04-07-2013, 07:41 PM | #1 |
Rep 6,285
What coilovers are you guys using?
I'm going to be putting in a full M3 rear end (EDC) and front hubs brakes etc in my 335i soon, and am looking at coilover options for the M3. The used rear end I have purchased doesnt come with springs or shocks, so rather then spend $ replacing these with used or new shocks i thought i would be best to go for a new coilover setup.
http://www.e90post.com/forums/showth...736865&page=16 My car will be predominantly a road car and I do envision to do a few driver ed type track days and a few runs down the strip, but ultimately I think I'm after a setup that is firmer then the existing oem suspension but still retains a oem like ride Ultimately I would go for the ohlins R&T dampers, but doing the m3 conversion is going to cost me enough as is in labour and parts, so I'm think of going for a compromise such as BC BR coilovers or a cheaper offering such as the bilstein B16 (over $1k cheaper then the ohlins) entry level JRZ's etc So what coilover setup are you running, and how have you found the ride handling and reliability after sales service of your setup? |
04-08-2013, 08:59 PM | #2 |
Rep 2,224
Most of us have EDC, so run H&R springs.
The only coilover setups I've seen used are KW's, but they were dedicated track cars. If you're not living at the track, an OEM style spring and damper setup would probably do the job and be easier to install, especially if you want to use the EDC. Or you could just buy an M3 |
04-08-2013, 11:32 PM | #3 | |
Rep 2,665
Drives: Goggomobil
You will never be able to replicate the handling and balance of an /// car by just replacing the suspension. There is a lot more happening in an ///3. 80% of an ///3 is ///specific. Also keep in mind the series coupe sits lower than an ///3 due to its suspension setup. So replacing the stock suspension with ones from ///3 may adversely affect the handling, unless you know what you're doing. I am not a suspension expert but surely someone from SouthernBMW or other vendors can chip in with that expert opinion. Good luck with your project.
F86 X6///
04-09-2013, 05:45 AM | #4 |
Rep 513
KW's seem to be pretty popular.
I had them on my 135i and was really impressed, have the KW Sleeve over kit on the M3 and very happy too
2011 BMW M3 - Mineral White - VF620 Supercharger - Gintani Sport Valved Exhaust - Harrop BBK - Arykym Front lip and Diffuser - KW Sleeve over kit - Forgestar CF5V Wheels 2009 BMW 135i - Space Grey - 11.841 @ 117.81mph - SOLD |
04-09-2013, 06:34 AM | #5 | |
Rep 6,285
As you may or may be aware the 335I runs an open diff and a lsd diff centre is a must do mod for some track work, and then due to the increased torque of a modded N54 the rear ends start squirming around due to the soft bushings, so the N54 guys spend a lot of $ installing M3 bushings links etc to firm the rear up and adding a lsd diff centre to the 335i diff. By replacing the entire suspension with a M3 setup, you can save costs somewhat but you end up with much beefier driveshafts and diff combo along with better brakes. Yes you're correct the ride height is higher in the /// also, which is another reason why I'm seeking feedback from you guys in what coilovers work, as for me it would be costly to buy two rear shocks and springs which im missing then end up having to buy lowering springs/kw sleeve kit $1K+ to get to the desired ride height. Therefore I figured I will either go for the eibach/bilstein prokit combo or go for an entry level coilover kit such as the h&r street http://www.turnermotorsport.com/p-21...uspension.aspx BC BR's http://bc-racing.com.au/br-type-coil...es-e92-en.html or go midrange for the bilstein B18's $2k (I can get them cheaper then turners price) http://www.turnermotorsport.com/p-13...uspension.aspx and then in 12 months time pony up and go for the ohlins R&T's $3.5K. http://www.prospeedracing.com.au/pro...it-BMW-M3.html At this stage I'm thinking of going with the bilstein B18's, as the price of these are quite good (the KW V3's are closer to $3K) but the installation costs for the setup will be quite high, and im sure there will be a few unexpected costs involved also which always occurs with a mod such as this! Last edited by DR-JEKL; 04-09-2013 at 06:49 AM.. |
04-09-2013, 06:41 AM | #6 | |
Rep 6,285
Unfortunately I'm missing the edc rear shocks and springs, so the KW sleeve kit isnt really a cost effective option for me (unless I could get rear oem shocks for cheap) but I can understand why you would have gone for them being a newish car with low kays and a more effective option then lowering springs. |
04-09-2013, 08:14 AM | #7 | |
Rep 2,665
Drives: Goggomobil
F86 X6///
04-09-2013, 06:55 PM | #8 |
Rep 2,224
The Bilstein and H&R would both be good kits. H&R is a good brand and competitively priced.
I used to run 19psi on a 335 back in '08 and agree the biggest problem was putting the power down. Even with fat tyres, the rear end would just squirrel around in gears 1-3, but that was mostly because it lacked LSD. Sounds like a good project |
04-10-2013, 04:27 AM | #9 |
Rep 693
HI MFKN3
Was that your car at Mikes the other week getting the supercharger fitted as mine was getting the suspension fitted the next day.
THE BEAST MHD Flash Tune /M3 suspension/Forge Intercooler/Alpina B3 AT Flash/Bilstein B4 Suspension/BMW OEM M3 Steering Wheel and DCT Paddles/LUX V4 Angel Eyes/CIC Retrofitted
04-10-2013, 05:46 PM | #10 |
Rep 2,224
