03-28-2014, 02:50 PM | #1 |
Rep 10,185
F80/F82 Lithium Ion starter battery
Not much talk around about the F80 and F82 Lithium Ion battery used instead of the now regular AGM battery.
Interestingly the battery has built in electronic controls, so things like the Intelligent Battery Sensor (IBS) is a thing of the past. The battery plugs int the cars LIN BUS so the systems can monitor it. 50% weight saving over AGM Thoughts ? EDIT: One major drawback is one cannot use regular car battery chargers, since they charge above 14V, which will damage the Li-Ion battery. Hope dealer remember this when going in for a service and they hook up a charger for the diagnostics
BMW if you are reading, I need a job, Please. Last edited by E90Fleet; 03-28-2014 at 03:30 PM.. |
03-28-2014, 03:08 PM | #2 |
Rep 25,115
Impressive. Like you say, with all the focus rightly on weight saving you think it would attract more press.
My car made front page of Bimmerpost
03-28-2014, 03:10 PM | #3 |
Rep 4,318
Weight saving is nice, curious about longevity and cost. E9x M3 batteries are already about $500 with the BS initializing fee tacked on. The new tech sounds very expensive, we'll see. Last thing I would want is a battery that only lasts 2 years and costs $800 to replace. Hopefully both of those points are exaggerations, and who knows, maybe will last longer.
GT3 RS | Desperately seeking the next great M car...
03-28-2014, 03:23 PM | #5 |
Rep 10,185
BMW says it has improved cold weather performance over AGM battery down till 0C
BMW if you are reading, I need a job, Please. |
03-28-2014, 03:28 PM | #6 | |
Rep 10,185
Sure cost will be high untill main stream models get it aswell
03-28-2014, 04:56 PM | #7 |
Rep 10,407
Interesting, relatively mundane things can really help the battle of the bulge...
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
paffinity21.50 |
03-28-2014, 05:03 PM | #8 |
Rep 10,185
Interestingly BMW speak more about it being a superior power platform for the ever increasing electricity demands of modern cars than its small weight savings.
03-28-2014, 05:21 PM | #9 |
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
$1700 option on a Porsche (but much smaller). I like it, thanks BMW.
Carl L195.50 |
03-28-2014, 05:28 PM | #10 |
Rep 1,984
My car battery charger box says 12v with 2, 10, and 50 amp setting. I guess this one should be ok charging new battery on m3?
03-29-2014, 01:54 PM | #11 | |
Rep 10,185
Only Li-Ion ones I know are industrial spec machines with specific software for them. BMW have not confirmed yet which countries would get the Li-ion batteries. It may be all or only just some. So till deliveries start one cannot know if one needs a new charger or not.
03-29-2014, 03:25 PM | #14 |
Rep 140
Drives: Bimmer Beauty
The most important part of Lithium Ion batteries is the BMS (Battery Management system) that monitors each cell's state and give's accurate reports of the storage unit's actual capacity!
Compared to Lead batteries which have a nice curve depending on their charge status it is not same for Lithium Ion ones, also a curve used by most current lead charge controllers to replenish a flat battery! We use Li Ion storage a lot here de to their higher life span (cycles) and efficiency (much much better than lead alternatives), yes you can use a normal lead battery charge controller as long as you are respecting the max cell voltage but then you start saturating the Lithium Ion battery and cause it to wear out fast/fail once it's full and keep pumping in current! Good read on the subject: http://batteryuniversity.com/learn/a..._ion_batteries Though back to initial topic, good to see the use of Li-Ion battery in here, less weight, better lifetime, no real issues of wear when exposed to the same temperatures inside the engine bay as with Lead batteries. |
03-29-2014, 05:57 PM | #16 |
Rep 1,749
i think the standard charger will work. again porsche went through this and there is no special charger for the Lithium batteries. i have had it in my gt3 for past 4 years. take it out in winter months in germany and put standard one in. it doesn't like temps below 40f. hellova lot lighter than regular battery but have no idea its in the car performance wise.
"It gave you amazing satisfaction, but anyone who says he loved it is either a liar or he wasn't going fast enough." - Jackie Stewart on racing at the Nurburgring
03-29-2014, 06:59 PM | #17 |
///M Uber Alles
332
Rep 1,601
I hope they use the regular batteries for Canadian spec'ed cars. I don't mind saving weight but a slightly lighter car that doesn't start when you need it to is worse than a few extra pounds.
die Welt ist meine Auster 2015 M4, MW, Black Full Merino, DCT, CCB, Adaptive M Suspension, Premium, Executive. Technology, ConnectedDrive, CF Trim, Convenience Telephony, European Delivery Last edited by M4TW; 03-29-2014 at 08:27 PM.. |
03-29-2014, 08:21 PM | #18 |
Rep 10,407
Many (most?) BMWs have their batteries in the trunk anyway and I'm sure the new M3 and M4 do.
03-30-2014, 04:37 AM | #19 | |
Rep 10,185
Dealers have to have their workshop chargers software upgraded to include Li-ion settings. The equipment currently charges AGM batteries at 14.8V. Most amateur chargers charge between 14V and 15V. I see CTEK has a lithium ion specific charger in both USA and European forms that charges at 13.8V.
BMW if you are reading, I need a job, Please. Last edited by E90Fleet; 03-30-2014 at 04:43 AM.. |
03-31-2014, 03:11 AM | #20 |
Moderator
618
Rep 10,855
A lot of us got Braille Lithium batteries for our E90s to reduce weight. No real problems with the bigger ones for DD use.
And damn, BMW has still not hired E90fleet?!
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
03-31-2014, 04:31 AM | #21 |
Rep 10,185
No, wrong color so cant even get a interview
03-31-2014, 07:50 AM | #22 |
Rep 4,144
Li ion is the future. Soon the majority of cars will be using these kinds of batteries. They are supposed to last longer and are lighter than common lead acid batteries. It's a good thing that BMW is starting to use these. I'd have liked to have seen them in the E90 M3's. I guess they weren't quite ready until now.
Cheers.
2017 F80 YMB.
