09-21-2013, 07:41 PM | #1 |
Rep 43
ABS sensor seems to be linked to everything!
I had the ABS, DSC and FTM warning lights all come on 2 days ago.
I was fearing the worst after reading some posts about $2,500 + pump replacements etc. Turned out it was just a bad ABS sensor on the left front, changed that and all warning lights were gone. I've tried searching for the "relationship" between these various lights and ABS but can't find the answer. Could somebody briefly explain why and how DSC and FTM could be affected by ABS? Thanks Daz |
09-21-2013, 09:59 PM | #2 |
Rep 124
Drives: 2013 E92 M3 ZCP
ABS, DSC and FTM all use the same wheel speed sensors. That's why when yours went bad all three systems showed errors.
FTM monitors the difference in velocity between the four wheels that would indicate a change of tire pressure. Lower pressure, means decreased circumference and therefore lower rotational speed. If it differs from the other wheels by a significant amount the FTM system will warn of low tire pressure. DSC combines differential wheel velocity with other sensor readings (gyroscopes, steering) to detect over/under-steer conditions and generate corrective actions.
2013 E92 M3 ZCP 6MT (06/13 built) :: Melbourne Red & Fox Red/Black/Black 2-tone :: H&R Sports+ Springs :: Ground Control Camber plates :: Essex/AP-Racing Radical Pro 5000R (CP9660) Front BBK :: 275/35/18 Maxxis RC1 on OZ Challenge HLT (track)
09-22-2013, 09:34 AM | #4 | |
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
I experienced this exact thing this summer at the track but it wasn't because of a bad sensor, it was because I was spinning my rear tires so much that ABS failed! Cliff notes: 97 degrees afternoon track session at Big Willow and I'm running street tires (Michelin PSS). Tires can't handle the heat and actually begin to break down into a gooey substance. It's so bad, that I have no traction accelerating at anything more than half throttle. Because of the sustained tire spin, ABS turns off - but so does everything else! My NAV lights up like a Christmas tree and everything turns off, including DSC. I track with Euro MDM on, so DSC is on as well. In this instance where ABS failed, I could deal with that but didn't know DSC had also failed so I wasn't being very cautious on my warm down lap and this happened: http://www.m3post.com/forums/showpos...&postcount=615
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
09-22-2013, 09:52 AM | #5 | |
Rep 20,742
Drives: 2021 911 turbo
09-22-2013, 10:01 AM | #6 |
Rep 124
Correct, my mistake. Let's say I should try to math on a Saturday night that late
