10-31-2013, 04:57 PM | #1 |
Rep 1,842
Performance Friction Z-Rated Brake Kits for 135i from GMP Performance
New from Performance Friction - the new line of Z-Rated brake kits specifically for your BMW! Without question, this brake kit is the best on the market - a conclusion that comes from years of racing domination, not the marketing desk. Unlike other brands whose street kits have only the nametag in common with their top level racing components, these PFC parts are the real deal that win Championships across the board of top-level professional series Tudor, GRAND-AM, World Challenge, WTCC, Australian V8 Supercars, and more. BMW 135i (E81/E82) Performance Friction Z-Rated Monobloc Front Brake Kit (355mm, ZR31 Caliper) BMW 135i (E81/E82) Performance Friction Z-Rated Monobloc Rear Brake Kit (355mm, ZR31 Caliper) The kits are specifically designed to meet the needs of the most demanding BMW Performance enthusiast and racer. Brake bias is moved slightly to the rear for improved braking performance in both front-only and 4-wheel applications. Calipers Z31 Front and Rear Caliper (4-Piston, 4-Pad) - The 4-piston Z31 caliper used on both the front and rear of this kit is a Monobloc design, machined from a single piece of alloy billet (not a casting used by all other manufacturers) for maximum strength from an FIA-created design that optimizes weight while keeping the caliper rigid. This unique caliper uses four pads per caliper - one per piston for an incredible bite and the ability to mix pad selection for mixed-use cars. Calipers are finished with black anodizing, then your choice of color powdercoat and include dust boots. Why not 6-piston? Performance Friction takes their top level racing technology and applies it to everything they design, and make every component that comes from their South Carolina manufacturing facility perform at the highest level possible. A 4-piston caliper, designed correctly, is lighter and has better release characteristics than a similar 6-piston piece. If you are trying to impress piston counters, there are much cheaper ways to do it. If you want the best performing brakes you can buy, look no further. Rotors The Performance Friction rotors used in all kits are the newest V2 Direct Drive Rotors. Made from a precision casting, all external surfaces are machined to tolerances of 0.004", including the OD of the vein area that most manufacturers leave rough-cast. This is the only rotor that are mechanically, thermally, and dynamically balanced - meaning you will never warp them because they are balanced in all situations, all temperatures. New V2 hardware reduces weight an additional half pound from the already light V1 components. Kit also includes Z-Rated PFC performance pads and the required stainless brake line set. For more information on these kits, click any of the links above or feel free to contact us at any time!
Trey @ GMP Performance Phone: 704-525-0941 x 254 Email: trey@gmpperformance.com Website: www.gmpperformance.com |
11-26-2013, 11:11 AM | #2 |
Rep 1,842
Feel free to message us with any questions or for more information.
12-03-2013, 02:41 PM | #3 |
Rep 1,409
Any word on when PFC pads will be available for stock calipers? Thanks.
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
12-04-2013, 11:52 AM | #4 | |
Rep 1,842
Thanks everyone!
12-16-2013, 04:51 PM | #5 |
Rep 1,842
No ETA yet
12-16-2013, 05:15 PM | #6 |
Rep 1,409
Someone has actually a thread on getting a beta brake pad compound for stock 135 calipers ... See here ... http://www.1addicts.com/forums/showthread.php?t=921066
Tags |
brake kits, calipers, gmp performance, performance friction |
