07-17-2013, 08:45 AM | #1 |
Rep 690
Carbon Fiber Hood Install
So after searching countless forums and topics I decided to make one of my own. I have gotten different answers from members and manufacturer's themselves. I just got a VIS GTR style hood and am awaiting shipping. I want to know from those who have any kind of CF hood, what kind of struts/hood shocks they use. I've read people use none, some use one, and some go out and buy the M3 hood shocks, because their aluminum hood is lighter and more closely resembles the CF hood, in terms of weight. I heard if precautions are not taken then the hood can be warped from the OEM struts. Please give me some input, thanks.
07-17-2013, 09:07 AM | #2 | |
Rep 919
07-17-2013, 09:11 AM | #3 |
Rep 690
yes I more than likely will use one, this is what a worker from VIS themselves said:
" I usually recommend using no struts at all, and just a hood prop. I am not totally sure if the hood struts on an M3 are any lighter, but there are some half/low pressure shocks out there that claim that they are for composite hoods." I responded: "So that would entail, just using the front hood latch/release?" Then him: "Yes, unless a company can confirm that their shocks can be used with carbon hoods without warping them. Or if you personally know a guy on the forum or something, that has used the M3 shocks successfully with our hood. I just want to make sure that you maintain a part and are happy with it." They seem to be a good company with a lot of knowledge, but I was hoping for a more definite answer from these guys since they do specialize in CF materials. |
07-17-2013, 12:03 PM | #4 |
Rep 919
VIS sells products across many different product lines. CF hoods on some vehicles don't use any struts. Others require hood pins. It really is across the board with the items they sell. I can understand why they can't give you a definitive answer, both in a practical and a legal sense.
Many suppliers for Seibon parts for the e82 suggest complete strut removal. I think you'll be able to get away with one strut fine as many people have done this in the past, but be very careful with flex and keep an eye on the strut mount to make sure there isn't any wear and tear. |
07-17-2013, 12:06 PM | #5 |
Rep 690
ok will do, I got some good advice from jetblack on the forum and he has the same exact hood and recommended to use one strut, so I will more than likely go that route. Don't really want to invest in $40 per M3 strut.
07-17-2013, 12:30 PM | #6 |
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
I used no shocks on my Vorsteiner Hood and use two M3 struts on my Revozport hood.
The m3 shocks are very low pressure due to the m3 having an aluminum hood and feel perfect on my Revozport hood. I would only use two M3 shocks or none. Do not use 1x stock e82 shock as you will put excess pressure on one side and can bend your hood over time when you close it. One thing I do strongly recommend is you get Aero Catches or another form of Hood pins for your CF hood. |
07-17-2013, 12:32 PM | #7 |
Rep 690
that's another thing i was interested in was the pins, some say for looks others say it only helps when driving in excess of 150. Btw do you have a part # on the shocks, I believe these are the ones people are referring to? I would just hate to drill into the hood if I really don't have to, or if I am not going to be racing at ridiculous speeds.
http://www.bmwpartsupply.com/OEMPart...237900795.html |
07-17-2013, 01:09 PM | #9 |
Rep 690
ok thanks, nice diagram! so even with the struts, you recommend hood pins? seems like it should be one or the other.
07-17-2013, 02:19 PM | #10 |
teh porcupine
98
Rep 1,726
Drives: 2020 Tesla 3 LR AWD
Hood pins and struts if you want to do the job right.
07-17-2013, 07:32 PM | #11 |
Rep 171
Just had yesterday installed a seibon hood... The installer used all the original parts, I bought aerocatch ( did not used them) .. Haven't yet past 100mph but the hood has not even moved.. You got to be careful when closing. Press it evenly and gently.. If you want I could send you pictures to your email( don't know how to post it from phone)
07-17-2013, 07:35 PM | #12 |
Rep 690
yea that'd be nice, can send to djintelligence3000@yahoo.com
07-17-2013, 08:41 PM | #13 | |
Rep 690
07-17-2013, 09:43 PM | #14 | |
Rep 4,744
07-18-2013, 09:38 AM | #15 |
The Crowing
111
Rep 2,005
I installed the seibon hood in my garage. Had my wife help me hold it in place cause its awkward to carry. Not sure why hood pins would be needed. I've been above 130-140 with it and no lifting or anything. Both latches transferred over from OEM hood an the rubber grommets transferred as well. Bought the hood used and it looks like on strut was used before and it is slightly warped. I use the rubber grommets up front to correct that when its closed. I have both struts OEM struts on. I have to push down on the roundel after I latch it a little to get it to close. I adjusted it like that because the grommets push up against it.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback |
07-18-2013, 09:49 AM | #16 |
Rep 690
yea i'll be having my wife help me as well since i don't want to drop the hood, even though i know it's not too heavy, it's the width and grip that might kill me.
07-18-2013, 10:03 AM | #17 |
The Crowing
111
Rep 2,005
Yeah it's very awkward I started to try it but then smartened up a bit I got some help for maybe 30 seconds. Although the next mornin I opened the garage door with the hood up and scratched it pretty good. Idiot! Still hate myself for that. Hahaha.
07-21-2013, 01:39 PM | #20 | |
Rep 928
OEM struts can also lead to inadvertent wear that won't be noticeable until after an extended amount of time. Based on the ratio of weight to the ft/lbs of pressure to close the hood, the struts add dampening and require more force than is necessary to properly close the hood without stress. Alot of this may seem minimal, but it also coincides with how often you are under the hood. If all you are doing is changing oil or belts, I wouldn't fret. But for those who are using the hood for a reliable amount of weight reduction and will be under the hood often, its better to retain that integrity rather than destroy it. |
07-19-2018, 11:06 AM | #22 | |
Rep 3
Any help is appreciated. Thanks. |
