02-14-2013, 11:05 AM | #1 |
Rep 688
Brake Dust On Rims, Really?
I seriously cann't believe that BMW have not yet developed a way to prevent brake dust from accumulating on their great looking 19's rims by now. Nothing pisses me off than looking at my new M3 wheels and noticing how dirty they get just after 25 miles of stop and go driving. I've tried rim wax and sprays to prevent the built up of brake dust and nothing stops it. I remember having this same problem with all of my BMWs (320i, 325i, 525i and 740i). And I do recall buying some brake shields for my 325i. They worked to prevent the dust from building up. But they made the rims heat up more a and they really didn't make the rims look nice at all. |
02-14-2013, 11:19 AM | #2 |
Rep 1,652
Thats just the way it is. Its a high performance vehicle and the dust has to go somewhere. All you can do is keep up with them. Avoid using chemicals and waxes to try and prevent it. The chemicals in a way end up being magnets for the dust. Use nothing but soap and water to clean the wheels.
Current: 2019 F90 M5 Competition
Previous: 2016 F80 M3 Past: 2013 E92 M3 Past: 2011 E92 335Xi |
02-14-2013, 11:22 AM | #3 |
Rep 302
I have the same gripe as well. I know all pads will produce dust, but the OEM ones seem to produce an excessive amount. When they're due for replacement, I definitely be looking at non-OEM options to reduce the dust build up.
02-14-2013, 11:23 AM | #4 | |
Rep 94
Yep, it's all about brake lining selection. There is a tradeoff for high Mu linings = brake dust. You can always look to switch to a ceramic pad :
http://zeckhausen.com/BMW/E92_M3.htm Quote:
02-14-2013, 11:24 AM | #5 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
02-14-2013, 11:27 AM | #6 |
Rep 1,463
Prevent brake dust?..interesting.. Do you also want to prevent braking?
Brake dust is an integral by-product of braking..not much can be done about it. FYI lower brake dust pads = lesser friction and braking power |
02-14-2013, 11:30 AM | #7 |
Rep 408
02-14-2013, 11:32 AM | #8 |
Rep 1,625
I've used Hawk HPS pads on my CTS-V. They had much less brake dust than the OEM pads and I thought they performed better.
There are low dust pads available aftermarket. OEM ones are quite dusty. |
02-14-2013, 11:38 AM | #9 | |
Rep 688
02-14-2013, 11:40 AM | #10 |
Rep 1,231
02-14-2013, 11:53 AM | #12 |
732
Rep 3,735
If your M3 is being mainly used on the street with very light track usage, I suggest you switch over to the Akebono EURO Ceramic brake pads. They are pretty much dustless and perform very well for a street vehicle which sees some light track duty.
If the car is going to be consistently used at the track, then brake pads, lines, and fluid are in order for you. Let me know, I can help you out a ton. Malek |
02-14-2013, 12:08 PM | #13 |
Rep 302
02-15-2013, 09:02 AM | #17 | |
***Major MammelToe
159
Rep 1,139
E92 M3 SG DCT - AA Filter, Verstraβe Paddles, ECS SS, MH race stud, Stoptech BBK, MR Exhaust,RE Pulley, BPM Tune,Euro bumper and GTS lip, Euro MDM & DCT, KW CS, Recaro PP, TMS Soild Diff Mounts, MRF solid subframe mounts, GTS aero, RPM track built motor.
02-15-2013, 10:45 AM | #19 |
Rep 2,446
Drives: '11 E92 M3 DCT
That shit works! I also put on the tread on my tires to keep them from squeaking
11' E92 M3 Space Grey | DCT | ESS VT2- 625 | Gintani Race (valved) + Quad Res Catless X-Pipe | KW Sleeve's | GC Camber Plates|Arkym Diffuser | Vorsteiner VRS Lip | P3 Boost Guage | Stud Conversion PHOTO's: Click Here ESS VT2 625 PHOTOS: Click Here |
02-15-2013, 02:19 PM | #21 |
Rep 1,773
Drives: 328it, RIP M3, E46 Sold
I have had 2 sets of Akebono's on my E46 and have had almost ZERO brake dust.
02-15-2013, 06:49 PM | #22 | |
TIM YOYO
1505
Rep 3,283
Drives: 2013 M3
It's about $12 a can, but it's totally worth it. This stuff keeps the brake dust off for weeks. Some tips for using this: * Clean the wheel extremely well before applying and DO NOT touch the wheel with your hands before applying; the slightest amount of oil from your fingers will keep it from working right * Apply liberally, but slowly; take your time like you're painting the wheel * Once you've applied it well, you can wash the wheels with soap and water (no wheel cleaner) and re-apply a little less liberally to safe the product
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech Past: 2013 ///M3 - Interlagos Blue Black M-DCT Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport |
