02-15-2014, 09:58 AM | #1 |
Rep 30
Anyway to get the Oil Temp visible?
As critical as it is to warm these cars up with the rod bearing issues, I was wondering is there is a way via coding or any other methods to get oil temp?
I would think it takes longer for the oil to warm up than the coolant, and i was been unusually cold here in TX and it seems like it takes a solid 10 min to get the temps up. |
02-15-2014, 10:40 AM | #3 |
Rep 1,381
As hard as it is to believe, there isn't a sensor for oil temp. Based on what I read on this forum, the oil temp displayed is just a calculation based on water temp and the intensity of the current needed to heat up the oil level sensor. BMW fail
02-15-2014, 11:15 AM | #4 |
Rep 303
My experience showed that oil temperatures respond faster than coolant temperatures probably because the oil is right where the action is while the coolant is a little more distal. I added an oil temp gauge to one of my cars and it showed temp changes while going up a slight incline. The coolant temp gauge didn't move.
Also, Petros, are you sure about no oil temp sensor? If true that sucks. |
02-15-2014, 11:35 AM | #5 | |
Rep 1,381
02-15-2014, 12:06 PM | #8 |
Rep 120
You are correct same on the s65 I have seen them fail and show falsely high temps and cause fail safe mode and cooling fan going into full spool. http://www.amazon.com/HELLA-00786803.../dp/B000VUANRE
For the OP you can get a app for most phones and get live data or the BMW performance wheels show coolant and oil temps. Last edited by Ging; 02-15-2014 at 12:17 PM.. |
02-15-2014, 04:18 PM | #9 |
Rep 1,067
Drives: 2017 M3 ZCP / 2017 RRS SC
Why don't you just go by the rpm gauge? Don't go above 4k until redline is at 8400. I am not sure how a temp gauge will be any different.
17 M3 ZCP -- 2017 Range Rover Sport SC --RIP-- 12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500 |
02-15-2014, 04:34 PM | #10 | |
Rep 303
02-15-2014, 04:45 PM | #11 | |
Rep 545
The temperature sensor is seated on the housing of the oil condition sensor. The housing of the oil condition sensor contains an electronic evaluation unit. The electronic evaluation unit has self-diagnosis. A fault in the oil condition sensor is entered in the fault memory of the engine management system. The oil condition sensor sends its measured values to the engine management system: ! Engine oil temperature ! Oil level ! Engine oil quality The electrical material properties of the engine oil change as the engine oil wears and ages. The changed electrical properties of the engine oil (dielectrics) cause the capacity of the capacitor to change. The electronic evaluation unit converts the measured capacity into a digital signal. The digital sensor signal is sent to the engine management system. The engine management system uses the signal for internal calculations (e.g. condensate in the engine oil). Note: If you would like to read more about the oil sensor see attached. |
02-15-2014, 06:08 PM | #12 | |
Rep 120
02-15-2014, 06:11 PM | #13 | |
Rep 303
02-15-2014, 06:44 PM | #14 | |
Rep 1,381
02-15-2014, 06:47 PM | #15 |
Rep 120
YES maybe not same part number but same guts. a lot of bmw motors use this type of sensor even if the dashboard doesn't show a reading. In live data thorough OBD-II you can most of the time view oil temp
02-15-2014, 07:18 PM | #17 |
Rep 545
02-16-2014, 10:30 AM | #18 | |
Rep 162
A fluid sensor is a very simple device. It does not care if the fluid is coolant or oil. It will function the same. If the fluid temperature range is similar, it would be reasonable to use the same sensor from an economics perspective.
2009 E90 M3 DCT
02-16-2014, 10:02 PM | #20 |
Stop the hate, get a V8
3853
Rep 8,625
BMW's method of doing it is not very different from other manufacturers. Tons of cars these days have "smart" oil life meters that can tell if the oil is getting contaminated. They're often calibrated to the service fill, meaning if you do not use TWS it can be off by a bit.
Past: 2011.5 M3 sedan ZCP |
