07-28-2013, 10:50 PM | #1 |
Rep 194
Drives: 2024 X3 M40i, AW
0-60 (normal,sport sport+)
Hey folks:
I was wondering if there was a big difference between the 3 modes during the 0-60 run or essentially if you press the throttle fully it won't matter? Are all the test spec runs done in the sport+ mode by magazines etc? Thanks) |
07-29-2013, 12:57 AM | #3 |
Rep 1,140
Drives: Something something racecar
Actually, I think you'd be faster in Sport+ because of the reduced pedal travel to get to WOT. No?
07-29-2013, 04:54 AM | #5 |
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
No.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
07-29-2013, 05:31 AM | #6 |
Rep 1,140
07-29-2013, 05:53 AM | #7 |
Rep 126
I am pretty sure you would reach a certain speed faster in the sport+ mode vs. the normal mode. It is true that the "max" power output from the engine is the same in any mode, but how it gets there is different-- aka you'll reach max power quicker in sport+ mode vs normal mode. What I am unsure of, however, is if you absolutely floor the car whether that difference is negligible or not.
07-29-2013, 08:08 AM | #8 |
Studying...
36
Rep 860
When in doubt on this subject, take it from Jeremy Clarkson: "BMW have fitted it with a little button that when you press it, makes absolutely no difference in the speed you go, but it does make it worse (EDC being uncomfortable)"
07-29-2013, 08:50 AM | #10 |
Rep 194
Thanks for replies folks- that's what I figured
I think the only real difference would be the track setup where some people would prefer a more sensitive throttle for rev-matching vs the normal mode and a casual throttle application without going all the way. Additionally some people claim that m mode makes you go faster, but the m-mode is just a collection of settings. Theoretically if you have power sport+ vs normal in m mode it won't make a difference. That leaves us only with the sport setting for EDC, which might have a slight effect on the 0-60 time due to less car body sway on a stiffer setting when shifting, however even then I would have my doubts about it being faster. |
07-29-2013, 09:23 AM | #11 | |
Rep 2,000
Bruce |
07-29-2013, 09:26 AM | #12 | |
Dingleberries
76
Rep 1,246
OP..in real world though on the M3, you won't notice a difference. |
07-29-2013, 09:48 AM | #13 |
Rep 4,381
07-29-2013, 10:00 AM | #14 |
Rep 2,400
Remember a Eurotuner article a while back that tested the M button (sport+) over several runs and there was modestly more torque and hp produced in the low rpm range, but HP and TQ were exactly the same as without the M button after 3,500-4,000 rpm IIRC. Also, believe R&T used to give launching pointers on what gave the best 0-60 times & 1/4 mile for the M3, and their fastest time was acheived with Sport + button. Not sure why that would be the case, either way, difference if any is miniscule at best assuming perfect launches (pretty difficult to acheive in their own right).
07-29-2013, 10:07 AM | #15 | |
Rep 194
Funky, is there such a thing as a difference between MDM and M mode- isn't it the same thing)? |
07-29-2013, 10:34 AM | #16 | |
Rep 4,381
In MDM you are allowed (amongst other things) more wheelspin before the traction control cuts in. In normal (non MDM) mode the system will cut back the engine power any time it senses the onset of wheelspin which will quite often slow your WOT acceleration in 1st and 2nd gear. |
07-29-2013, 10:36 AM | #17 |
Rep 194
Gotcha - thanks)
07-29-2013, 10:07 PM | #18 | |
Rep 7,298
07-29-2013, 10:17 PM | #19 |
Rep 8,496
it's easier for me, I have some mental block about doing it properly on normal.
07-29-2013, 10:20 PM | #20 |
Bad Lieutenant
233
Rep 3,517
Sport feels like most cars I've driven, and I'd always wanted a pure linear throttle, like Normal, I'm glad BMW left it alone and added the 2 other worthless options.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
07-29-2013, 11:18 PM | #21 | |
Rep 361
07-30-2013, 10:07 AM | #22 |
Rep 4,488
^ Normal feels "soft" to me on the road too, but that's because you tend to drive in lower RPMs there, but Normal is PERFECT on the track where precision and linearity are the name of the game and where you're constantly running high RPMs. Yes rev matching in Normal requires a little adaptation, but honestly your entire driving style changes on the track, so it's not very difficult to adjust that as well.
I therefore use Normal on the track and on spirited hill country drives and keep Sport for lazy casual driving where a twitchier throttle makes the car feel faster and the decreased precision is a non-issue.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
