01-09-2014, 07:13 PM | #1 |
Rep 3,044
Drives: 2011 Dakar Yellow M3, 2018 M5
MRF Solid Sub-Frame & Differential Bushings - A Night & Day Difference in Performance
Some of you are familiar with my build. Over the years, its become more and more focused on extracting maximum performance out of the car. (Full build thread HERE)
The first mod in that direction was KW Clubsports. Then an ESS VT2-625. Then I managed to get my hands on one of MRF's rare X-Pipe. Together that combo has made my car a bit of a freak in the horsepower realm, dynoing 581HP/377TQ on 91 Octane. (See MRF X-Pipe dyno gains HERE). Its one thing to put down a lot of horsepower on a dyno. But its another thing altogether to get the same power down on the road, where traction, wheel-spin, and wheel hop come into play. Because of how much power I was putting down, first gear basically became non-existent. Accelerating from a dig, I couldn't hook up with the road without a lot of wheelspin. When I did finally hookup, my tail would either kick in one direciton or I'd get a lot of wheel hop, before the car could put down power properly. And even then, I'd have to short-shift out of first around 5k rpms before the car broke traction again. I began feeling like: "what's the point of my supercharger if i can't translate its power to real world results?" I contacted MRF Engineering, who (as a lot of you know) is a shop that has made a name for itself for serious performance builds and track builds - i.e. serious project cars - and they recommended that I look into replacing the OEM sub-frame bushings and differential bushings with solid ones (Aluminum for the sub-frame bushings, Delrin for the differential bushings). They explained that the bushings would substantially improve how much power the car could put down, by minimizing wheel hop, car squat, and diff deflection I was skeptical. How much difference could a hunk of aluminum or Delrin make?..... Turns out... A LOT !! Results: Performance improvements were drastic. The way the car handles and puts down power now, is like night and day. Here are some of the many improvements I've noted. My car:
The car should have come like this in the first place. It comes as no suprise, that subsequently BMW has begun putting these solid bushings in their other performance cars (including the M3 GTS, the new M5 and new m6). While I, personally, can't comment on the results for NA cars, the benefits are so universal that I have to imagine substantial improvements for NA cars as well. And NA people have said the same in other reviews. My car now feels much more sure-footed, planted, reliable, and most importantly, I have access to much more useable power from the line. If you care about performance, GET THIS MOD. The Parts: The sub-frame bushings are custom designed by MRF engineering, and C&C'd from solid aluminum. They're beautiful pieces. Too bad they're completely hidden from view once installed. Here is a pic: MRF Aluminum Subframe Bushings OEM Subframe Bushings By contrast, the differential bushings are made of delrin - so they have just an infinitessimal bit more "give" than aluminum. Aluminum differential bushings are also available to those who really want them. Both the aluminum and delrin differential bushings (not the sub-frame bushings) are from Turner Motorsports. Comments on NVH (Noise, Vibration, Harshness) - This is a performance mod. As with any performance mod, there is a bit of a trade off in "comfort." People need to be honest with themselves about that upfront. Buy an exhuast, you get a louder car, and sometimes drone. Buy new shocks or a coilover kit, you get a stiffer less forgiving car. Buy a supercharger, you're gonna hear some supercharger noise. BMW dumbs this car down, and makes it more cushy for the masses. If you want to tap into the car's full potential, you have to get rid of some of BMW's "lowest-common-denominator" creature comforts. Luckily, the trade-off here is minimal. The bushings do create a low volume whine above 40mph and 3k RPM for me. (Might be different for other people). Best way to describe the sound is that it sounds like the F1 car noise, but just on low volume. Its actually kind of cool. But if you're looking for dead silence - this is not it. I have both the sub-frame and differential bushings so I can't pinpoint exactly WHICH of the two is causing the F1 type noise, but my understanding that it is strictly associated with the differential bushings and that the sub-frame bushings do not contribute to this noise. For those curious about how prominent the noise is - its entirely imperceptible if you're listening to music, or if your windows are rolled down. I will try to put a video up of the sound inside the cabin for those who are curious, sometime in the next few days. The question I always ask myself on any mod is: "is what I'm gaining worth more than what I'm sacrificing?". With the solid bushings, the answer to me was an overwhelming yes. I can't communicate how truly pleased I am with the results. Pics from the Installation: As you can see, the Sub-Frame comes out for this install. Luckily MRF Engineering has some very expensive custom tools at their disposal (being a performance oriented shop) - and can get what would otherwise be a very long install, done relatively quickly. That saves us (the consumer) money and time. Unsurprisingly, other shops that aren't quite as performance oriented just don't have these tools. This month alone, I understand Malek has already done 8 (!) of these installations. And all of their reviews appear to be universally as glowing as mine. Probably a good reason for that. Best, - esquire
[ESS VT2-625] [Akrapovic Evolution Exhaust] [KW Clubsports] [OSS Angel Eyes] [Revinora r-CRT Lip] [Vorsteiner Boot] [Challenge Race Diffuser] [See the Build Thread HERE] Last edited by esquire; 01-09-2014 at 07:34 PM.. |
01-09-2014, 07:49 PM | #2 |
///M
161
Rep 1,867
Very detailed review about the subframe upgrade!, been reading a lot of forum member with SC m3 upgrade their subframe recently.
I'm trying to keep my car N/a and was wondering if its worth it to do the upgrade.
THANKS TO:~<RPM>~ ~<SONICMS>~ ~<MODECARBON>~ ~<McKennaPerformance>~
MODS: MODECARBON V2 GTS FRONT LIP & REAR DIFFUSER, AA GREEN FILTER, RPI SCOOPS, PSW, Verstraβe Extended DCT Shifter, ZCP WHEELS (SEMI-GLOSS), OHLINS R&T, Megan Exhaust, AKRA XPIPE, BMW LED INTERIOR, BLACKOUT W/ORION V4 LED AE, OSRAM CBI |
01-09-2014, 07:54 PM | #3 | |
Rep 3,044
Like I mentioned in my post, there are several NA cars out there who have done their bushings, and I believe they have all had positive things to say about the mod.
[ESS VT2-625] [Akrapovic Evolution Exhaust] [KW Clubsports] [OSS Angel Eyes] [Revinora r-CRT Lip] [Vorsteiner Boot] [Challenge Race Diffuser] [See the Build Thread HERE] |
01-09-2014, 08:56 PM | #5 |
Rep 706
Drives: ESS VT2 650 E92
More and more I read about this the more it keeps pushing me to buy these. Thanks for the great review
01-09-2014, 09:00 PM | #6 | |
Rep 3,044
01-09-2014, 09:45 PM | #7 |
Perception is King
131
Rep 1,703
Sweet, great info, isnt there some companies that make super hard but not soild differential bushings? How long did it take and what was the Total cost?
Perception and Reality are Two totally different Things.
01-09-2014, 10:22 PM | #8 |
Bored at work....
893
Rep 5,395
Wonderful review. You've made up my mind 100%.
May I ask the price of the sub frame bushings and the diff bushings? PM me if you wish |
01-09-2014, 10:33 PM | #9 |
Rep 6,149
Sounds expensive.
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
01-09-2014, 11:20 PM | #11 |
E46 + E90 + F80
192
Rep 2,894
Drives: E46 + E90 + F80
Incredible review as always.
If it's possible to make a video, that would truly be appreciated!
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread |
01-10-2014, 12:05 AM | #12 | |
Rep 3,044
01-10-2014, 09:01 AM | #14 |
***Major MammelToe
159
Rep 1,139
My whine is faint. Actually, I would like it louder! Its sounds like a baby F1.
E92 M3 SG DCT - AA Filter, Verstraβe Paddles, ECS SS, MH race stud, Stoptech BBK, MR Exhaust,RE Pulley, BPM Tune,Euro bumper and GTS lip, Euro MDM & DCT, KW CS, Recaro PP, TMS Soild Diff Mounts, MRF solid subframe mounts, GTS aero, RPM track built motor.
01-10-2014, 09:12 AM | #15 |
E46 + E90 + F80
192
Rep 2,894
Thanks! I truly enjoy your write ups on the forum.
I want a F1 Baby!
01-10-2014, 03:49 PM | #16 |
Rep 3,044
Pert, did you get both the subframe and the differential bushings? Goes to those that the noise is so faint that on some cars its completely non-existent.
Lol.
01-11-2014, 07:06 PM | #17 |
Rep 459
Would be interesting to see before/after performance measurements, i.e. 0-60, 60ft. times, 1/4 mile, to see what the actual improvements are to acceleration.
No toys right now...
My old M3: |
01-15-2014, 04:49 PM | #18 |
BimmerPost Supporting Vendor
732
Rep 3,735
Sasan,
Glad you are enjoying your new bushings. For those wondering if this is only for Supercharged cars, the answer is a resounding no. The Sub-frame bushings equally benefit the naturally aspirated cars as all the same rear end problems are still present. The forced induction guys simply notice more of a grip difference in comparison to the N/A guys because most N/A cars don't have traction issues in comparison to SC'd cars. All the other benefits are identical.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
01-15-2014, 06:36 PM | #19 |
Rep 3,246
I've gone delrin (they felt like metal to me) subframe bushings and I'm NA and just did this as my car sees a lot of track time. Did a rear sway install at the same time (that I've subsequently snapped at the bar ,not end links ) and can say I love the solid, responsive feel of the back end and that the whole car just feels that much more responsive and communicative at the limit. Did a 1700 mile round trip days after install with the wife and kids (out to VIR last year) and felt no difference cruising around and neither did my wife. Stayed away from the diff upgrade as I've heard that's what adds the most NVH, (besides the engine ones) and have never once done launch control and don't plan on it, so subframe for me...great writeup
mods: track ready stuff
01-15-2014, 08:40 PM | #21 |
Rep 3,044
Leonardo, just reach out to Malek@MRF. He can get exact figures to you
