01-08-2014, 10:15 PM | #1 |
Rep 144
BMW Extended warranty issues
Hi all,
I have a 2009 M3 for which I recently purchased the BMW Extended Warranty (Gold). Needless to say, this is not an inexpensive warranty. I took my car in to a local dealership in northern California with better than average review scores. However, I wanted to run their handling of the issue by all of you fine folks to get your thoughts. There were 3 issues with my car: 1) Increased battery discharge -- car currently fitted with the original OEM AGM battery. 2) Passenger door will not unlock 3) SOS call system malfunction Up front, the dealership wanted me to agree to potential diagnostic charges at $130 for each of the three above problems. This would be "refunded" and I would only have to pay the $50 written into the Extended Warranty contract should any of the above issues fall under warranty coverage. A few hours later, they give me the results of the diagnostic check. The increased battery discharge is due to a faulty cell in the battery. Apparently, the battery is not covered under either the original or extended warranty. Although they mention that they may have replaced it as a faulty unit if I was still within the original factory warranty period, the battery is now apparently too old and at the end of it's life expectancy. So, they want to charge me $130 diagnostic fee and about $700 for replacing the battery and coding it. Fairly ridiculous. The door is apparently a faulty locking mechanism so they will not charge me the $130 but will charge me the $50 deductible. Parts and labor will be covered by BMW. Lastly, and most annoyingly, the SOS system malfunction was blamed on using a "non-approved" cell phone. Apparently, the Motorola I have is not on the list of 4 -- that's right, FOUR -- models approved by BMW. They're claiming that this can throw the telecommunications system out of wack although the error has clearly occurred when the phone isn't even paired with the car. The frustrating thing here is that I brought this issue up with another dealership while the car was in the original warranty period. It was logged in the service record but no issue could be found so the code was reset. Yet, this dealership now want me to fork over $130 as a diagnostic fee for a problem they failed to diagnose initially and, now, on the second go around. Does any of this sound reasonable? Is it appropriate to charge all these diagnostic fees on a warrantied car? Can they charge me for a problem that I had already flagged during the original warranty period? Should the battery be covered? Thanks for all the input in advance. El Duderino
2009 E92 M3. Melbourne Red on Fox Red. ZPP ZTP. Remus Sport. CF splitters, diffuser, grille, side markers.
01-08-2014, 10:23 PM | #3 |
Rep 144
Yup, I am taking the car elsewhere for the battery work. What about the rest? What's up with all these diagnostic fees despite the fact that I paid $4K plus for an extended warranty from BMW.
01-09-2014, 12:09 AM | #5 |
I want to drive a Zamboni
1132
Rep 5,559
Drives: 13 E93 M3 18 F80 M3 16 K71
Battery replacement is not cheap, I paid $500 for my E90 battery and your car is due for a new one.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
01-09-2014, 02:30 AM | #6 |
Rep 144
Believe me...I will. Just as soon as I determine how this pans out and I get my car back. Completely unacceptable behavior in my view. I will also be sure to hit them hard on the service survey and then follow up with BMW NA. Total BS.
01-09-2014, 02:50 AM | #7 |
Rep 347
01-09-2014, 09:06 AM | #9 |
Rep 229
I think you should haggle for 1 diagnostic charge (especially getting the cellphone code one written off) and overall discount. They typically do offer a bit of a discount if you insist.
Also, I wouldn't put anything other than OEM especially if you're on an extended warranty. It might haunt you down the road. I think it was around $300 for the battery at RealOEM, add a couple hours of labor (standard), coding, etc $700 isn't far off, although more on the slightly expensive side. Ask them to give you an invoice and cross off from there. IMO, if you're gonna take the car to other dealer, might as well get it done there. All dealers charge diagnostic. Good luck |
01-09-2014, 09:09 AM | #10 |
Ninja
390
Rep 4,014
go to indy shop and have them swpa and register your battery OP...contact alekshop, they should be able to help you out with that....
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i |
01-09-2014, 09:44 AM | #11 |
Rep 1,405
On the issue of the increased battery discharge, I imagine the dealer spent the time and charged you for examining the integrity of your electrical system.
If that's the case, then he should have told you two things up front: (a) they would need to check out your entire electrical system at a cost of $130 and (b) the battery was a potential cause of the problem and, if it was, it would cost you $700 to replace. If the SA did not clearly state those conditions to you at the outset, then he, in my opinion, did not do his job. In your position, I would argue that had I known these cost requirements from the beginning, I would have declined his offer. |
01-09-2014, 12:39 PM | #12 |
Stop the hate, get a V8
3853
Rep 8,625
Past: 2011.5 M3 sedan ZCP |
01-09-2014, 03:10 PM | #13 |
Rep 1,424
I have the "increased battery discharge" also. I mentioned the extremely high prices the dealer charges to my indie shop. I can't remember what they have to do but only takes 3 minutes to recode something (sorry I didn't listen to the details). The process sounded easy and quick. So the actual cost should be the battery, the time to install the battery plus 3 minutes! $200 sounds about right...........and the dealer price for some reason is $400 to $700.
01-09-2014, 03:59 PM | #14 |
IG: @dj_dub
1808
Rep 1,452
Drives: 2010 BMW E90 M3 - SG/FR 6MT
Great...this scares me a bit as I purchased the same BMW Extended Warranty as well over a year ago. Hope I don't see a bunch of hidden fees when I take my car in for problems later on down the road. I hope you get your issues resolved dude!
CarboProject CF Plenum | Dinan CF Intake | ESS Tune | RKP X-Pipe | Akra w/CF Tips | MFactory CF DS | CSF Cooling | AST 5200 | Hotchkis F/R Sways | SPL/Ground Control/Fall-Line Arms | DEFIV Diff Brace | StudioRSR Rollcage | 3-piece BBS RT88 | Michelin PS4S | Brembos F/R | Recaro Profi SPG XL | CAE Ultra Shifter | Perf Elec Wheel V2 | BAVSOUND | GT4 CF Front Lip/Canards/Rear Wing | Arkym CF Rear Diffuser | Forcewerkz CF SS | Varis CF Lower Tray | Turner Skidplate | BayOptiks Headlights
01-09-2014, 08:16 PM | #16 |
Rep 144
Thanks for all the replies above. Much appreciated. They're now willing to shift the cost of the SOS diagnostics towards a new battery bringing the cost of the battery to $480 including coding.
Still seems steep? Thoughts?
01-10-2014, 12:24 AM | #17 | |
Rep 144
01-10-2014, 01:28 AM | #18 | |
I got lei'd
846
Rep 7,594
Op, battery is all you, if you are still in NorCal, bunch of shops for the battery to be registered, not coded. I'd say $300 the least. Alekshop would be best bet for fixing SOS. |
PhillySteve1.50 |
