09-05-2013, 06:32 PM | #1 |
Rep 20,742
Drives: 2021 911 turbo
Dealer forgot to install underbody brace plate - Opinions needed
I brought my car to the dealer for various maintenance items, to fix an exhaust leak and to replace the right side felt under the front bumper that I damaged going down a steep driveway. I pick the car up a few days later after a $900+ bill.
The next Saturday, walking towards the car, I notice that the felt piece I asked to replace is now missing entirely. Looking under the car, I notice that the entire mid section of the under-bumper felt is missing (the large center section also has air ducting for the oil cooler). My first though is that they did not install it properly and it tore away while driving. Further, while driving the car, I also notice there is an unusual vibration mostly felt at idle, as if the exhaust was touching the underbody. I bring the car back to the dealer at the first opportunity. When they put the car on the lift, they show me that the entire metal brace plate that connects the suspension mounts under the car is also missing and that my engine mounts are shot because the engine is sitting half an inch too low. They say that because of the mounts, the engine probably shook the metal brace out of place. I am quite sceptical, because I don't see how that could have happened. Futher, if I would have lost such a big piece of metal while driving back home, I would have definitely felt it come off. Further, looking at the bolt holes that secure the metal brace, I notice that they are all in perfect condition, not as if the brace was sheared off. Today, I get a call from the dealer saying that my car is ready but that they found all the missing parts in a Canadian Tire bag in the trunk . They asked me if I had the parts removed at Canadian Tires... Finally, they end up confessing that the mechanic that was working on my car was not feeling well and did not finish the job; he stored the parts in the trunk in the bag. The mechanic that picked up the job on the next day omitted not re-install the front felts and brace (the brace needed to be removed to fix the exhaust leak) . So I pick the car back today and get a $850 bill for replacing the engine mounts, they did not charge me for installing the front brace and felts . Driving back home, all of a sudden, there is a strong vibration at idle coming from the engine. After investigating, I find that the vibration is coming from the intake plenum rubbing against the top strut tower brace, as if the engine is now sitting too high . Except for an exhaust leak, I had a car that was driving perfectly fine. Now after $1750 I have a messed up car. It does not add up . A few questions: Could the fact that I drove without the bottom suspension brace installed have damaged the engine mounts or other components? What could cause the engine to now sit too high at touch the top strut tower braces? Last edited by CanAutM3; 09-05-2013 at 10:26 PM.. |
09-05-2013, 07:12 PM | #2 |
Bad Lieutenant
233
Rep 3,517
I don't get the connection with the mounts and the chassis brace; something isn't right or it's a coincidence the mounts failed. Shit I would have wanted to go with the vibra-technics mounts while they were doing that work
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
09-05-2013, 07:13 PM | #3 |
HayZeus
17
Rep 302
Weird stuff . What dealer ? Laval ?
I doubt the engine will sit too high .Unless something was twisted or warped when you drove with the parts missing, remounting the engine correctly with original mounts or aftermarket should not have it sitting too high .
BLOME !!!
MW E92 , Turner test pipes , Vorsteiner Titanium catback, TMS spacers, ESS remap , KW sleeves. |
09-05-2013, 09:32 PM | #4 | |
Rep 20,742
By driving with the brace plate not installed, I deduce that the front axle could have bent and damage the engine mounts in the process. This could be why the engine now sits too high. I am just speculating and would like some experts to chime in. Last edited by CanAutM3; 09-05-2013 at 09:45 PM.. |
09-05-2013, 09:34 PM | #5 |
Rep 20,742
Agreed. See my post above. I think that driving without the brace could have bent the front axle on which the engine is mounted...
09-05-2013, 09:46 PM | #6 |
Rep 573
What brace, do you have a link to realoem or something? It would be very hard to bend the front subframe. I Have replaced two front subframes and cant recall this brace (might just be a brain fart but a link would be nice)
09-05-2013, 09:51 PM | #7 | |
Rep 358
09-05-2013, 09:53 PM | #8 |
Rep 573
I looked it up, that plate is more of a skid plate (reason for be not putting brace and it as the same thing) I would highly doubt that driving without that would cause the front sub frame to bend.
It is also possible that the engine mounts were installed incorrectly since they have a nipple on them that inserts into a hole to help when you tighten the nuts so it doesn't spin and for placement. But not sure if that would make it sit high enough to hit the bar. |
09-05-2013, 10:01 PM | #9 | |
Rep 20,742
Now I am really pissed. Going to talk to the service manager first thing tomorrow morning. |
09-05-2013, 10:08 PM | #10 | |
Rep 20,742
09-05-2013, 10:09 PM | #11 | |
Rep 358
09-05-2013, 10:11 PM | #12 | |
Rep 573
09-05-2013, 10:12 PM | #13 |
Rep 1,616
Usually when I hear about a removable brace/cover I think that its not an integral part of the chassis. I'm not familiar with this specific part but usually braces are just used to stiffen the chassis, there shouldn't be a detrimental issue if its not installed.
I'm thinking the dealer probably jacked up your engine mounts somehow and are just making excuses. You should actually ask for a full refund AND have them fix everything. The work you described seems pretty simple, to cause this type of problem is inexcusable.
09-05-2013, 10:13 PM | #14 | |
Rep 20,742
Not quite the way I like doing things... This thread is to get technical insight, not to use as a negotiation tool. Last edited by CanAutM3; 09-05-2013 at 10:22 PM.. |
09-05-2013, 10:14 PM | #15 |
Rep 573
The subframe is actually very stong. You have to think, the subframe holds the engine up. It also helps hold the wheels on with a wishbone and control arm.
09-05-2013, 10:15 PM | #16 |
Rep 20,742
09-05-2013, 10:17 PM | #18 |
Rep 573
To be honest you just have to take it back and tell them that it still has a problem after they preformed a repair. They did the repair so they have to fix the new problem that has come from it.
