View Poll Results: Speculation on, which one would be faster. M3 or M4 | |||
I believe the M3 is going to be faster. | 7 | 6.86% | |
I believe the M4 is going to be faster. | 30 | 29.41% | |
I believe they will offer identical or nearly identical performance. | 65 | 63.73% | |
Voters: 102. You may not vote on this poll |
03-29-2014, 11:00 PM | #1 |
Rep 94
Speculation on which one will be faster: M3 or M4
Since, Majority of us believe that The New M3/4 will be faster then the M3 GTS. Let Speculation on, which one of the M's would be faster. M3 or M4?
Please state your reason. M4/M3 Track Videos. Last edited by Flying Brick; 03-29-2014 at 11:31 PM.. |
03-29-2014, 11:18 PM | #4 |
Rep 94
There is a miner difference in the Curb weight between the 2 cars. Plus the chassis of the cars will be different. Which will make some difference on the track to get a better lap time.
03-29-2014, 11:18 PM | #5 |
///M Uber Alles
332
Rep 1,601
If speculation can be validated, then doesn't it stop being speculation? Anyway I speculate that they will be about the same until higher speeds at which point the lower drag coefficient of the M3 - .31 vs. .34 - might give it a slight advantage. A .03 advantage to be precise.
die Welt ist meine Auster 2015 M4, MW, Black Full Merino, DCT, CCB, Adaptive M Suspension, Premium, Executive. Technology, ConnectedDrive, CF Trim, Convenience Telephony, European Delivery |
03-30-2014, 06:21 AM | #9 |
Rep 20,742
Drives: 2021 911 turbo
Faster is a very broad term. I am assuming it means around a race track. I believe the difference will be marginal with a slight edge going to the M4 with its 50lb lower weight and lower center of gravity.
03-30-2014, 06:34 AM | #10 | |
Rep 20,742
03-30-2014, 07:11 AM | #11 | |
Rep 94
I am hoping that no one is planning to do any racing with the M3/M4 on the streets . |
03-30-2014, 10:29 AM | #12 | |
///M Uber Alles
332
Rep 1,601
I guess the M4 would have an advantage based on weight. 50 pounds is worth about 5 hp or .05 in the 1/4. Since it is a race however it will come down to the drivers and which car came out of the factory better.
03-30-2014, 10:39 AM | #13 |
Rep 3,899
Identical performance IMO. The weight difference is slight- a fat driver in the M4 and a thin driver in the M3 and now the M3 is lighter...full fuel tank vs 1/4 tank, heavily optioned car vs no options- this is the difference in weight we are talking about- negligible.
2014 AW F80 M3 DCT
2011 AW E90 M3 DCT - Sold 2010 JZB E90 M3 DCT - Sold 2009 6MT E90 LCI 335i M -Sport - Sold |
03-30-2014, 02:45 PM | #14 |
Rep 5,110
If we are talking straight line performance, as that is what quite a few of the replies seems to adress, then those numbers are allready listed in the official spec threads and gives a advantage to the lighter M4.
If you mean lap times around a track with similarly equipped cars, the same advantage should be visible for the M4 again. It's got a lower CoG and less weight, that aids both acceleration, braking and cornering. The above also assuming same driver and everything else equal. In real life, not a great advantage to either is my guess, as most drivers aren't able to extract 10/10ths of such a cars potential anyway |
03-30-2014, 03:23 PM | #15 | |
Rep 20,742
Cd is a dimensionless factor that represents how "slippery" a given shape is in an airflow regardless of its size. For instance, a cube of 1x1x1 inches will have the same Cd as a cube of 3x3x3 feet. To establish the drag force, one needs to multiply the Cd by the frontal area of the object. For instance, despite having the same Cd, the 3 foot cube will have a drag resistance force 1296 times greater than the 1 inch cube when exposed to the same airflow. Due to its greater frontal area, the M3's drag will be 2.7% greater than the M4's (assuming that their Cd are really equal at 0.34 and not rounded off). |
03-30-2014, 04:06 PM | #16 | |
///M Uber Alles
332
Rep 1,601
03-30-2014, 10:34 PM | #20 |
Rep 10,407
No, if the cube is traveling in a direction parallel to the normal of any face, it will have a drag force 9 times as large.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
03-31-2014, 01:56 AM | #22 |
Law Enforcer
25209
Rep 22,306
Drives: '22 Chalk Gray Porsche C2S
