04-02-2013, 06:06 AM | #1 |
Rep 3,071
E93 Clunking sound w/top up over rough pavement
My new to me second E93 makes a clunking sound only with the top up over rough pavement or sewer covers in the road. My 08 never made that much noise. My 1st car had 18 inch wheels and tires, this car has the 19 inch setup. Sounds like it is coming from the left rear window area.
Michael
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/ |
04-02-2013, 09:10 AM | #4 |
Rep 106
I recently started having the same problem.
04-02-2013, 10:48 AM | #6 |
Rep 1,052
Drives: 2022 X3MC; 2012 M3 Cabriolet
(probably) Same thing here. Houston has pavement imported from bombed-out Somalian cattle trails, meaning the roads here are crap. And I hear that clunk-sound frequently. Figure it is just something in the door. Or maybe it's the airbag about to detonate. Anyhow, some day I'll get out the tools and remove panels and try to find out what it is. But after 25,000 miles and 54 weeks, doesn't seem to get any worse or affect anything.
- V .
2022 ///X3M Competition; São Paulo Yellow
2012 ///M3 Cabriolet; Le Mans Blue Metallic. >177k miles and still rocks! |
LuckiSevens227.00 |
04-02-2013, 12:27 PM | #7 |
Rep 232
My 135i convertible did that - turned out that the interior liner, which in that car is a spandex sort of thing with a stretched-taught string tie-down, had a broken clip and it was flopping about. Hop into your rear seat and look around - it may just be something loose from the trim.
LuckiSevens227.00 |
04-02-2013, 05:17 PM | #8 |
Rep 3,071
Thanks will check
04-03-2013, 12:56 PM | #9 |
Rep 128
Same problem here. The "solution" from 2 dealers was to put felt tape on the package divider in the trunk.
Very upsetting to have such horrible rattles in an $80K+ vehicle.
ON ORDER: 2023 G05 X5 ///M50i Carbonschwarz|Tartufo
CURRENT: 2020 F97 ///X3M Competition|Donington Grau|Tartufo RETIRED: 2017 F80 ///M3 | 2014 F10 550i ED 2 June 2014 | 2011.75 E93 ///M3 ED 5 July 2011 | 2009 E90 328i |
04-03-2013, 01:34 PM | #10 |
Enthusiast
194
Rep 1,282
Drives: 2015 F80 M3
Garage List 2011 BMW E93 M3 [0.00]
2004 BMW M3 [9.50] 2015 BMW F80 M3 [0.00] 1997 BMW 840CI [9.50] 2011 BMW X5 M [10.00] 2008 BMW 335i Conve ... [8.40] |
Does this clunk happen only when the top is up and is the clunk coming from the front?
I recently had this issue with my 335i E93. It ended up being the roof latch pins (or something like that) needing adjustment. Easy fix at the dealer. I hope you get it fixed soon. If you are anything like me I hate when my Bimmers make noises they shouldn't Good Luck!
2017 Porsche 718 Boxster Carerra White / Garnet Red / Black
2013 Porsche 991.1 911 Carrera S Platinum Silver Metallic / Black and Yellow accents 2014 F31 328i xDrive Alpine White / Black |
04-03-2013, 02:22 PM | #11 |
Rep 128
Noise comes from the rear in my car. It honestly sounds like pieces of the suspension are broken and rattling around, but such is not the case.
04-03-2013, 06:19 PM | #12 |
Rep 708
Yes, there's a clunk on mine from the roof on the driver's side with the top up, if you hit a bump hard enough. Haven't had any leakage or top problems, so no big.
Cheers
Bye bye E93 M3 - Hello F83 M4! |
04-03-2013, 08:32 PM | #13 |
Rep 3,071
Clunk
Same issue for me.
04-03-2013, 08:56 PM | #14 |
Rep 1,625
My e93 was almost dead silent and rattle free.. then I had leaking seals, which was replaced under warranty and a fried amplifier and speaker.. which took BMW 4 visits to fix.
Now I have a ping/pop noise from the front that happens quite frequently and occasional clunks from the rear. |
04-04-2013, 06:22 AM | #16 |
Rep 3,071
The only reason it is surprising is that my 08 did not have the clunking. Anyone think the 19" wheels harshen the ride thus contribute to this?
04-04-2013, 07:14 AM | #17 |
Rep 58
Had same cluncking and rattles...felt tape everywhere and problem solved! No more cluncking or rattles...
'08 M3 E93 DCT - Individual Diopsidschwarz/Palladium -19" 220 Gunmetal - 12mm H&R spacers - H&R Swaybars - BMC filter - M Performance grills - ECU - Zimmerann Rotors/Brembo Sport Pads |
04-04-2013, 05:22 PM | #18 |
Rep 3,071
I am focusing on the driver's side windows and seals. Will try same paths with windows up and down and see if I see a change.
04-04-2013, 06:47 PM | #19 |
Rep 301
I was thinking about getting an E93
I'm in the market for an M3 and the E93 was high on my list but I was really concerned about clunking noises, rattles and leakage as the car starts to age. I'm glad I read this post. Are there any other problems owners have experienced with the E93?
04-04-2013, 09:49 PM | #20 | |
Rep 1,052
- V .
04-04-2013, 10:22 PM | #21 | |
Rep 708
Cheers
04-05-2013, 06:50 AM | #22 |
Rep 3,071
NJDrive, this is a first world issue. It only clunks over really poor sections of road at high speed. We just had a new semi-highway installed and the numbnuts put a bunch of manholes on the road so poorly that some are really sunk down like shallow potholes. Otherwise she is like butter.
