07-30-2013, 03:32 PM | #1 |
Rep 333
135 mph steering wheel vibration
Finally got a chance to wring her out on a nicely empty portion of the interstate. This car just seems to get more planted as the speed builds. Smooth as silk through the wheel, arrow straight and rock solid... to 135 mph. Then, and all of a sudden, the steering wheel started kicking back a nasty vibration. Very pronounced, like an unbalanced front tire or a suspension part fail. Front tires are at 75%, rears probably under 45%. OEM fitment Conti Sport Contact 3's on 220's. All bone stock from the original build sheet. But again, to 135 the car was silk. Any ideas?
07-30-2013, 03:36 PM | #2 |
Rep 2,352
Drives: 16' BMW i8
Garage List 2001 BMW M3 E46 CON ... [9.50]
2016 BMW i8 [10.00] 2003 JEEP GRAND CHE ... [0.00] 2000 540i SPORT E39 [10.00] 2007 TOYOTA TACOMA ... [0.00] |
Wheel Weights?
07-30-2013, 03:41 PM | #3 |
Rep 8,496
wheel weights likely, also check air pressure.
I've never taken my car north of 110 mph, but I would also consider the quality of the road you were on too...a lot of small minute imperfections are more pronouced as your speed increases. And we don't really live in a country with glass smooth roads. With some of those magazine tests for max speed (Top Gear, perhaps Road & Track & others), the manufacturers send in a technical expert to ensure the car is prepped properly to go anywhere north of 150 mph. they check air pressure, wheel bolt torque, etc etc..just so the reviewers don't incorrectly attibute a maintenance/setup issue as the actual car's deficiency, which can be damaging if reviewed and written to their subscribers or viewers. Last edited by mdosu; 07-30-2013 at 03:47 PM.. |
07-30-2013, 03:50 PM | #4 |
Rep 1,470
i have been to 140 per the speedo (AiM Solo DL said 132) with no vibration problems like that. check wheel balance.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
07-30-2013, 05:30 PM | #5 |
Rep 333
Some good places to start, thanks. Car's cooled off now I will ck the tires- TPMS never signaled, though. If it's a balance issue, wouldn't it start to vibe out before 135? I mean it was like a switch was flipped....
07-30-2013, 07:19 PM | #6 | |
Bad Lieutenant
233
Rep 3,517
I'm curious to know the cause.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
07-30-2013, 07:38 PM | #8 |
Rep 333
Both right side tires were 1/2 pound less than driver's side. And yes, speeds over 100 mph have a higher recommended pressure in the manual. I did not have my tires to that poundage as I hadn't planned for this little run, but there it was, a wide open highway just begging for WOT so I let'er eat! I will inflate to those autobahn pressures and try it again. Ah, hell, you can bet the road will be one big knot of Priuses, minivans and semis this time
As a matter of fact, I did steal it
07-30-2013, 07:48 PM | #9 |
Rep 333
That's the thing, it was stable, smooth and on rails until it hit 135 or thereabouts. I only glanced down for an instant when the vibration started and it was just under 140 somewhere. The was absolutely NO untoward harshness, vibration or shimmy, etc, before that speed was reached. The steerring wheel was actually calm. In fact the car is so stable and laser like at speed that I am now hesitating doing a wheel mod, spacers, etc. The 220's are growing on me because the stability is so right. Just need to get some new tires, for certain. Compared to my previous (Porsche) experiences, this car instills a lot more confidence at speed, at least in the straights. 911s and even the mid-engine Boxsters, from my experiences anyway, have a tendency to get front end light at high speed and it takes some getting used to.
07-30-2013, 07:59 PM | #10 |
Rep 3,341
All of my vibration issues were noticeable to me around 80 mph. All of my vibration issues were fixed with another wheel balance. It could be a little funky tread wear on your tires that are the issue at that speed...just guessing. I'll bet a new set of tires with a road force balance would do the trick. Yes, 220's are awesome!
07-30-2013, 09:43 PM | #12 |
Rep 1,470
Stop at 134.
07-31-2013, 08:20 AM | #14 | |
Rep 688
07-31-2013, 10:34 AM | #15 | |
Rep 333
Yes it was, and DSC was still engaged.
07-31-2013, 01:45 PM | #17 |
Rep 20,742
Drives: 2021 911 turbo
Most likely tire/wheel balancing. Vibrations is a very complex topic. Different excitation can yield to different hamonics and vibrations depending on speed. Further, the faster you spin, the stronger the excitation forces.
It clould also be a bent wheel. The deformation is small enough that you don't feel it at lower speeds, but as the speeds increase... With my street tires, the car is silky smooth all the way to top speed (my car is delimited). With my track wheels, wich ar impossible to keep balanced (high wear rate and rubber pick-up), the whole dash starts to shake like hell upwards of 120mph due to the vibrations. |
07-31-2013, 03:19 PM | #18 |
Rep 869
Ever plugged one of the tires or had to use the fix-a-flat foam sealer do thingy? It is actually a liquid of not inconsequential volume, that will roll around in the tire and exaggerate the vibrations at high speed.
(ask me how I know)
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20 |
07-31-2013, 04:33 PM | #19 |
Rep 682
Yeah, be careful man...you might have just dodged a yardsale.
I don't wanna be reading a "I just crashed my M3 in Wisconsin" thread soon. Take it to the track.
07-31-2013, 04:36 PM | #20 |
Rep 3,574
check wheel weights. also leave edc in sport not sport+ for top speed runs.
2015 Porsche 991.1 GT3 2015 F80 M3 -- Individual; Space Grey |
07-31-2013, 05:39 PM | #21 |
Rep 333
I purchased this car in June and had the dealer remove the tires for rebalancing and to clean the wheels inside out. Dealer inspected and declared all four were good to go save the wear, which not incidently was very even, no cupping or incline wear because of the camber. I didn't care what he said, because before he prepped the car for me, the same was done for brake inspection during the PPI by the shop that did all the post warranty stuff on my Porsches and 330i. Top shelf guy, and he said everything was good to go. No plugs, bubbles, etc. So this is an interesting mystery. I was going to run these tires through spring then get new so I wouldn't have to store through winter on the new shoes, but now I think I'll run some RE11 or PS2 in OEM fitment to see if that solves it. Also will have the installer check all the rims for straightness. Thanks Fellas for the insights. And the fatherly advice! Even though I am probably older'n all of ya !
07-31-2013, 06:39 PM | #22 |
Rep 4,318
Did you by chance have 1100 lbs of wood flooring in the trunk?
GT3 RS | Desperately seeking the next great M car...
