      03-21-2013, 03:27 PM   #1
FBPARTS
Drives: BUS
Turbosmart and Synapse Bov Kit!!!
Send me a PM for you order.....
Part #: TS-0203-1250
Description: Turbosmart BMW 135i/335i/535i/Z4 w/ N54 Twin Turbo 3.0L Kompact Plumb Back Kit
Turbosmart Blow Off Valves - Kompact Series - Plumb Back: The Kompact Series BOVs have been designed as a bolt-on replacement for plastic factory Bosch or Denso BOVs, the Kompact Series products offer superior flow, full adjustability and greater structural integrity under boost. Ideal for cars with constrained engine bay access like VWs, Audis, Porsches, Seats, SAABs, Mazda MX5 (Miata) and Ford XR-6T. Very popular with motorcycle drag racer.
*DESCRIPTION:* Fully recirculating BOV. The Plumb Back systems vents all excess pressure back into the intake system. Great for enthusiast not wanting to be noticed. (Complies with AUS RTA rules).
*APPLICATION:* Fits most cars using the factory BOSCH or DENSO bypass valves. Available in 20mm and 25mm outlet diameters.
*SUPPLIED WITH:* Pictorial fitting instructions.
Part #: TS-0203-1050
Description: Turbosmart BMW 135i/335i/535i/Z4 w/ N54 Twin Turbo 3.0L Kompact Dual Port Kit
Turbosmart Blow Off Valves - Kompact Series - Dual Port: The Kompact Series BOVs have been designed as a bolt-on replacement for plastic factory Bosch or Denso BOVs, the Kompact Series products offer superior flow, full adjustability and greater structural integrity under boost. Ideal for cars with constrained engine bay access like VWs, Audis, Porsches, Seats, SAABs, Mazda MX5 (Miata) and Ford XR-6T. Very popular with motorcycle drag racer.
*DESCRIPTION:* Hybrid-type BOV. Dual Port vents both to the atmosphere and back into the air intake. Dual ports with sequential timing allow quieter operation during normal driving, while getting all the benefits of a Supersonic BOV under race conditions. Easily converted to a fully atmo or fully bypass unit.
*SUPPLIED WITH:* Pictorial fitting instructions and a blanking plug.
Part# SB001B.KIT001
Synapse BMW 135i & 335i BOV Kit w/ Black Charge Pipe
Part# SB001A.KIT001
Synapse BMW 135i & 335i BOV Kit w/ Polished Pipe
Synchronic BOV package � SB001 is the iconic Synchronic BOV that has set the standard for impossibly fast response from a BOV/DV. Completely modular, it can be installed as a vent-to-atmosphere BOV or re-circulating diverter valve. This universal package can be outfitted to most any application utilizing our interchangeable mounting flange system. By design, it is a pull-type valve only. This means that boost pressure keeps it closed, meaning no boost leaks upwards of 100+ psi of boost. It operates in a normally open condition. This means that it is designed to remain open under vacuum conditions. For maximum performance and reliability, it is recommended to install the Synchronic BOV in a re-circulated configuration with the discharge between the MAF sensor and turbocharger inlet.
Synapse Engineering introduces the new updated version of production kit for the BMW N54 135i/335i engine package. The kit includes all components needed for a bolt-on application. The kit also clears the factory intake airbox.
Updated design elements include the following:
• Zero weld, CNC mandrel-bent, aerospace grade 6061 Aluminum tubing
• Relocated BOV location closer to the throttle body for improved performance and better clearance
• Reduction of Silicone coupler surface area for maximized charge velocity
• Billet CNC machined air temp sensor adapter welded directly onto charge pipe
• T-bolt clamps now included with the kit
• Alternative finishes now available in polished Aluminum and powder coated black
• Engineered mounting bracket reduces vibration for overall assembly.
      03-27-2013, 01:53 PM   #2
FBPARTS
Drives: BUS
good deals....
      03-29-2013, 12:55 PM   #3
FBPARTS
Drives: BUS
good prices....
      04-24-2013, 03:03 PM   #4
FBPARTS
Drives: BUS
great deals.....
      04-26-2013, 12:05 PM   #5
FBPARTS
Drives: BUS
good deals....
      05-03-2013, 10:50 AM   #6
FBPARTS
Drives: BUS
good deals....
      05-09-2013, 10:41 AM   #7
FBPARTS
Drives: BUS
good deals.....
      05-20-2013, 02:27 PM   #8
FBPARTS
Drives: BUS
good deals....
      05-24-2013, 10:35 AM   #9
FBPARTS
Drives: BUS
nice.....
      06-05-2013, 12:46 PM   #10
FBPARTS
Drives: BUS
nice.....
      06-11-2013, 10:38 AM   #11
FBPARTS
Drives: BUS
good deals.....
      06-21-2013, 02:37 PM   #12
FBPARTS
Drives: BUS
good prices.....
      06-25-2013, 12:26 PM   #13
FBPARTS
Drives: BUS
good deals.....
      06-26-2013, 12:29 AM   #14
1SER135
Australia
22
Drives: '08 135i M SPORT 6M
Will the DV's work on an ER charge pipe? What PSI are they rated at, I know the forge DV's come with different springs for different applications, are these the same?
      06-27-2013, 12:38 PM   #15
FBPARTS
Drives: BUS
pm sent.....
      06-27-2013, 07:15 PM   #16
1911A145
1911A145's Avatar
34
Drives: 135i
Part# SB001B.KIT001
Shipped to 34952? Thanks
| COBB E30 | VRSF DP's | ETS 5" FMIC | BMS DCI |
393 RWHP / 434 RWTQ
      07-01-2013, 02:40 PM   #17
FBPARTS
Drives: BUS
ready to ship.....
      07-10-2013, 11:42 AM   #18
FBPARTS
Drives: BUS
ready to ship.....
      07-11-2013, 04:16 PM   #19
fastdrivingjr
Drives: ducati 749
2010 135 . synapse bov kit shipped 30004
      07-12-2013, 02:18 PM   #20
FBPARTS
Drives: BUS
pm sent.....
      07-18-2013, 11:09 AM   #21
FBPARTS
Drives: BUS
ready to ship......
      07-23-2013, 11:54 AM   #22
FBPARTS
Drives: BUS
good deals....
1addicts
