Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M3 (F80) and BMW M4 (F82) General Forum
      09-25-2013, 01:05 PM   #1
solstice
Drives: 2015 M3 6MT
F80/F82 Weight by standard.
A lot of confusion around the weight numbers. BMW is not misleading, they use the EU Kerbweight standard and also stated an ~80kg weight loss from the E92 M3.
What has been misleading is the myriad of translations to US curb weight and all confusion with what the standards includes.
Here is a list of the side by side weight F82/E92 using the 80kg/176lbs difference as formula.
US curb weight: 3528 / 3704 lbs ( 1600 / 1680 kg )
EU DIN Unladen: 1575 / 1655 kg ( 3472 / 3648 lbs )
EU Kerbweight: 1505 / 1585 kg ( 3317 / 3494 lbs )
I hope this can help when you compare weight and power to weight ratio with other cars. Just be sure you use the same standard.
( When you see lower US curb weight number for the E92 it's mags or people having put the car on scale without a driver and with equipment/fluid differences )
      09-25-2013, 02:44 PM   #2
myzmak
Advocatus Douchebagus. Sex Marxist.
myzmak's Avatar
Drives: Lucy.
2015 F80 M3  [10.00]
2013 MB E350 Wagon  [10.00]
very helpful, thanks.
      09-26-2013, 03:59 PM   #3
mxa121
mxa121's Avatar
226
Drives: M
THANK YOU
      09-26-2013, 06:58 PM   #4
Holset
Sweden
274
Drives: F90 M5 Comp LCI
Unladen means unloaded so for the F82 it should be
EU DIN Unladen:1500kg/3306lbs
EU Kerbweight:1575kg/3472lbs
EU DIN Unladen=all fluids and 90% fuel
EU Kerbweight=all fluids and 90% fuel + included 68kg driver and 7kg cargo
      09-26-2013, 07:06 PM   #5
Carl L
Carl L's Avatar
196
Drives: '15 M3
Good post but a small correction is I think you have curb and unladen reversed. Also, the unladen is supposed to be less than 3306, not 3317 (or did I just open up the worm can again?!)
edit- just saw Holset beat me to it.
f80post
