01-02-2014, 01:56 PM | #1 |
Rep 609
Upcoming new owner. Mod advice
Hey guys. Finally getting myself into an e90 m3 after a short hiatus. Sold my e46 m3 in January and got a 2013 WRX that I've enjoyed thus far. Things have been going well and hopping into an e90 m looks better than ever. Got a few questions in regards to mods.
Suspension is a huge thing for me in my cars. I like the ride to be daily driver compliant, yet give it that sporty, aggressive feel. Most of the M's I've been looking at have EDC. While I am more of a simplest, I am unsure of which direction I should go. While I am aware EDC components cost a bit more, what kind of suspension setups are compatible with EDC? I've done the coilover route on almost all my previous cars, but thinking of going with a good spring setup for the e90 since the car will most likely only see street time for now. The KW sleeve over kit, Eibach, and H&R seem to be the most popular in regards to springs. I like the KW sleeve kit since it has the height adjust ability like coilovers. However, are any of these not compatible with EDC? Should I be looking at something else? What setups have a comfortable ride, but tighten things up nicely? I've been known to be an exhaust maniac on my e46 M (9 separate setups), so I will definitely be visiting this area shortly after I obtain the car. I've been catless and had my fun, but keeping the car daily driver compliant is a biggie for me. I want to keep the cats in, but I do want an aggressive exhaust note. Test pipes seem to be extremely popular with this car since it lets the cat out of the bag, so to speak. However, removing cats in any car makes them sound evil. I will be looking mainly at the ACM muffler mod since it's a very cost worthy modification with great results. However, I've heard some M's with the ACM muffler and the challenge x pipe. Would adding that x pipe remove my cats? I see that they have 3 versions (sport, race, street)? Would removing the secondary cats make me catless? Only reason why I ask is because I thought I read somewhere they have 2 sets of cats. I could be completely wrong though. That's it for now. Thanks guys!
01-02-2014, 02:23 PM | #2 |
Rep 939
Not an expert on suspension but my e46 m3 had bilstein PSS-9 coilovers and I'm now running H&R Sport springs with my EDC e92 M3. Ride is firm but compliant enough for daily driving. Also stiff enough for spirited track driving. The drop is aesthetically pleasing and the functionality of the EDC is unhampered. Some coilover setups are non-compliant with EDC whereas the springs are good to go.
As for the exhaust, I'm like you and want the perfect balance of grunt and burble without compromising on drone or bassy boom in the cabin. I started with an AA setup and just recently switched to the MPE slip on. I love it. I've heard that MPE and Akra are the best non-drone options but, if you go Akra, you need the x-pipe to get volume as it can be more quiet than stock. I've also listened to the OE Exhaust Mod - sounds good but, IMHO, not as exotic as the MPE. |
01-02-2014, 02:27 PM | #3 | |
Rep 609
Exactly. I do like my exhausts a bit louder than others. I was looking at the Gintani, Agency Power, and Eisenmann Race exhausts as well. All of which seem to be around the same level of sound. I'll have the check on the MPE exhaust. Thanks again!
01-02-2014, 02:35 PM | #4 |
Rep 5,396
suspension should be kept stock for compliance and performance.
unless you go with a quality (IE expensive) coilover setup, the car will ride worse and not handle any better on anything but the smoothest of surfaces.
01-02-2014, 02:37 PM | #5 |
Rep 609
I am aware, however there is much to be had from of a more aggressive spring. Lower stance, decreased roll, etc. I've had coils on almost all my cars and know it's a great system. However, springs on this car (for the street) seems to be fairly popular. I am used to a firmer ride, so it's not a huge issue.
01-02-2014, 02:43 PM | #6 | |
Rep 337
I'll add some here...
I ordered the ZCP specifically to avoid swapping back/forth from different coil over setups like I have in my past cars (probably more swaps than you have on E46 exhausts lol). Anyway I'm almost 1.5yrs in on my '13 and I wouldn't change a thing on the suspension, granted my car is 90/10 street/track driven. Exhaust-wise, I listened to every setup I could find before ordering and actually had a MPE a couple months before I took delivery. Still love it today, and "I hear" they are even more exotic sounding with the front cat delete =)
'24 G80 Base in Dravit/Full-Kyalami, Allocated January 9th, delivered April 30th. Sandlapper CCA.
01-02-2014, 02:48 PM | #7 | |
Rep 5,396
the car will ride worse, bounce more, handle worse etc. with springs only to each their own though, and sad to see your wrx go
01-02-2014, 02:50 PM | #8 | |
Rep 609
That's the first I heard that! I love the wrx, but looking forward to getting back into an M.
01-02-2014, 03:37 PM | #9 | |
Rep 620
01-02-2014, 03:41 PM | #10 | |
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
the stock ZCP suspension works very for me on the track and I'm pushing 580 wheel HP and also run a 380/365 Big Brake kit as well. There is some body roll but it's not a bad thing. It give you great feedback and even a novice driver like me knows exactly where the limit is.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
01-02-2014, 05:42 PM | #13 |
Rep 656
I agree with this. If you are just after a drop and a bit of improvement, ZCP or Dinan is the way to go.
01-02-2014, 05:47 PM | #14 | |
Rep 656
01-02-2014, 11:39 PM | #15 |
Rep 786
Hey man, I remember you from m3forum.
Few quick notes for ya since I had 2 e46m3s as well, I can give you a little help with comparable parts. Kw v2 for e46 M3 is KW V3 for e9x. I was actually among the few folks that found my e46 KWV2s way too bouncy to the point where I never wanted to go back to coil overs again. But I am sure as hell happy I ended up with KWV3s for the e92. At its lowest setting the car still rides better than stock and handles like its on rails. If its not in the budget atm just throw in a set of used lowering springs to hold you over until you can get KWV3s - you won't regret it. I went through eisenman sport, eisenman race plus a few other exhausts along with the popular rasp pipe in the e46. The e9x sounds so much better with the v8, but this is where it gets tricky. While the inline 6 e46 Ms sounded weak with sport mufflers most Race mufflers combined with an x-pipe on the e9x are too loud or drone too much. Everyone here will tell you to go MPE or Akra evo. While they both sound great, it is not necessary to spend big cash from the beginning. I love running an x-pipe for performance and combined with pretty much any type of a sport muffler the combo usually comes out good. Challenge street = your oem primary cats w/resonators, Challenge sport = high flow cats w/ resonators, challenge race is catless with resonators, and challenge race + is catless without resonators. Challenge sport, mxp, UUC corsa, ae are just a few of my favorite mufflers. I've been through around 10 rear sections and 3 x-pipes give or take so far and I still enjoy switching up my combo. Hope you will enjoy this platform as much as I do. Have fun with it! |
01-02-2014, 11:48 PM | #16 | |
Rep 609
Thanks for much for the info everyone. Definitely informative. I'll have to see how compliant the stock suspension is and if I can stand the wheel gap. I don't like to "slam" my cars, but I do like them to have an aggressive look, while keeping things practical.
In regards to coils, I keep eyeing up the kw v3's. I have a feeling I'll go for them as well since I was pretty happy with the v2's on the e46. My only concern is that the few M's I am looking at currently all have EDC and would be an issue going to coilovers. I'll have to see what options I have when I do acquire a car. I appreciate all the feedback. Very helpful!
01-03-2014, 12:01 AM | #17 |
Rep 656
Dinan is a great sounding exhaust that is relatively mild and has no drone, and sounds great with an X-pipe (especially with a quad resonated one, but I just couldn'thandle the smell). It frequently goes for $1500 or so used.
01-03-2014, 12:22 AM | #18 |
Rep 3,934
i think you are crazy to buy springs or coils for performance. if you buy them for to get a rougher ride (which some like) and lower stance then i guess it different.
i know for me my ZCP/ EDC suspension is PERFECT. can be rough and can be smooth. in the highest EDC setting the car gets stiff and firm. plus with ZCP you get a slightly lower ride. for me i always thought the M3 suspension out performed the power of the car. I would go mods power first on M3. |
01-03-2014, 10:50 AM | #20 |
Rep 1,374
I remember your E46 M3 build thread at m3forum
thought you went WRX recently, i guess you're coming back to M! E90 LCI would be perfect, gluck hope you find a well maintained M3!
01-03-2014, 02:53 PM | #22 |
Rep 656
Really? There is quite a bit of feedback that suggests their toe links do nothing (their rationale for why the stock is inadequate does not make sense), except making adjustments easier. If you had them installed simultaneously, you're most likely just feeling the monoballs. Or, you know, placebo, since you'll only likely feel the difference during track use.
