03-07-2013, 09:28 PM | #1 |
Rep 8,496
Automobile repair/maintenance class - don't laugh
Guys, I just figured out an awesome program that helps out DIYers like myself who don't have access to the space, hydraulic lifts, and a second-hand or pointers from someone who knows cars.
Every quarter Arlington County offers Adult education classes. Aside from the standard learn VBA programming and spanish lessons...they're offering 3 different levels of auto repair/maintenance classes. The class curriculum is based on the need of the students' maintenance or repair work that's needed. There's a workshop providing a hydraulic lift and other equipment and the student is responsible to supply equipment and tools the shop doesn't have. The cost is $180 for 8 three-hour sessions in the shop. I'm thinking about signing up the class to do all my maintenance work and bolt-on work. I already know a few things that can get done at these sessions: 1. exhaust installs 2. 6MT fluid change 3. rear diff fluid change 4. brake fluid change 5. brake rotor/pad changes (or bbk install?) 6. suspension installs (I won't be doing this) 7. spark plug change 8. alignment (if equipment is available.) Pros: allows the OCD M3 owner to know their maintenance/repair work was done properly by himself. Access to a lift at basically $7.50/hour Someone can give you a second hand if needed, if you're treading into some more moderately difficult work, instructor can provide some help Cons: Instructor may know less than you Limited equipment for M3 specific work. (like installing a ESS kit, lol) Each session is limited to 3 hours You have to know at least generally what you need to do. You can't approach each session like it's your first time holding a wrench. Owner still needs to be the expert in what the steps are (M3 oil pan has 2 drains, etc) Share space and equipment with other students (not a bad thing if say 3 M3 guys sign up for the same class) does this sound crazy, or should I do this? Anyone else interested? Classes are at 7pm/8pm on weekdays, once a week, and classes are offered every quarter. Last edited by mdosu; 03-07-2013 at 09:34 PM.. |
03-07-2013, 09:44 PM | #2 |
11818
Rep 23,187
if you need the lift and have specific projects you can finish in 3 hours go ahead. me personally i like to have as much time as i want on project. usually finish quickly but what if you run into a snag. i did my studs not that long ago fairly easy but ran into issue with my rear spacer not wanting to come off and spent a ton of time with it. i would rather put it on stands at home and if i dont finish get to it another day without putting things all back together.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
03-14-2013, 09:33 PM | #4 |
Rep 1,140
Drives: Something something racecar
Interesting program, too bad it's not in Texas.
