BMW M3 Forum (E90 E92)
      03-15-2013, 09:26 PM   #1
Thik
Drives: 2010 Space Grey E92 M3 6spd
What happened to my battery? (Pics)
Hey guys, so my car wouldn't start a few weeks ago and it got towed to the dealer. The service advisor said that it was a bad battery. My 2010 E92M has approx. 35K miles on the odometer. They said the battery failed because I spilled some 'yellow' unknown liquid in the battery department. This cause the battery to short and fail. They would not cover it under warranty.
I have attached some pics. Please give me your thought about what really happened.
I know I did not spill anything in the battery compartment. Any idea what that yellow stuff is?
      03-15-2013, 09:33 PM   #2
SAINT VAN ROCK
///M Enthusiast
SAINT VAN ROCK's Avatar
Drives: 2012, E92 DCT M3
I know piss is yellow under UV....crazy stuff right there. Interested to know what that turns out to be
      03-15-2013, 09:51 PM   #3
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
that does not look like something would've SPILLED on it at all. And y would the dealer say you spilled something on the battery? Who the hell would spill anything on the battery?
It looks like some sort of mud though, does it have that acidic smell?
      03-15-2013, 10:09 PM   #4
Superfly_M3
Drives: 2011 M3
Salt water? maybe?
Isn't Sulphur yellow?
      03-15-2013, 11:41 PM   #5
White 13
Drives: A 2013 Alpine White E92
Parts store will have some battery cleaner and acid detector. It turns red or some other color when it contacts acid. You might buy a can and spray in there to see if it is a acid spill. Won't hurt to clean it with this stuff anyway it will neutralize any acid that may be in there. If it is acid it could have been an overcharging alternator or maybe a bad battery.
Looks more like mud though. Was there any water ever in there? Are you the only owner? I am thinking could the car been in any kind of flood?
      03-15-2013, 11:46 PM   #6
Vic311
Drives: 2011 e92 M3
Are you sure it wasn't the battery itself that exploded? Battery will do then when they get weak.
Also they use sulfuric acid and that looks like yellow like sulfur
      03-16-2013, 01:30 AM   #7
Edjay
Drives: 08 E90 AW, 76 2002
Self tapping screw on the second pic. Maybe aftermarket stuff done to car. Possible someone forgot to place the vent tube back on and batt was leaking inside instead of being vented out?
      03-16-2013, 04:38 PM   #8
CBS
CBS's Avatar
Drives: F10535, E90M3, E30M3, E28M5
2017 Alpina B6 GC  [0.00]
2014 535xi M Sport  [0.00]
2014 X3 3.5 M Sport  [0.00]
2011 M3 E90  [9.74]
2007 Z4 M Coupe  [7.00]
1990 M3  [9.50]
1988 M5  [10.00]
+1
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes
      03-16-2013, 05:48 PM   #9
drvai
drvai's Avatar
Drives: E92 M3 AW
Looks like a leak from the battery (or something else there).
      03-16-2013, 10:14 PM   #10
Sergm3
Drives: 2014 f10 m5 comp
Put some water in your trunk where the battery sits see if leaks out from the bottom. It looks like maybe you missing a plug and or your car sat in some deep water.
      03-16-2013, 10:31 PM   #11
Edjay
Mix some baking soda and water. Brush it around the affected area. This will let you know if its acidic. If it is, it will bubble up. This will also rid the area of acid.
      03-18-2013, 12:26 AM   #12
Thik
I don't think the car was flooded because otherwise more area of the car would be affected with water and dirt residue, not just the battery compartment.
I really think it's sulfur that the battery spewed out when it failed on its own! Damn dealership tried to deny me warranty by blaming it on me!
Is there a way to test if that yellow stuff is indeed sulfur from inside the battery and not dirt or rust?
      03-18-2013, 08:53 AM   #13
wooderson
Drives: Alpine White E92 M3
It def looks like it was submerged in something. You can see the fluid line go up in the front and back which is consistent with the fluid movement when stopping and accellerating.
      03-18-2013, 08:58 AM   #14
CD2534
CD2534's Avatar
23
Drives: N/A
It looks like a corroded battery to me. Probably just a faulty battery.
      03-18-2013, 09:10 AM   #15
05Mdriver
05Mdriver's Avatar
351
Drives: TT Flat Six
2007 Porsche Turbo  [10.00]
2008 BMW M3  [10.00]
2005 BMW M3  [10.00]
I love how dealer finds a faulty battery.. then blames OP that he spilled something in his own car to ruin his own battery.
      03-18-2013, 09:15 AM   #16
wooderson
Are those seat covers in the one pic? Why are they off the car?
      03-18-2013, 10:34 AM   #17
Thik
The seat covers are from the car beside mine.
      03-18-2013, 10:41 AM   #18
leemik
Drives: 2013 LRP M3 Coupe
2020 Acura NSX  [0.00]
2013 BMW M3  [9.50]
Did you buy your car new? clean carfax? you can see the water line on the battery as it was sloshing around.. must have been in there for a while to be all dried up ltoo... does your car have any odors?
      03-18-2013, 10:48 AM   #19
zamboni
I want to drive a Zamboni
zamboni's Avatar
Drives: 13 E93 M3 18 F80 M3 16 K71
16 K71 F800GT  [10.00]
2018 F80 M3  [10.00]
2013 BMW E93 M3  [10.00]
What did you spill?
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue
13 E93 M3 Melbourne Red
2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3
My next vehicle would be a Zamboni
      03-18-2013, 11:34 AM   #20
rantarM3
Drives: E90 M3
It definitely looks like the battery was partly submerged in some liquid. Notice the "wave" pattern on the long side. That would seem consistent with a fluid moving back and forth as the car accelerates and decelerates (pointed out by others). But also look at how the residue becomes more concentrated as you move down the side. That seems consistent with a fluid evaporating over time and with the concentration of the residue becoming higher as there is less fluid. At the bottom of the battery compartment is where the material appears thickest.
How much liquid was in the battery when they pulled it out? If you know what volume of fluid the battery contains and the volume of the battery compartment, you can estimate the height at which the fluid would have been on the side of the battery had it had a leak.
What if you scrape some residue onto a wire and put a flame under it? Perhaps it would produce the blue flame associated with sulfur but I leave this to the chemists on the forums. You could also try to see if it dissolves in a small amount of water.
      03-18-2013, 01:16 PM   #21
Thik
There was no liquid inside the compartment when they pulled it out. Everything is bone dry. There is no odor whatsoever. If it was water or dirt, it would smell earthy. I took the car to another independent mechanic, he said it was the sulfuric acid that spewed out when the battery started leaking from the inside.
I'm guessing the yellow stuff is sulfur mixed a bit with rusted metal caused by the sulfuric acid? Since much is usually a darker brown that disintegrates with water?
I don't know. How can I test to see what that yellow stuff is for sure? Does the sulfuric acid inside car batteries look like that?
      03-18-2013, 01:51 PM   #22
rantarM3
Drives: E90 M3
You could collect some and send it out to a lab for analysis, or try some home chemistry. Either option is not great. Do you know anyone that works at a university/college and has access to a lab (perhaps equipped with a mass spectrometer)?
m3post
