01-19-2014, 12:28 PM | #1 |
Rep 1
new owner ... stock sound & bluetooth questions
Hi all ... I'm a new 1 series owner and want to make some updates to the stock sound.
When I removed the battery cover in the trunk I found the Combox (see attached image). My car has the USB connection plug + AUX input but no Bluetooth capabilities. I'm assuming that this is the module to enable BT in my car (calls + streaming) but something is missing because my radio doesn't have any of the BT configuration menus. Am I still missing any hardware or is it just a case of coding? I also have these general question about the stock radio setup in the car. 1. If I removed the stock head unit will I need a radio code to get it working again? 2. Can I add RCA capabilities to the stock radio unit (via some aux cable/harness that plugs straight into the back of the unit)? 3. How do I get a +ve signal from the stock radio to trigger the bass tube to switch on when the radio is switched on? Is there a +ve wire that feeds the Combox that I could use to do this? 4. If I disconnect the battery do I need to recode anything? One last thing, what the big red thing onto of the battery (orange circle in the picture)? Thanks in advance for your help. Bob |
