10-07-2013, 06:22 PM | #1 |
Rep 140
Brake Fluid Reservoir Question
2011 E90 M3 6spd. Dealer tells me a recent clutch malfunction is due to the fact that a hose came off the brake reservoir thus starving the master slave of fluid. When looking at the reservoir from the hood towards the windshield, the black hose attached to the white tube on the top on the right side of the reservoir. I think that is an overflow tube/hose and that the fluid going to the slave is on the bottom of the reservoir. Comments please.
PS I note that the dealer also tried to tell me that the fact I put Castrol SRF brake fluid in my car contributed so needless to say I am very wary of any of their explanations. Thanks.
Current: 13 X5 Diesel, 991 Carrera S 50th Anniversary Edition Gone: 11 E90 M3 ZCP, 07 328i ZSP, 05 330i ZHP, 04 996 GT3, 02 525iA, 02 996 C2, 01 Boxster S |
10-07-2013, 06:50 PM | #2 |
Admiral
933
Rep 3,886
This sounds very fishy to me. Interested to hear from someone with better knowledge of this.
2020 FORD RAPTOR 2014 F15 X5 | M-SPORT SOLD 2011 SG E90 M3 | 2008 AW E90 M3 | 2004 E46 M3 |
10-10-2013, 10:19 PM | #3 |
Rep 935
This may help. Which hose are they talking about?
http://realoem.com/bmw/showparts.do?...86&hg=34&fg=15 |
10-11-2013, 09:26 AM | #4 | |
Rep 140
10-26-2013, 08:09 PM | #5 |
Rep 3
Okay, the picture you have is a very similar tank on the 2007 335i that I have in my garage.
The hose that comes from the right side of that tank goes to hose #7 in the other picture above. That is the feed line from the brake fluid reservoir to the feed port on the clutch master cylinder. If the hose "fell off" during operation, the clutch master cylinder (CMC) would fill with air. After a few pumps the master cylinder would be dry and full of air which would cause the clutch pedal to become soft and basically lay flat on the floor of the car. I don't think running the CMC dry would cause it to become non-functional but it definitely makes it hard to bleed the entire system. That help? |
10-27-2013, 06:23 PM | #6 | |
Rep 140
10-27-2013, 07:22 PM | #7 |
Rep 3
The hose (#7) is basically just pushed on the tube on the reservoir and onto the CMC, I do not like this design at all. I feel that the hose could work itself loose if you have ever replaced either component. I put a hose clamp over the hoses themselves as added security.
10-28-2013, 08:06 PM | #8 | |
Rep 140
10-30-2013, 09:52 AM | #9 |
Rep 3
No worries, glad to have helped.
