be the driveshaft/guibo because I had the cowbell issue so I replaced it with a reman. i also just put 4 new tires on and the vibration is still there.
i was wondering if you ever figured it out? Thanks! |
07-22-2021, 06:31 AM | #22 |
Rep 207
It's probably the engine/motor mounts.
These typically fail as early as 40 to 50K miles. I've had this issue! If you're sensitive to vibrations, replace with OEM motor mounts, aftermarket ones may have more vibrations between 3-3.5K rpm & may not last long enough, the passenger side mount is too close to the exhaust headers & the heat degrades the rubber in the mount. OEM mounts are around $100 for a pair & it's a moderate level DIY. |
takrdown94.00 |
