08-18-2013, 11:42 PM | #2 |
IG: limited.slip
335
Rep 1,922
The Dinan "plates" I had briefly. They don't provide enough camber for optimal performance.
Just buy a set of real camber plates http://www.m3post.com/forums/showthread.php?t=861370 |
08-19-2013, 12:39 AM | #3 | |
Rep 631
However taking my usage in considerations (DD, No track time, Just needing an additonal 0.5-0.7 degrees to complete my aggressive front stance), it seemed that the Dinan fixed plates would be a more fitting choice? (Lower priced, Brand new, Less possibility of NVH..etc) I just couldnt get around paying the extra $$ for adjustable plates when I know I wont be needing/utilizing the extra benefits (Adjustability, >3 degrees ..etc) With that said, if you are keen on clearing them out you can PM me and we will see if something can be worked out (I just did not want to be seen as a lowballer hence I did not inquire further on your plates) Back on topic Dinan plates BNIB or used please hit me up, thanks! Last edited by BIU; 08-19-2013 at 01:06 AM.. |
08-21-2013, 09:02 AM | #4 |
Rep 880
I was looking for these as well.... could not find any used so bought new and received them earlier this week. Have not installed them yet. Just as FYI, these things are like almost 1/4" thick so they will raise the front up a bit. I have Swift Spec-R lowering springs on the way so not a big deal for me. The plates are actually a lot thicker than i thought they would be though.
I had these plates on my 335i as well and were really happy with them. I actually switched from vorshlags to these. Adjustable is great, but with my static dinan plates and coilovers I was at –2.3 camber in the front which worked perfectly for the track and was still fairly gently for my street tires (my car was a daily driver as well). I hope to get around the same result on the M3 with the static plates and the lowering springs. We'll see…. Hopefully will receive everything and can install over labor day weekend. |
