04-05-2013, 10:08 AM | #2 |
i can haz horsepowr ??
3861
Rep 1,943
I somehow massively doubt that it'll be THAT light. But we can always hope.
Dakar Yellow G80 M3
Ivory White Interior @dakar.g80 #savethemanuals Gone but not forgotten: 991.1 GT3, F80 M3 ZCP, E46 M3 |
04-05-2013, 10:44 AM | #3 |
Rep 63
One can only hope.
But for the first time there will be a different internal code between the M and the standard 3-series platform, (f80 vs f30). Lets hope this means that the structures are so different from each other that there will be room for massive weight savings. Why would they else use different codes?? Once again, one can only hope... |
04-05-2013, 12:18 PM | #4 |
Rep 426
I don't see why not since the current e9x is actually 3550 as weighed by many owners indepedantly through the years. The e46 was 3450 which is much higher than most actually know. So to shave 200 pounds is not super easy, its also not really that difficult for a manufacterer with access to change the sound material, body panels, suspension component materials/subframe material etc
I expect it to weigh 3400 to be honest which with 420 "rated" and more likely 450 true hp as they always underrate engines |
04-05-2013, 04:01 PM | #5 | |
Rep 203
Lets stop spreading bad data
If it achieves 3300 lb curb weight, this car will break some hearts and egos with that powerband.
OT and a but needs to be said. Quote:
Here is real data: My car came off the factory floor one of the fattest M3 coupes (I called her Miss Piggy back then) you can order and even with additional stereo components STILL did not achieve the weight you claim. With almost a full tank of gas, sunroof, SMG, PDC, OEM 19" boat anchors, nav and a 12" speaker box + 5 channel amp (+65 lbs) topped out at 3410. ZERO weight reduction - tool box and M mobility kit still in the trunk. I was trying to get it as FAT as possible for my initial weigh in before I put her on a diet. This weight from the Long-Acre scales (http://www.longacreracing.com/catalo...p?id=1&catid=1 ) was verified by the CCA at several Auto-X events that first year on their scales as well. Just for reference, non-sunroof 6MT car is right at or below 3300 stock on the same scales. Sunroof (+45), SMG (+15) and NAV (+10) do not add 150 pounds to the 46M's weight. I have removed those components from my car and weighed them and the car afterwards. Miss piggy today sits at 3290 lbs with the full interior, the same stereo and 1/2 tank of gas.
Naturally Agitated - S54B34 CSL Clone - 395 285 SAE on 91 pump - 3150 lbs - P car and E9X eater.
04-05-2013, 05:47 PM | #6 |
Rep 591
Drives: 05 M3, 00 Z3MC, Boxster Spyder
Official BMW Weights
Official BMW Weights:
(with a few official Audi and Porsche weights thrown in for comparison) DIN curb weight (preliminary as they call it): E30 M3 at 1,225 kg = 2,701 lbs Z3MC (S52) 1,345 kg = 2,967 lbs 997.2 GT3RS 1370 kg = 3,020 lbs E36 M3 at 1,385 kg = 3,053 lbs Z4M Coupe 1390 kg = 3,066 lbs 997.2 GT3 1395 kg = 3,075 lbs TT-RS at 1,450 kg = 3197 lbs E46 M3 at 1,474 kg = 3,250 lbs E82 1M at 1,495 kg = 3,296 lbs R8 V8 at 1560 kg = 3,440 lbs E92 M3 at 1,605 kg = 3,538 lbs R8 V10 at 1695 kg = 3,571 lbs EU standard weight: E30 M3 at 1,300 kg = 2,865 lbs Z3MC (S52) 1,420 kg = 3121 lbs 997.2 GT3RS 1445 kg = 3,186 lbs E36 M3 at 1,460 kg = 3,219 lbs Z4M Coupe 1,465 kg = 3,230 lbs 997.2 GT3 1470 kg = 3,241 lbs TT-RS at 1,525 kg = 3,362 lbs E46 M3 at 1,549 kg = 3,415 lbs E82 1M at 1,570 kg = 3,461 lbs R8 V8 at 1635 kg = 3,604 lbs E92 M3 at 1,680 kg = 3,704 lbs R8 V10 at 1695 kg = 3,737 lbs EU is DIN + 68kg driver and 7kg luggage. |
04-05-2013, 07:40 PM | #7 | |
Rep 203
Great comparison info!
04-06-2013, 04:59 AM | #8 |
Rep 9,708
I see in the attached article, they mention CCB in the mix to get to this weight. No doubt CCB will be an expensive option to save the weight. Standard steel braked cars will weigh +30-40lbs
04-06-2013, 07:41 AM | #9 |
Rep 63
On a M5 it saves 42,8lb, probably a little less on a M3, since the rotors and calipers will be smaller in the first place, (6 piston front cal. on M5, probably 4piston on m3)
04-06-2013, 07:54 AM | #10 |
Rep 203
Interesting. What does the CCB option cost on the M5? Is that the $6500 "performance upgrade" listed on the build site?
04-08-2013, 01:16 AM | #11 | |
Rep 83
Drives: E39 530i Sport Individual
http://www.f30post.com/goodiesforyou...3/BMW-M4-j.jpg http://www.f30post.com/goodiesforyou...3/BMW-M4-g.jpg They are definitely 6 piston front calipers on the front and the rears look to be 4 piston, not those single piston sliders like on the M5/M6 CCB option...
"Smoke me a kipper,
I'll be back for breakfast." |
04-08-2013, 04:11 AM | #12 | |
Rep 63
But I was talking about the standard steel brakes, those will probably be 4 piston fixed alu cal. at the front and 2 piston fixed at the rear on the new m3/4. In other words, smaller and lighter then the standars on m5. Point is that the difference between CCB and steel will be slightly less on M3/4 than it is on M5. I`m also happy that M gmbh are finally ditching those sliding cals. |
04-08-2013, 02:46 PM | #13 | |
Rep 203
I may be in the minority when I say this, but I could care less how much more power this new M has over the S65 variant (415, 430, 455 blah) ... as all M cars make more power than their predecessor. I won't consider ordering one until the sedan is independently weighed. Anything south of #3400 and I may tell my son he can pay for his own undergraduate and graduate school like his dad did! Crank HP won't impact that decision, sadly. I must be getting old...
04-08-2013, 02:47 PM | #14 |
Rep 9,708
04-08-2013, 02:53 PM | #15 | |
Rep 9,708
The M5/M6 CCB's use the exact same calipers as the stock versions, just different pads and discs, and down rated booster. I hope M3 goes the same way |
04-08-2013, 03:08 PM | #16 |
///M at Heart
90
Rep 1,954
very highly doubt it.
Its larger than the outgoing E92. E92 335's are around what 3700 lbs on a good day? edit: just saw the weight comparo's. I don't think it'll be under 3500 for sure. |
04-08-2013, 03:10 PM | #17 |
Rep 9,708
04-09-2013, 02:00 PM | #20 |
4 Star General -Twilight Zone
36
Rep 1,032
The current V8 S65 is already lighter than the previous gen. E46 M3 I6....
But I'm sure they will reduce weight where they can. Target = 300 lbs. less than current E9x
'12 Ducati Diavel
'06 E46 M3 (sold) | '97 325is - Dinan (sold) '02 Z3 3.0 coupe (sold) Past - '84 Ferrari 308 GTSI | '88 Ferrari 328 GTS | '05 Dodge Viper Copperhead Edition #180/300 | Audi S4 |
04-09-2013, 02:51 PM | #21 |
Rep 63
No wonder, S54 block was made of cast iron, with the S65 they moved to alu-block, that helps on the weight...
05-20-2013, 06:59 PM | #22 |
Rep 455
Turbos, piping, intercooler etc ads a ton of weight that would offset any differences from losing 2 cyl and some displacement. I seriously doubt it will be 3400 wet regardless.
