08-09-2013, 09:09 AM | #1 |
Perception is King
131
Rep 1,703
How do you get your car on Jackstands?
Yes im for real,lol These M's arent ez like a car with a solid axle. Im talkn about if you need to Take ALL four wheels off with no spares to put on, I mean i know theres Jack Pads but im just confused about how you can jack it up from the jack pads Then get Jackstands onto the Jackpads?lol
Perception and Reality are Two totally different Things.
08-09-2013, 09:20 AM | #2 |
Rep 954
The short answer is you jack from the center jack points (there are 2, one front one rear). But it can be a challenge if you don't have a pretty long low profile jack.
For my E46 I use an AC Hydraulics jack and drive the car onto a 2x8 boards to be able to easily reach the front. For the rear I will sometimes jack a corners, put 2x8 boards then jack from the point ahead of the diff (NEVER the diff itself). The best option is flat top jacks with jack pads at the 4 jack points, but you can use regular axle stand jacks at the 4 jack points as well. It's plenty stable. |
08-09-2013, 09:57 AM | #3 |
Mr. Nice Says Hello
637
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
its such a pain the ass for me lol.. i drive up some ramps I made with wood, jack up the front with the jack point (behind the oil drain plug) and then go to the rear and jack from the diff. My race jack barely clears sometimes lol
08-09-2013, 10:09 AM | #4 | |
Rep 154
Front on ramps, jack under one of the rear side jack points, lift enough to get my other jack under the subframe, jack rear, put rear on stands, jack front, put front on stands.
08-09-2013, 10:16 AM | #5 |
Rep 303
I've been wondering about this. Thus far I've only used my floor jack to lift at the side jack points to change tires one at a time. By the sounds of it, there are official front and rear jack points. I used to rear lift my RX7 using the diff. Does this work for the E92 too?
08-09-2013, 10:31 AM | #6 |
Rep 4,318
GT3 RS | Desperately seeking the next great M car...
08-09-2013, 02:54 PM | #9 |
Rep 203
The differential will work if you center the load on the case and use a firm jackpad in between. If you rush or don't pay attention the load can shift as you drop it on the stands or load one side of the diff case more than the other. Either case has the potential to damage the diff or axial bushings.
Pay attention and work slowly.
Naturally Agitated - S54B34 CSL Clone - 395 285 SAE on 91 pump - 3150 lbs - P car and E9X eater.
08-09-2013, 03:04 PM | #10 |
Rep 4,167
Not sure if serious..
Audi R8 v10 Ford Raptor m3e46freak@yahoo.comfor all euro parts!! ebay/craigslist verified/ m3post/e46fanantics/m3forum/zpost/bimmerforum |
08-09-2013, 03:36 PM | #11 |
Rep 5,874
For the front, I use ramps to get clearance then use the center jack point. For the rear I've jacked up via the black forward portion of the diff (NOT the aluminum cooling section) and then lowered onto jack stands without issue. There were no weird groans or movements. I would not recommend this as supposedly it's a bad idea but no problems for me. The biggest issue is that you have to have a high height jack to get enough clearance for the stands under the pads.
08-09-2013, 05:12 PM | #12 |
Rep 8,083
i would advise to follow instructions from somewhere on how to do this. Take no advice from ANYONE on a forum on how to do this. I know there alot of people on here who are knowledgeable on mechanics, but just be careful. One mistake with a car in the air..........
08-10-2013, 01:41 PM | #13 |
Rep 303
Since my car is only a year old, I haven't checked out whether there is a shop manual for it. I assume there is and it should have a page or two on how to lift the car. Does anyone have a shop manual and can share this info?
From my experience, if diffs haven't been specifically designed as a lift point, I wouldn't use it as one. |
08-10-2013, 01:58 PM | #14 | |
Rep 423
2011 M3 Sedan
2001 M Coupe 2020 Macan Turbo 2018 GT3 |
08-10-2013, 02:26 PM | #15 |
Rep 12,736
i wouldn't jack on the rear diff, the aluminum won't support the weight of the car. i'd say it might hold up once or twice, but its quite a gamble whether or not it would collapse or crack.
Instagram; @roastbeefmike
08-10-2013, 03:38 PM | #16 |
Rep 423
It is not the rear diff, the jack point is actually the mount which is a solid piece of metal. It is just behind the differential. Same spot for my m coupe and othe bmw's.
2011 M3 Sedan
08-10-2013, 07:23 PM | #17 |
Rep 1,789
I want to get these, but rather pricey especially since I don't jack the car up all that often.
http://www.jackpointjackstands.com/ |
08-10-2013, 07:41 PM | #18 | |
Rep 5,874
08-10-2013, 08:46 PM | #19 |
Rep 423
Craftsman had the same idea with their jack stands and jack combo but you need clearance to get to the jack underneath that the extra pad height takes away. Especially on lowered cars.
Here is my M3 on all four jack points using the AC hydraulics jack Here is my daughter inspecting the esco jack stands.
2011 M3 Sedan
08-10-2013, 09:23 PM | #20 |
Rep 266
Mentioned above was using Rhino Ramps. I would check first before buying. For my E92 they are too steep. A 2xsomething gives me enough room to get my service jack under the front though.
08-10-2013, 09:36 PM | #21 | |
Perception is King
131
Rep 1,703
08-10-2013, 10:59 PM | #22 | |
Rep 423
Rear jackpoint is just behind the rear differential. You will see a solid piece of metal there. Probably cast iron or similar. Put a spacer on your jack, I use hockey pucks so your jack does not hit the differential. Then you will be able to get your car on all fours.
2011 M3 Sedan
