07-31-2013, 03:15 AM | #3 |
Rep 287
Performance Friction Direct Drive Rotors:
http://www.m3post.com/forums/showthread.php?t=818535 Front only. I've found some cool looking rear floating rotors from REBS in Korea. Will pass on the pricing when I find out. http://zenondt.com/bbs/zboard.php?id...esc=asc&no=167
Drives: 2010 E70 X5M Carbonschwarz Loved and lost: 07 E92 M3 Silverstone II / 96 E36 M3 Evo Estoril Blue / 07 E84 Z4 M Coupe Interlagos Blue |
08-01-2013, 12:54 AM | #4 |
Rep 287
And Race Brakes too:
http://www.racingbrake.com/Two-piece...-M3-p/2161.htm http://www.racingbrake.com/Two-piece...-M3-p/2162.htm
08-05-2013, 08:46 AM | #7 | |
Mr. Nice Says Hello
637
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
08-05-2013, 09:41 AM | #8 |
Rep 12,316
This is what I'd go for (due to good feedback from other platform):
http://www.m3post.com/forums/showthread.php?t=860667 Need more interest from people though.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
08-06-2013, 09:47 AM | #9 | |
Rep 287
$900 for the rear floating disc kit $5000 for the M5 kit
08-06-2013, 10:00 AM | #10 |
Rep 3,996
I found these prices to be pretty good for OEM rotors. http://www.rmeuropean.com/Part-Numbe..._6BB4EABD.aspx
08-14-2013, 01:57 AM | #11 | |
Supreme Allied Commander
3888
Rep 54,538
Drives: F80 M3
Our vote goes to the Performance Friction Direct Drive Rotors!
PFC DD rotor discussion: http://www.m3post.com/forums/showthr...mance+friction Quote:
08-15-2013, 12:36 PM | #12 | |
Rep 3,980
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
08-15-2013, 11:20 PM | #13 |
Ninja
390
Rep 4,014
thoughts on stoptech rotors?
http://shop.acuteperformance.com/sto...d/g-55256.aspx anyone with experience with these?
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i |
08-16-2013, 06:36 PM | #15 | |
Rep 1,463
@ the OP. The OEM rotors are solid. You can pair them up with more agressive pads at the expense of rotor life, of course |
10-09-2013, 07:12 PM | #16 |
Rep 19
10-10-2013, 03:52 PM | #17 |
3888
Rep 54,538
Drives: F80 M3
RB rotors are a good upgrade for a street car, but they have not fair well on the track. If 2-piece rotors are a must-have, the PFC DD 2-piece is a much better choice.
10-16-2013, 06:38 AM | #19 |
Rep 10,676
When you write "better than stock," what are your expectations? These are just lumps of metal that absorb heat. The stock ones do a very good job. The quality aftermarket stock replacements will also do a very good job. Low quality aftermarket replacements may warp, crack, or fill their vents with rust faster. Expensive aftermarket upgrade rotors may weigh slightly less if two-piece and/or vent slightly better, but I am not sure even a race car driver could tell the very slight difference. For some two-piece, there may not even be any long term cost savings since replacement rotor rings are proprietary and possibly as expensive as new stock or aftermarket stock rotors.
If you have a problem you are trying to fix, the it is worthwhile looking for a solution. For example, maybe you are warping stock rotors regularly on the track. I noticed the OP's other thread on lightweight batteries. If paying big bucks to save a few pounds is important, go for two piece rotors. You should drop a couple of pounds per rotor. This is unsprung weight, so savings here are worth several times that elsewhere. You could probably also save some weight with a full aftermarket brake kit that replaces the massive cast iron single piston sliding calipers we have. Just don't go much bigger on the rotor or you will offset the loss. Lightweight wheels are also great, and some tires are lighter for the same size than others. |
10-16-2013, 09:06 AM | #20 | |
Rep 12,316
I did the mistake of driving a new 911 in the mountains.
Current:
10-17-2013, 03:02 PM | #21 | |
Dingleberries
76
Rep 1,246
BBK is more for heat management... |
10-20-2013, 03:15 PM | #22 |
Rep 10,676
For the most initial bite, I'd stick with stock brake pads. Bite is really in the pad material. Most performance pads shift the temperature range up, so they trade initial bite for more fade resistance under temperature when worked hard.
I don't think big brakes stop any better in daily driving on the street. Their advantages start to show up when their better heat dissipation comes into play, which is when they are hot, like during repeated high speed stops. Unless you drive at high speeds on deserted canyon or mountain roads, you probably won't experience fade unless on the track. |
bbnks21211.00 |
