08-24-2013, 03:07 PM | #1 |
Rep 633
Stock Caliper Metal Guide Pins
Folks,
I had used these in my I Stock E36 M3 race car and it had completely eliminated the funny wear associated with caliper flex with the OEM setup. That said, I went to BW's site and realized they do not have this solution for our cars. http://store.bimmerworld.com/bimmerw...e-kit-p46.aspx Any leads? Thanks in advance. Regards, Lutfy |
08-24-2013, 04:20 PM | #2 | |
11818
Rep 23,187
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
08-25-2013, 10:29 AM | #3 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
I ran them on my e46 for several years and 50k miles. No problems. I looked into this a few years ago. I believe the e90x calipers only lend themselves to one solid pin per caliper. The other location on each caliper can't be converted for some reason.
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now. Why, yes. I am an abrasive bastard. |
08-25-2013, 11:22 AM | #4 | |
Rep 633
I clearly believe that with the guide pins (avoid uneven pad wear) and proper NON drilled 2 piece rotors and removing the rear backing plates (with SRF and PF08/Pagids) the stock system can run fine without putting the pads to dust. Lets see if anyone has experience. Sent a memo to BW as well. Cheers, Lutfy |
08-26-2013, 10:09 AM | #5 |
Rep 633
Okay update from Bimmerworld:
"We have them in the works for the E9X M3 cars. Probably a month or two off" Am excited for next year with the following setup: 1) Brass guide pins to eliminate caliper flex and uneven pad wear 2) Castrol SRF fluid (higher boiling point to eliminate soft pedal as compared to Motul 600 which needs quick bleeds each weekend) 3) PF Direct Drive or Custom Coleman 2 piece rotors to avoid accelerated pad wear and provide greater cooling (vaned rotors). 4) New Pagid RS29 compound (out now for our cars) 5) Removal of dust shield for greater cooling. Hoping this should solve the 'pads turning to dust' and a softer pedal Lutfy |
12-19-2013, 01:13 PM | #6 | |
Rep 633
This is a go for me as my pads were wearing unevenly plus this adds to a more linear/somewhat tighter feel as there is less flex (not that any one of us can really 'feel' an immense difference). That said, ordering all of the above to get an optimum stock brake system without burning up pads per weekend and boiling fluid (hopefully). Lutfy |
12-23-2013, 10:56 AM | #8 | |
Rep 633
No not really. The PFC Direct Drive are so close to price, I am ordering those with the new V3 (none of the bolts to deal with). When the time comes to get a replacement ring, I intend to send the worn out PF Direct Drive over to Coleman to get a custom blank with no dimples etc. Cheers, Lutfyb |
12-23-2013, 01:56 PM | #9 | |
Thread killer
646
Rep 1,896
The general consensus amongst the 1M track rats was that the PFC rotors offered the best cost/benefit ratio and longevity, although there's that troublesome M3post PFC rotor fail thread. You still plan on running stock calipers, right? I'm curious about your plans for street/track pad choice. PFC-Z rated and PFC08s maybe? |
12-23-2013, 02:08 PM | #10 | |
Rep 633
For street, I have been using the stock ones as it was just replaced under warranty (no more BTW). Most likely stick with PFZ. Yes stick with stock caliper. With these tweaks, the pad wear should be taken care of (on track) along with heat management (have confidence as some of the instructors I met on track were happy with wear). Pricing is same on V2 and V3 from my convo with BW. Cheers, Lutfy |
12-28-2013, 12:18 PM | #11 |
Rep 7,298
Interesting. So just pop out the rubber and put these in? I change pads at the track. Wondering if this will change any of the current process.
12-30-2013, 10:57 AM | #12 | |
Rep 633
Enjoy! Cheers, Lutfy |
12-30-2013, 09:31 PM | #13 |
Rep 834
I have a question on the kit, since it doesnt have a bushing to keep the dirt out , cant we cut our old bushings and slide them onto the solid bushing to the end to where its a tight fit , then we can reuse the end caps and keep the dirt out
12-31-2013, 11:48 AM | #14 | |
Rep 633
People talk about not using metal guides because they can fail on the street obviously haven't tried it. In my past 2 years with my E36, no issues except for savings with even pad wear. Lutfy |
