10-12-2013, 03:09 PM | #1 |
Rep 65
F10 M5 Knob installation: Fail!
UPDATE: Fixed it: It snaps back in just like the stock does.
I read the DIY and gave it a go. I swapped the base and cut four holes (twice larger than needed after reading the posts). It didn't snap in at all. Then I cut more and glued it so that it would be slimmer. Even worked out the edges. It does not even stay there. Can anyone identify the problem just by checking the picture? The base was did not come out easily by the way, it was snug. It shifts very good by the way, better than what I was expecting. Of course it looks like crap. I'm thinking about putting the stock back and change the knobs only, but wanted to check if there is any help... My 2 cents: Do not change the base unless you have time to waste. Last edited by miamiflgator; 10-13-2013 at 11:10 AM.. Reason: Fixed it |
10-12-2013, 03:13 PM | #2 |
DHS
213
Rep 4,029
Drives: 2023 M4, 2020 Land Rover
I could use my Alcantara boot but I used the leather.
I would have to pry out the staples and pull apart the alcantara from the plastic. Then re-glue and staple to OEM plastic. Done.
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
10-12-2013, 03:18 PM | #3 |
Rep 2,400
Damn, I just ordered the M5 shift knob thinking the DIY was easy...really not looking forward to a 2+hr PITA installation....maybe I'll pay to have some aftermarket shop deal with it.
10-13-2013, 11:08 AM | #5 |
Rep 65
FIXED IT
I fixed it and took about 30 minutes. Good news I found a way so that it snaps back in just like the stock and won't move a bit. I trimmed everything so that the cut is not visible and glued the leather: not the sides but the top!
I can take pics and do a DIY but I don't if anyone will have the same problem. Plus IMO: don't swap the base. |
10-13-2013, 11:15 AM | #6 |
Rep 2,400
10-19-2013, 06:45 PM | #9 |
Rep 2,400
Yes, as others have said, this is a PITA install. Not that it can't be done, just that it is rather cumbersome. I did stuff the boot underneath the ring, but not exactly satisfied with the fit....think if I glue it, it will fit perfectly!. The knob does feel better and I like the "rougher" leather vs the old m3 knob.
10-19-2013, 07:16 PM | #10 | |
DHS
213
Rep 4,029
Any shiftknob for the E9X M3 is 5-20 minutes max. I have done all of them. Not hard at all.
10-19-2013, 07:57 PM | #11 |
Rep 2,400
You must be significantly more talented than I. It was going very quickly, ie 10 mins between the cutting of two boots, removal, plug in etc, it just was stuffing the M5 boot underneath..that was pretty difficult given the different shape and where the boot is cut, but again, if I glue it think it will be perfect.
10-19-2013, 08:00 PM | #12 | |
DHS
213
Rep 4,029
2023 BMW M4 2016 X3 Last edited by Endless619; 10-21-2013 at 09:54 PM.. |
10-19-2013, 10:46 PM | #13 |
Rep 2,400
How do you like the M performance one compared to others you tried? I almost pulled the trigger on this, but wanted the lighting effect of the M5 knob, but like the carbon fiber and alcantara look.
10-19-2013, 10:57 PM | #14 |
DHS
213
Rep 4,029
I like it. It's heavier than the E46 Performance shift knob. Other than that its pretty much the same piece with added carbon and darker alcantara.
10-20-2013, 10:35 PM | #15 |
Rep 2,400
So I finally completed the M5 Shift Knob. Definitely worth gluing to the base to get the best fit (about 1 hr work in total). Cut the leather back as much as possible so that the leather boot goes just until the bottom end of the base. I used shoe glue (Shoe Goo brand), which worked perfectly as if you get some glue on the boot, it rubs right off. Used the binder clips as others have used to set the boot into the glue on the base. Once completed, snapped right into place and looks really good. In stuffing the boot under the base ring (before gluing), I never got a great fit and looked like there was too much "slack". By gluing, you can really control things nicely for a perfect fit and even if you mess up, because it's shoe glue it can peel right off. And as others have said, the shifter feels awesome!
10-21-2013, 01:25 PM | #16 | |
DHS
213
Rep 4,029
10-21-2013, 09:49 PM | #18 |
DHS
213
Rep 4,029
Looks good.
10-29-2013, 10:08 AM | #19 |
Rep 65
I was going to post pics but someone beat me to it
First: not all the rings/boot are created the same, I have seen another car and you can take it out and put it back in a second. It's impossible with mine, no leather should be tucked in. AND glue is a MUST. It looks much better also because you can cut the leather so that you will have no wrinkles etc. If you tuck it under, there is no way because M5 boot is larger on the base. It's awesome by the way, the first mod I'd do. |
11-06-2013, 07:46 AM | #22 |
Putcha ang ganda...
281
Rep 5,441
ive done this to my friends car and no issues. pretty darn easy to be honest. if your anal maybe 30 minutes but can be done less than that.
