02-21-2014, 04:32 PM | #1 |
Rep 1,459
Cylinder Deactivation
GM seems to really understand this technology, but no other manufacturer seems to be using it on a regular basis. Why not? It seems top be a really easy, cost effective way to have a fire breathing V8, and a fuel sipper on the highway at the same time. Does anyone know why this is hard to mimic, does it have something to do with the push-rod engine?
I would have loved to have seen the new M3 use an updated version of the S65 with this technology. |
02-21-2014, 05:35 PM | #2 |
Rep 1,133
Drives: 2008 Jet Black M3 Coupe
Wind resistance is a factor. Vettes are slick in the wind. It doesn't take 420 hp to make it go
02-21-2014, 05:41 PM | #3 | |
Rep 1,459
02-21-2014, 05:49 PM | #4 |
Rep 3,934
whats funny is that people hate that Cylinder Deactivation. reason: when you have a exhuast, your car will sound like a 4 banger at times. (tunes can turn this off)
BUT if Cylinder Deactivation is something necessary to keep V8s then so be it! |
02-21-2014, 06:25 PM | #5 |
Rep 3,071
My Pontiac G8 GT had this and it never was an issue, though I rally didn't get great gas mileage on the highway.
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/ |
02-21-2014, 06:33 PM | #7 |
Rep 4,488
Apparently it was very difficult for GM to get the transitions between cylinder modes to occur smoothly, especially with a manual transmission involved, so I wouldn't call it an easy way to get a benefit. I imagine there's also the added weight, space, and complexity factors. Most automakers seem to be content simply abandoning NA and dropping cylinders instead.
Also keep in mind that in much of Europe, fees are assessed by engine displacement, not MPG directly or the presence of features like that, so that market responds more to getting power from less displacement rather than making higher displacement engines more efficient. In fact I believe the displacement tax is an ANNUAL charge like our registration fees, not like our gas guzzler tax that the first owner pays once at delivery.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
02-21-2014, 06:41 PM | #8 |
Rep 3,934
02-21-2014, 06:44 PM | #9 |
Rep 4,488
Not 100% certain, though I seem to remember registration fees scaling with displacement. I'm sure someone in Europe will chime in on this thread before long though.
02-21-2014, 06:56 PM | #10 |
Rep 472
It's like that in Singapore; annual tax based on displacement. And since Singapore mimics a lot of British laws, this wouldn't surprise me.
02-21-2014, 08:07 PM | #11 | |
Rep 545
Chrysler = Multi-Displacement System (MDS) Dodge = Displacement On Demand (DOD) GM = Active Fuel Management (AFM) Honda = Variable Cylinder Management (VCM) Daimler AG = Active Cylinder Control (ACC) GM Introduced 2005 T- truck, Envoy, Trailblazer 5.3L V8 RPO LH6, 2005 grand Prix 5.3L More engines added in 2006, (Monte Carlo, Impalla) 2007 SUV’s added, 150,000 produced in 2005, Over 2 million by 2008 Chrysler Introduced in 2004 on the 5.7L Hemi 2005 on 300C, Magnum, Grand Cherokee 2006 Durango, Ram, Commander 2007 Aspen 2009 Challenger The engine management system monitors the following on GM vehicles to allow activation: Transmission in 3rd,4th,5th or 6th gear Engine oil pressure between 25-75 PSI Engine Speed 900-3000 RPM Engine oil temp between 20-150c (68-302f) Engine load steady Battery voltage 11-18 volts The GM and Chrysler versions deactivate the exhaust valves using a special valve lifter on specific cylinders. |
02-21-2014, 08:13 PM | #12 |
Rep 1,133
02-21-2014, 09:12 PM | #14 |
Perception is King
131
Rep 1,703
My 2013 GMC truck has it, that isnt aerodynamic at all.
Perception and Reality are Two totally different Things.
02-21-2014, 09:30 PM | #15 |
Rep 1,459
It has to move the weight of an 8 cylinder engine (ie. the total weight of the car). But cruising on the highway, that's more than enough power, especially when you consider the new Vette has 460 HP.
02-21-2014, 09:45 PM | #17 | |||
Rep 324
AMG uses cylinder deactivation on the current SLK55. The M152 engine is exclusive to that model and it's part of the AMG2015 "Road to Sustainability" campaign. Naturally aspirated 415 hp/398 lb ft torque. 19/28 fuel economy - which is obviously good for an 8-cylinder. It's basically the current engine used in the AMG 63s without turbochargers.
Long-story short, I agree with OP...I'm surprised this technology isn't more prevalent and although it requires some compromises it still is a viable option even in a performance car. |
02-21-2014, 11:28 PM | #18 |
You got my money?
3210
Rep 4,696
Drives: Ice Cream Truck
My tahoe use to deactivate some cylinders. I hated it! It would lag on quick acceleration (felt like 1-2 seconds to switch back to full v8) and the exhaust note (I have a tame borla cat back) was horrid.
I removed it with a handheld programmer and the can tune got me 1.5 MPG MORE even with cylinder deactivation off. Its crap in my book.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
02-22-2014, 03:55 PM | #19 |
Rep 136
I think the Veyron has this technology down cold. It only takes a couple of hundred HP to maintain 200mph once you're there. I guess that's what millions will buy you.
02-22-2014, 05:20 PM | #20 |
Rep 875
I am very interested in this topic actually. How does the other companies' system work?
- Do the valves still open/close when the cylinder is deactivated? I remember to have read that the intake/exhaust valves stay close on the deactivated cylinders to minimize pumping lost but how is it implemented in an overhead cam design? - Is it always the same cylinder that get deactivated? Seems to be but wouldn't this cause uneven wear on the engine in the long run? Our cars (and most modern cars) already sorta have a cylinder management system in that if you lift off the gas while cruising, the ecm will cut all fuel injection until the engine is near idle. How hard is it or if it's possible to elaborate on this a little bit and have the computer just 'skip' a beat when not all the power is needed? I would imagine this would be a smoother transition between on and off and also no uneven wear on the engine either and should help gas consumption. Other posters have mention something about pumping lost negating the benefit though. |
02-22-2014, 05:54 PM | #21 | |
Rep 545
E92zero: PM me with your email and I can send you a PDF file with more information and color photos. I just attended a great webinar on Active Fuel Management systems. I teach automotive technology and there are always plenty of new changes. |
